E90/E91/E92/E93 (2006 - 2013)
Money money :o) Wicked wheel shudder..
A week a go i had my wheels road forced balanced and they insisted that I had a bad tire and it needed replacing. Well I had it replaced.
Now my car shudders from 62-80mph I had an indy replace my drive belt tensioner, Oil filter housing gasket, and mecatronic seal and they also replaced my tranny fluid. Now my issue is I asked him to check my wheel bearings and he said they are fine. So now I am at a lose whats causing the shudder. It can be seen in the wheel too it moves left to right. I am beginging to think i should just replace my rotors. They dont feel warped but what else could it be at this point. |
I have the same issue later found my thrust rod bearing need to be replaced.. will try and get a pic of them this weekend. Note: I still haven't gotten them fix.
Sent from my A500 using Bimmer App |
Do you say when the car's jacked up the wheel's loose - moves left/right? Talkin' about the tire rims. Or the steering wheel shimmys at speed? If depending on a vendor to fix, you should see a front end specialist or BMW Dealer. |
I have had my wheel alignment done, tires road forced balanced that highlighted a issue with a tire replaced it same thing is happening. had my bearings checked. I have zero abnormal wear on the tires they are all wearing well within exceptable wear rate (16k on the current tires with zero inside wall wear).
The steering wheel at speed shakes left to right about 3mm - 5mm travel.
Doug ________________________________________________ 2010 328 E93 Titanium|Black|Aluminum Other Cars: 1973 Datsun 240Z 1966 MGB Roadster |
Rotors would only cause a shudder while braking.
Don't forget to check sway bar mounts while you're there. At what speed does this occur? Mild balancing prob might show up ~75 mph. |
What do you mean when you say you can see it in the wheel?
See Post #5, above. |
I think it is possible the new tire is bad. Went/is out of round or the like. Check that first.
2011 328i Convertible : Mineral White; Oyster/Black Dakota Leather; Premium, Sport, Value; Sport Wheel w/paddles; Heated Front Seats; Satellite radio; HK Sound ![]() 2012 528i Sedan : Titanium Silver; Oyster/Black Dakota Leather; Anthracite Wood; Comfort Access; Side & Top View Cameras; Cold Weather, Premium; Technology; ![]() 2004 330ci : Titanium Silver; Gray Leather; Premium, Sport; Fold Down Rear Seats; Xenon Headlights; Navigation System; HK Sound 2001 X5, 2009 528i (retired) |
OK so since my nwq tire where put on i have had this issue. The tech noted when the tires where installed that a rim was bent. So I always put it down to the rim. I just replaced the rim and had the road forced balance done and they waid one tire is bad and that the shudder is a result. SO I got the tire replaced under warranty and well its still here
from 55-80mph. I had the bushes checked the control arms checked the sway bar bushes all good.
stock rims?
Sounds like someone doesn't know how to use the machine if they gave a "pass" to the second, replacement tire IMO. Do you remember how many "pounds force" the first and 2nd tire had before and "after" alleged correction? Did they find any contribution of the wheel to the problem? This machine (if indeed the Hunter machine) can easily detect out-of-round wheels.
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic. ------------------------------------------------------------------------ E90 328i E92 335i 6MT E46 M3 6MT E39 528i 5MT MBz W140 S320 MBz W124 300E (slammed) (unmentionables in between) '71 AMC Javelin (4-Spd Stick on the floor) '67 Pontiac Firebird 'cabrio' (1st car - "the leaker") ------------------------------------------------------------------------ Member: BMW CCA |
