E30 (1982 - 1993)
Old 09-22-2012, 10:44 PM
jadasilva jadasilva is offline
Mein Auto: 1987 Alfa Spider Quad
Spec E30 car build question
Hi all,
Looking to purchase my first 325 to get into the Spec E30 series, but was wondering if anyone had any input on which base car (325i or 325is) would be preferable? I understand the iS comes standard with LSD and closer gear ratios 1st-3rd...are these two features alone worth the extra price to find an is over an i?
Thanks!
Old 09-23-2012, 12:51 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
not sure where you got the closer ratio box from, a 325iS has the gears further apart and 1 2 and 3 are all taller than a standard 325i box. They do have a shorter ratio LSD though, its a 3.91 instead of 3.73
referance: E30 sales brochure
E30 above Sold
Last updated 2nd January 2014
Old 09-23-2012, 11:29 AM
downhiller's Avatar
livin large
the is will be a better starting place. since it has the "sport" suspension and the lsd.
Old 09-23-2012, 08:02 PM
ah yes maybe i got the two mixed up, thank you.
@downhiller...do you still think it is worth the premium considering I will be swapping out the suspension for spec units anyway? and the lsd can be purchased separately?
Old 09-23-2012, 10:35 PM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
AFAIK the is is different in that it had an engine oil cooler, LSD, sport seats, and front/rear spoilers. Everything else was the same as the i.
I Timothy 2:1-2
Old 09-24-2012, 02:05 AM
yes thats right, all readily available parts, and seeing as you will be bastardising the car you might as well get a 325i and save the cash
E30 above Sold
Old 09-24-2012, 03:03 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Question engine oil cooler
Code:
Thanks for mentioning it
I want to retrofit one into my 323, as we think 100F is a balmy day
The cooler is not the issue, but the adapter to the engine
I do not want one of these generic adapters that flows oil through the cooler on start-up , but one that only starts flowing through the cooler upon a certain oil temperature being reached
Where can I get such ?
I suppose the pressure hose I need to plumb into the turbo later on, will come from the oil pressure switch ?
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 09-24-2012, 05:31 PM
downhiller's Avatar
livin large
dont they have stiffer springs?
Old 09-25-2012, 04:53 AM
Originally Posted by Nick323 View Post
Code:
the factory BMW ones are like that. but being from africa, you will find one very easy to get, ever SA built 325i had an oil cooler from the factory
they were optional on all E30s, only came standard on M325i and M3
E30 above Sold
Old 09-26-2012, 02:24 AM
Nick323's Avatar
Nick's Toys
Question Oil cooler adapter
Code:
Thanks Andy
Do you know if they had a built in Thermostat ?
I would need to order one, as I will not have much luck at the breakers, I think...
Old 09-27-2012, 06:14 AM
an audience of One
Maybe in other markets (of course the other guys get the good stuff ) , but I'm pretty sure that NA had the same springs, trans ratios, damper valving, sways, etc. The final drive was the only mechanical variable, I believe.
Code:
Thanks Andy
Those are notorious for being stuck open or closed. You may want to source a new one or an aftermarket unit.
I Timothy 2:1-2
Old 09-27-2012, 09:54 AM
ForcedFirebird's Avatar
ForcedFirebird ForcedFirebird is offline
Mein Auto: 1986 327is
Have you read the rules yet?
There are 2 gearbox part numbers allowed, and have the same ratio's. You have to run a 3.73 final drive, H&R Race springs and Bilstien Sport dampers. Any sway bars are allowed, but have to be attached to the control arms (no m3 style mounting), and have a limit on the amount of camber/caster you adjust. Strut bars are permitted as are electric fans, power steering delete, A/C delete. There's more, but not going to go into into it here, just read the rules...
http://www.nasaproracing.com/rules/spec30_rules.pdf
In all honesty, best to start with a 318 shell if you are going to piece it together, saves you the time of removing all the sound deadening.
My friends and I are almost finished with one Se30 car and are building 2 more. Glad to see more racers out there coming up
Wide Open Throttle Technologies (WOT-Tech)
Instagram feed
Facebook page
Old 09-27-2012, 11:24 AM
Gasturbine Gasturbine is offline
Mein Auto: '87 325i Cabrio
Ive got an i with sports seats and an oil cooler, so would I have a factory ordered car, or did BMW mix and match some on the floor?
Old 09-27-2012, 11:30 AM
All b25's came with oil coolers. The 325eS and 325iS came factory with sport seats, different lip or air dam, LSD final drive and trunk spoiler. No iS or eS in sedan formats.
Gasturbine, enter the last 7 numbers of your vin into realoem.com and you will see all the options our car came with. Being older cars, they often have swapped parts.
Instagram feed
Facebook page
Old 09-27-2012, 12:15 PM
Huh? I thought my engine was an M20?
Ive been down this road before. Sites says nothing about sport seats, but first owner insists those were the original seats when he bought the car off the floor.
Old 09-27-2012, 12:39 PM
hornhospital's Avatar
D'oh, You Kids!
Correct on the engine. It is an M20. M20B25
Quotes to live by:
Old 09-27-2012, 12:45 PM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 99' 540i M-Sport
It is.. m20b25 for the i models. Mine is a m20b27 for the moment in my e .
1999 540i M-Sport
Silver/Black
Still fresh and Minty
1985 335i
Black on Black coupe 5spd
R.I.P
1979 Trans Am 10th Anniversary
#16 of 5,683 made
KOI Import Parts-- 513-771-7777
Old 09-27-2012, 01:20 PM
Dude, you have a cabby. They came factory with sport seats, LSD and heavier sway bars than the iS cars. Didn't notice the info near your username. 325iC is same as 325iS just roof-less.
Instagram feed
Facebook page
Old 09-28-2012, 04:03 AM
Nick323's Avatar
Nick's Toys
Question Thermostat in oil cooler circuit ?
Markseven, before you get me more confused than a baby in a topless bar
Code:
Are talking bout the H2O Thermostat or one in the Oil-cooler adapter circuit ?
On the Oil cooler adapter, what are the possibilities ?
I have a 323 without a Oil cooler and am looking on how to adapt this oil system to such.
The cooler itself is not the issue, but how does one plumb it to the lubrication system. On the ETK it looks like it is part of the Oil filter housing assembly, but I cannot go deeper than that...
Old 09-28-2012, 10:24 PM
an audience of One
Code:
Hey man, sorry, I was mistaken, the thermo is not serviceable. You need to get the whole oil filter housing. IIRC, the cooler reduces temps by 4°, so it may not even be worth it... except for more oil capacity due to the cooler itself.
I Timothy 2:1-2
Old 10-01-2012, 03:40 AM
Nick323's Avatar
Nick's Toys
Question Oil filter to cooler housing number ?
The story behind Oil coolers on high revving motors is that the oil temperature increases exponentially with RPM. I did a study for Toyota on underhood temperatures
If I want to fit a Turbo...
Anybody got a part# for this oil filter housing with cooler connections ?
Will this fit on my 323 block ?
Old 10-01-2012, 07:32 AM
an audience of One
With a turbo, don't you want to relocate the filter anyway?
I don' know if it the housing you want will fit - Andy will prolly be able to say yes or no.
PNs:
http://realoem.com/bmw/showparts.do?...29&hg=11&fg=30
I Timothy 2:1-2
Old 10-02-2012, 03:44 AM
Nick323's Avatar
Nick's Toys
Thumbs up
Thanks for the link Markseven
On my 323 the Filter is bolted directly onto the block.
So I am not sure whether the Oil filter head 11421711070 will just bolt on and voilá ?
Why would you think I need to relocate the filter with a Turbo set-up ?
Will it be in the way ?
I have not yet decided on where to purchase my Manifold and what Turbo to use, as I first want to see what lurks under my cylinder-head
Old 10-02-2012, 07:50 AM
an audience of One
I don't know much about turbos, but from what I have seen on *most* FI M20s, the snail sits close to the oil filter. I would imagine the thin wall of the screw-on filter will soak heat like a sponge. I could be wrong.
I Timothy 2:1-2
