Old 09-28-2012, 01:53 AM
Leekay07 Leekay07 is offline
Mein Auto: X5 35D, Former X1 and 335
Money money :o) Wicked wheel shudder..
A week a go i had my wheels road forced balanced and they insisted that I had a bad tire and it needed replacing. Well I had it replaced.
Now my car shudders from 62-80mph
I had an indy replace my drive belt tensioner, Oil filter housing gasket, and mecatronic seal and they also replaced my tranny fluid.
Now my issue is I asked him to check my wheel bearings and he said they are fine. So now I am at a lose whats causing the shudder. It can be seen in the wheel too it moves left to right.
I am beginging to think i should just replace my rotors. They dont feel warped but what else could it be at this point.
Old 09-28-2012, 03:29 AM
sirjaymill sirjaymill is offline
Mein Auto: 2008 M5
I have the same issue later found my thrust rod bearing need to be replaced.. will try and get a pic of them this weekend. Note: I still haven't gotten them fix.
Sent from my A500 using Bimmer App
Old 09-28-2012, 05:59 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Do you say when the car's jacked up the wheel's loose - moves left/right? Talkin' about the tire rims.
Or the steering wheel shimmys at speed?
If depending on a vendor to fix, you should see a front end specialist or BMW Dealer.
Old 09-28-2012, 06:28 AM
I have had my wheel alignment done, tires road forced balanced that highlighted a issue with a tire replaced it same thing is happening. had my bearings checked. I have zero abnormal wear on the tires they are all wearing well within exceptable wear rate (16k on the current tires with zero inside wall wear).
Old 09-28-2012, 06:30 AM
The steering wheel at speed shakes left to right about 3mm - 5mm travel.
Old 09-28-2012, 06:32 AM
DougN's Avatar
DougN DougN is offline
Original Owners Club
Mein Auto: '10 E93;'66 MGB;'73 240Z
Did you have the wheel shudder before the force balancing? If not, why are you throwing other parts at the problem if it did not exist before the wheel was balanced/new tire?
Doug
________________________________________________
2010 328 E93 Titanium|Black|Aluminum
Other Cars:
1973 Datsun 240Z
1966 MGB Roadster
Old 09-28-2012, 06:35 AM
haskindm haskindm is offline
Mein Auto: 335I Convertible
Rotors would only cause a shudder while braking.
Old 09-28-2012, 08:25 AM
Look for worn suspension arm bushings/ball joints. Easily checked for and easily fixed.
Don't forget to check sway bar mounts while you're there.
At what speed does this occur? Mild balancing prob might show up ~75 mph.
Old 09-28-2012, 09:01 AM
john@eac john@eac is offline
Past Sponsor
Mein Auto: Many
What do you mean when you say you can see it in the wheel?
Old 09-28-2012, 11:18 AM
See Post #5, above.
Old 09-28-2012, 11:27 AM
bmwrocks's Avatar
bmwrocks bmwrocks is offline
Mein Auto: 2011 328i Convertible
I think it is possible the new tire is bad. Went/is out of round or the like. Check that first.
2011 328i Convertible : Mineral White; Oyster/Black Dakota Leather; Premium, Sport, Value; Sport Wheel w/paddles; Heated Front Seats; Satellite radio; HK Sound
2012 528i Sedan : Titanium Silver; Oyster/Black Dakota Leather; Anthracite Wood; Comfort Access; Side & Top View Cameras; Cold Weather, Premium; Technology;
2004 330ci : Titanium Silver; Gray Leather; Premium, Sport; Fold Down Rear Seats; Xenon Headlights; Navigation System; HK Sound
2001 X5, 2009 528i (retired)
Old 09-28-2012, 02:54 PM
OK so since my nwq tire where put on i have had this issue. The tech noted when the tires where installed that a rim was bent. So I always put it down to the rim. I just replaced the rim and had the road forced balance done and they waid one tire is bad and that the shudder is a result. SO I got the tire replaced under warranty and well its still here from 55-80mph. I had the bushes checked the control arms checked the sway bar bushes all good.
Old 09-28-2012, 03:22 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
stock rims?
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Old 09-28-2012, 05:17 PM
pointandgo's Avatar
pointandgo pointandgo is offline
Mein Auto: '13 F10 535i (loaner)
If you had the tire/wheel assembly checked on a Hunter "road force" 9700/9712, this machine should have been able to diagnose the problem. The machine, however, needs periodic software upgrades...calibration, and is only as good as the skill of the operator....and then they have to apply the "correcting" weights properly.
Sounds like someone doesn't know how to use the machine if they gave a "pass" to the second, replacement tire IMO.
Do you remember how many "pounds force" the first and 2nd tire had before and "after" alleged correction? Did they find any contribution of the wheel to the problem? This machine (if indeed the Hunter machine) can easily detect out-of-round wheels.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
'71 AMC Javelin (4-Spd Stick on the floor)
'67 Pontiac Firebird 'cabrio' (1st car - "the leaker")
Member: BMW CCA
