Stop Driving your M5 or M6 - Oil pump recall - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > F10 M5 (2012 - 2016)
The 5th generation M5 has the V8 S63 TU engine with twin turbos under the hood producing 550hp. The engine and DCT gear box pusses the M5 0-60 in just 4.2 seconds.
Old 09-21-2012, 12:40 PM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
BMW M5 and M6 S63tu engine recall faulty oil pump
2013 BMW M5 and M6s powered by the S63TU engine are being recalled because of a faulty oil pump. The oil pump has already claimed at least one engine of a Bimmerfest European Delivery customer while driving on the Autobahn. If you have an M5 or M6 you should be getting a call from BMW NA shortly and are instructed not to drive your car. Driving your M5 or M6 can result in a dramatic lose of oil pressure that will destroy the engine.
NHTSA Recall Campaign Number 12V475000
Vehicle Make / Model / Year
BMW / M5 / 2013
BMW / M6 / 2013
Manufacturer: BMW OF NORTH AMERICA, LLC - Report Receipt Date: SEP 28, 2012
Component: ENGINE AND ENGINE COOLING:ENGINE
Potential Number of Units Affected: 696
Summary:
BMW is recalling certain model year 2013 M5, M6 Coupe, and M6 Convertible vehicles, manufactured from July 19, 2012, through September 11, 2012. Due to a manufacturing process error, the tolerance between the engine oil pump's drive shaft and the pump's rotor was not within specification. As a result, the pump's driveshaft could separate from the rotor.
Consequence:
Separation of the pump's driveshaft from the rotor could lead to a sudden loss of oil pressure causing the possibility of complete engine failure, resulting in an engine stall-like condition, increasing the risk of a vehicle crash.
Remedy:
BMW will notify owners, and dealers will replace the oil pump, free of charge. The safety recall is expected to begin during October 2012. Owners may contact BMW at 1-800-525-7417.
Notes:
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov.
Source nhtsa.dot.gov
Frequently Asked BMW M5 and M6 Recall Questions
Which models are affected by this Recall?
Affected are certain Model Year 2013 BMW M5, M6 Coupe, and M6Convertible vehicles produced between July 2012 and September 2012.
What is the specific problem?
The issue involves the engine oil pump. The pump driveshaft can separate from the pump rotor. If this were to occur, the engine could experience a sudden loss of oil pressure which could cause severe engine damage.
Why are other models not affected?
It has been determined that only certain vehicles produced between July 2012 and September 2012 were equipped with an incorrectly manufactured oil pump.
How many vehicles are affected?
Approximately 696 vehicles in the US are potentially affected.
What can happen as a result of this issue?
A sudden loss of oil pressure could occur, as well as the possibility of severe engine damage.
Can the driver become aware of the problem?
Yes, if the vehicle experiences a sudden loss of oil pressure, a low oil pressure warning indicator is displayed in the instrument cluster, along with a warning message in the control display.
What corrective measures will be taken?
The engine oil pump will be replaced.
How did BMW become aware of the problem?
BMW became aware of the problem through its quality control procedures.
Is BMW aware of any accidents or injuries associated with the Recall?
No.
Can customers continue to drive their vehicles?
We recommend that owners of affected vehicles do not drive their vehicle until this Recall can be completed. If the vehicle experiences a sudden loss of oil pressure, carefully pull over to the
side of the road and shut off the engine. Please contact BMW Roadside Assistance at 1-800-332-4269. If you are not the only driver of this vehicle, please advise all other drivers of this
important information.
How will customers be informed of the Recall?
The BMW Customer Relations department is calling owners of affected vehicles, advising to them discontinue driving the vehicle until the Recall has been completed. Subsequently, owners will receive a letter via First Class mail asking them to schedule an appointment with their authorized BMW center.
How will the Recall be performed?
Affected customers who make an appointment will have the engine oil pump replaced on their vehicle.
How long will the repair take?
This repair may take two and a half hours; however, additional time may be required depending upon the center's scheduling and processing. The repair will be performed free of charge by your authorized BMW center.
How many vehicles have experienced this problem?
The exact number is unknown at this time.
When will I receive my owner notification letter?
Mailings are planned for October 2012.
Do I have to wait for my Recall letter in order to have my Recall performed?
Yes. BMW is in the process of implementing the Recall Campaign to ensure that the necessary parts are at the authorized BMW center prior to sending out the owner notification letters.
I see the "TREAD Act Customer Reimbursement Plan" attached to my letter. Can you explain what that is about? Am I eligible for reimbursement?
If you have already had this repair performed at your own expense, you may be
eligible for reimbursement of certain expenses that you incurred.
Does anyone else thing it is unfortunate that BMW is making new M5 and M6 owners not drive their new Bimmers? I would be more the slightly frustrated I cannot drive my new M5 or M6 for at least a few weeks while BMW gets the parts together to fix it. Is anyone's BMW M5 or M6 effected by this?
More about Stop Driving your M5 or M6 - Oil pump recall
BMW-F10-M5-Revealed 1BMW-F10-M5-Revealed 2BMW-F10-M5-Revealed 3BMW-F10-M5-Revealed 4BMW-F10-M5-Revealed 5BMW-F10-M5-Revealed 6BMW-F10-M5-Revealed 7BMW-F10-M5-Revealed 8BMW-F10-M5-Revealed 9BMW-F10-M5-Revealed 10
Old 09-21-2012, 01:59 PM
kgapp kgapp is offline
Mein Auto: 2012 M6, 2009 X5
Deleted
Old 09-21-2012, 03:14 PM
AutoUnion's Avatar
AutoUnion AutoUnion is offline
Mein Auto: Deutsch Automobil
Looks like BMW still doesn't have their quality control in check. Come on! These are $100k+ cars going to your most loyal and dedicated fanbase
Old 09-22-2012, 02:02 AM
Sophisto Sophisto is offline
Mein Auto: F11 530D
Seems an oil pump autopart supplier is going through some rough times.
Old 09-22-2012, 04:36 PM
tedb1965 tedb1965 is offline
tedb1965
Mein Auto: 2009 535i xDrive
Wonder what this will do to resale value of these early production machines...
Ouch.
Old 09-22-2012, 08:04 PM
charlesberry's Avatar
charlesberry charlesberry is offline
Mein Auto: E46 944 Turbo
I was at Flemington BMW this morning and a shiny new M5 rolled in on the back of a flatbed.
Old 09-24-2012, 01:34 PM
mpresiv5 mpresiv5 is offline
Mein Auto: F10 M5
Received an email from dealer to get an x5 loaner. Just left tischer BMW was told my car isn't on the recall list (even though I knew it wasn't) and that I'm good to go..
Happy to drive my car home!
Old 09-25-2012, 05:42 PM
Kilani Kilani is offline
Mein Auto: M5 2013
I dropped off the car today.
It's very disappointing haven't had the time to enjoy it since i was still breaking it in. Very disappointing the worst thing ever the heart of the car. They said it will take 2-3 weeks. Any comments????
Old 09-25-2012, 05:51 PM
Mein Auto: M5 2013
I just remembered the oil check light came on once and I just brushed it off.
Checked the system and later it turned off. Could this have effected the engine at all?
Old 09-26-2012, 07:08 PM
tol4o tol4o is offline
Mein Auto: E92 M3 & X5D
The usual problems with the first year production. We had 2004 X3 and we had so many problems! I personally would avoid buying first year production
Old 09-27-2012, 11:51 AM
Axel61's Avatar
Axel61 Axel61 is offline
Mein Auto: 335d
That sucks!!!
Old 09-27-2012, 01:26 PM
Mein Auto: M5 2013
Damn right
Old 09-28-2012, 05:22 PM
rhird rhird is offline
<a href="http://www.Ticke
Mein Auto: E92 M3
So much for being first in line
Old 10-05-2012, 12:57 PM
tim330i's Avatar
The official recall has been posted but the NHTSA. Has anyone heard anything from BMW?
BMW / M5 / 2013
BMW / M6 / 2013
Summary:
Consequence:
Remedy:
Notes:
Old 10-06-2012, 11:14 PM
LongBeachBMW LongBeachBMW is offline
Past Sponsor
Mein Auto: BMW M3 Coupe
The new oil pumps have been arriving at the dealership for sold cars already. One of my ordered M5's was delivered a few days before the recall. Car was brought in to Service the day of the recall. New oil pump arrived with his VIN on Friday, Oct 5. Customer picked up car later in the day. Car was in Service Dept for 2 weeks. Customer was very happy to get his car back for the weekend.
Old 11-25-2012, 11:23 AM
Sawbones Sawbones is offline
Mein Auto: 335i vert
My oil pump was taken care of at the VDC prior to delivery at the dealer. Got a letter from BMW this weekend for a free M school day in Virginia for the inconvenience.
bmw, bmw f10 m5, bmw m5, bmw news, bmw recal, f10 m5, f12 m6, f13 m3, m5 recall, m6 recall
