New Here!! N Havin a Problem - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 09-10-2012, 01:52 PM
JoEy FRESH JoEy FRESH is offline
Mein Auto: 1984 BMW 325e
Whats Up Every1,
Year: 1984 Manual: 5speed 2-door
Model: 325e VIN#: 1008993
I have a problem with my bimmer. I'll drive and when I hit 4th or 5th gear it tends to bog down and I'll have rev it a bit just so it stays on or it will die on me. What seems to be the problem? THANKz
Old 09-10-2012, 08:50 PM
downhiller's Avatar
livin large
youre not going fast enough.
Old 09-10-2012, 09:35 PM
1991318i 1991318i is offline
Mein Auto: BMW E30 0011-0001-1000
yup
dat E30
Old 09-11-2012, 04:59 PM
I'll go fast and faster I go the faster it tends to bog down.
Old 09-11-2012, 06:35 PM
downhiller's Avatar
livin large
last time youve done a tune up?
Old 09-12-2012, 06:00 AM
what speed?
dat E30
Old 09-12-2012, 06:39 PM
downhiller's Avatar
livin large
Originally Posted by 1991318i View Post
what speed?
he said fast. now im thinking motorcycle fast here, so he should be getting out of 2nd gear and going into 3rd at about 80mph.
Old 09-12-2012, 08:01 PM
Well its been a while.i changed the spark plugs, fuel pump(not the one inside the gas tank), oil. could it be the anti freeze???
Old 09-12-2012, 08:50 PM
BMWFatherFigure's Avatar
Old School
Not antifreeze unless you have a blown head gasket. Leaking injectors - does it idle ok? Blocked air filter? MAF sensor?
Old 09-19-2012, 01:07 PM
Cletonius Cletonius is offline
Mein Auto: 1990 325is
Maybe check the distributor cap/rotor as well.
Old 09-19-2012, 03:05 PM
damalex's Avatar
damalex damalex is offline
Mein Auto: 89 E30
How long have you bin driving a 5 speed for???:what:
Sent from my DROIDX using Bimmer App
Old 09-27-2012, 06:10 PM
Just got a new MAF sensor. Thats not the problem but it was burnt tho. and Ya it does idle a bit.
Imma check out the distributor this weekend.
Ill be in 5 speed for a least 20min or not less..
hit me back up dont wanna take it to the mech.
Old 09-27-2012, 06:20 PM
downhiller's Avatar
livin large
if you only been driving a manual for less then a week, you just need to drive it more. run the revs to 3k each gear. if youre driving around town and the speed limit is 35, dont leave 3rd gear. if its 45, go into 4th. its when its over 50, youll want to drop into 5th. trust us, run the revs higher, make the car happy.
Old 09-27-2012, 06:35 PM
ya trust me im on 5th only on the freeway
Old 09-27-2012, 07:58 PM
downhiller's Avatar
livin large
there not much else it can be if its only happening in 4th and 5th. the gear doesnt change how the engine functions. OBD1 and euro 1 cars dont have the option of running multi fuel maps per gear. so the only options are, either you downshifted too soon, youre driving through water, or everywhere you drive is a 7% uphill grade.
Old 09-28-2012, 04:04 AM
Billwill Billwill is offline
Mein Auto: BMW E30 318i 1991
You sure you have the correct diff for your e30 fitted?
Old 09-28-2012, 06:07 PM
downhiller's Avatar
livin large
hes only been in it 20min. most likely for being an 84, its still the stock diff.
Old 10-09-2012, 03:36 PM
I found what the problem was. It was the fuel pump inside the gas tank. I KNEW IT but wasnt so sure. But now it idles high just a bit after driving it.
Old 10-09-2012, 07:38 PM
Old School
Change the fuel filter and get the injectors bench cleaned and tested. Then start on the erratic idle. ICV clean for starters.
Current:
E38 Parts Car
Previous:
