DIY: 1998 BMW 528i, Replacing Driver Seat Belt Buckle (Pretensioner)
I have Air Bag Light on the dash for almost 2 years now. Scanned with Carsoft Version 6.50. Related thread here "Any Carsoft expert here? Codes 16, 24": http://www.bimmerfest.com/forums/sho...d.php?t=449818 It turned out to be Driver's Buckle (aka "Pretensioner"). PN 72118240045: $150 at local BMW Dealer. Don't even try to buy this online, because of the explosive charge inside the assembly, most online vendors won't ship it. So buy it from BMW dealer only! This part varies from year to year, so ask your BMW dealer for help, or you can use realoem.com (enter your VIN). When you have the Air Bag Light, it could be many things. You need to scan the codes. Most people here use Carsoft Version 6.50 because it is cheap (since it is not the real version). 1. Pass seat sensor (search forum) 2. Crash Sensor(s), Front or Side: initially I thought this was the case and replaced it, see pic. 3. Seat Belt Buckle. BMW designs an explosive charge into the assembly, in a crash, the explosive charge is fired and this will pull the steel cable downward, tightening the belt, limiting the driver torso from going forward too far. I am not too sure this feature makes any difference because my Volvo and Honda buckles do not have this feature (explosive charge). For those curious where the side crash sensors are located, they are under the front seat. Instruction for Front Seat removal is below. http://www.bimmerfest.com/forums/sho...d.php?t=459397 Again, this part (side impact sensors) rarely goes wrong, so I included here only for reference: Options: 1. Do nothing, just placed a black electrical tape over. This is what I did for 1 year because I know it is the driver's buckle and nothing else, so worst-case scenario: during a crash, the seat belt will not be tightened further, similar to other cars I have so no big deal. 2. Fix it! Finally I have some time (and money) and decided to fix this. Also special thanks to "bimmerteck" for his advices before doing this job! Parts: PN 72118240045: $150 at local BMW Dealer. Tools: - Torx Bit T30 (used with 1/4 ratchet) - Torx Socket T50. - 10-mm wrench for battery - Screw driver, Pliers etc. - Piece of 2x4 wood 8 inches long - Zip Ties Warnings: - At appropriate time, you must disconnect the battery ground cable. Read on. Procedures: 1. Move Seat all the way back. 2. Remove "Cosmetic Cover" using T30 bit. On the INNER side, it is tricky with tight clearance, so use a 1/4 ratchet. Then wiggle the plastic cover forward to remove. Now you have exposed the T50 bolts holding the driver seat frame. There are a total of four (4) T50 bolts: two (2) in Front and two (2) in Rear. 3. Remove two (2) T50 Front bolts. Then move the seat all the way Forward. 4. The two (2) T50 Rear bolts are under a plastic cover. Gently pry the plastic cover up and remove it (it just snaps in). 5. Now there are two (2) ways to do this, some people remove the seat from the car completely, but I find this is more work than necessary. I did this with the seat in the car using a piece of 2x4 wood that is 8 inches tall. Since you will move the seat further Back, you will need to undo the "seatbelt height adjustment cable" thingy. Under the seat, there is a cable that connects to the seatbelt height adjustment. The "Fixing Pin" rotates and locks into the "Fixing Clip". Note how it is setup for re-assembly. Simply rotate the "Fixing Pin" to unlock it. Then pull the "Fixing Pin" out. The "Fixing Clip" will come off. Confused? Look at the opposite seat for reference. 6. Now Pull the seat as far back as possible (watch the wiring coming from the floor, don't yank it!). Place the 2x4 wood under the rail to lift the seat up. This allows the T50 socket to go in to remove the Pretensioner. 7. Now, STOP! Go to the trunk and disconnect the Battery Ground Cable (10-mm wrench). 8. In order to remove the old Pretensioner, you need to: - Undo the Velcro - Cut the Zip Tie - Disconnect the 2 connectors (1 for explosive charge and 1 for buckle). They are very easy to disconnect. 9. Now look at the old and new Pretensioner: - Old Pretensioner has "wire chafing", this may be why I have the above SRS codes. - New Pretensioner has Protective Sheathing. - Transfer the Old Plastic Clip to New Pretensioner. - Connect the 2 connectors - Add zip tie. 10. Now, install the New Pretensioner: there are 2 notches (Blue arrows) that must match the tabs on the seat. 11. Re-connect: - "Seatbelt height adjustment cable" thingy. - Battery - Four (4) T50 bolts - Cosmetic covers - Velcro around the base of the buckle 12. Get Carsoft Version 6.50 to turn off Air Bag Light. A few tricks on Carsoft 6.50: http://www.bimmerfest.com/forums/sho...d.php?t=345629 http://www.bimmerfest.com/forums/sho...d.php?t=449937 The bottom line for me: - Laptop Compaq Evo N600C from 2003 with the 9-pin RS232 port - XP Operating System - Install software as instructed: copy from disc to C:\. See attached pdf. - Then copy the 10 "crack" files as instructed. - You must launch Carsoft from C:\cm75f directory. If you launch the software from "Start\All Programs\Carsoft", the software will crash LOL! So, for this part of launching software, do not follow the pdf file. - Go to C:\cm75f directory, find the Carsoft.exe file and launch the software from there. Listen to me, it took me a long time to figure this out!!! - Battery must be fully charged! - Key in Ignition Position II - Erase Air Bag codes. - Go to dash, the Air Bag should be off. That is it, boys and girls!!! Last edited by cn90; 02-19-2012 at 11:07 PM. |
Nice DIY. Didn't know the pretensioner could go wrong. Any idea what went wrong on yours?
Looking for a DIY? Parts? Check this out, it might be your ticket TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint Stable: e39 M54, e53 N62 & Tribby |
In Step #10, I showed the picture of "Chafed Wire" near the Buckle. That was the problem. I cannot understand why a Chafed Wire can do this. The insulation is stripped but the wire is still OK. In theory I could have fixed it by using new wire etc. etc. But since: a. This part is 14 years old and has seen 125K miles with thousands of clicks at the mechanical part (the Buckle). b. My life rides on it during a frontal crash. c. The explosive might have lost its charge (I may be wrong). This "invention" by BMW....I kind of doubt if it makes any big difference in a crash. Many cars do not have this explosive thingy and still pass federal crash tests. My concern was #a above: what if the buckle does not hold during a crash ----> the driver will R.I.P. With the new Buckle, it has a distinct new sound "click" that sounds very good LOL. I am happy with the new "click". |
Anyways, BMW isn't the first one to use the precharge explosive tensioner. I think the French were the first to use it sometime in the 80's - I am 100% positive, I was still in Europe back then and it was a bit of a stir when the news came out. Peugeot, or Renault or maybe Citroen equipped every one of their car with that device. No matter if it was bottom of the line - cheapest model, or top of the line. But never ever heard of these things failing until your post.
Thanks doru,
I just uploaded a document on Pretensioner (see attached pdf) that shows pic of deployed pretensioner. I'd be curious to know: 1. Who first invented the pretensioner idea. Is it 1980s or before that? 2. Does it really help in a crash testing experiment? |
DIY Passenger Seat Emulator
I forgot to post the DIY Passenger Seat Emulator.
Bought the BMW Passenger Airbag Seat Sensor Mat Occupancy Bypass Emulator from ebay seller radzos from Vilnius, Lithuania; $10 + $5 shipping = $15 total. It is a very simple fix: 1. Open Right Rear Door and look behind the Front Passenger Seat. - Cable that goes to SRS Computer is Blue. - The other connector goes to the seat sensor (Red). 2. Unplug the factory connector (squeeze the side tabs and pull) and install this "Emulator". Then zip tie the factory cable so it does not hang down. Done in 5 minutes. Then use appropriate software to erase the SRS dash light. Last edited by cn90; 04-14-2012 at 07:22 PM. |
UPDATE to this whole thing.
Initially, the Carsoft SRS Code was: 24 Linker Sattellit (Sidebag Sensor) / Druck-Fuhler, Beifahrer Airbag 16 Gurt Schalter, Fahrer Airbag 1. I researched and someone told me it was driver's Buckle (aka = Pretensioner). Installed brand-new Buckle. The SRS codes came back. This time I gambled and bypass it using the "Emulator" as mentioned above. 2. The new "Emulator" works great! SRS codes never came back. So if you ever see the above SRS codes in Carsoft, the culprit is the pass seat sensor! PS: Now I have a brand-new Buckle LOL. Considering that my life rides on the Buckle (in the event of a frontal collision), it is not a bad thing to have a brand-new Buckle after 14 years of service! ------------------ This is my understanding: this whole thing about pass seat occupancy sensor is to prevent injury to a child < 40 lbs in a car seat placed in the FRONT seat. Factory Setup: - Adult Passenger FRONT Seat: sensor tells SRS computer that there is an adult there, in a collision with more than 7G deceleration: pass airbag deploys. - No adult: if sensor does not sense anything more than 40 lbs: pass airbag will NOT deploy to prevent potential injury to a child (should there be a child less than 40 lbs there). My mod using "Emulator": - The Emulator simulates condition that there is an adult there. So in a collision, the airbag WILL deploy regardless if there is any pass in the front seat. - So if you install this Emulator, do not place any child seat on the front. Actually, if one searches the internet, even the government strongly recommends a child less than 40 lbs to be placed in the REAR seat, it is much safer there. It does not matter what car you drive, a child less than 40 lbs do NOT belong in the FRONT seat anyway! I am a safety-conscious person and I am confident using this mod. Last edited by cn90; 04-15-2012 at 06:15 AM. |
Wow. I didn't know about this DIY until now ... so ... as I am wont to do ... I just added the following to the existing bestlinks on the topic so that others will find this more easily in the future:
- What is the cheapest usable BMW E39 airbag srs reset/scan tool on the net (1) & a DIY for replacing the driver seat belt buckle pretensioner and the passenger seat emulator (1) & what can cause a BMW E39 SRS airbag light (1) (2) (3) (4) (5) (6) & what scan tools reset the fault (1) (2) (3) (4) (5) & what happens when we disconnect the airbag before the battery or we connect the battery before disconnecting the airbag in seat and window regulator repairs (1) (2) (3) (4) (5) (6) (7) (8) & where to obtain an airbag occupancy sensor bypass unit (1) (2). Note: Here is the cheapest SRS reset tool that I could find to date:
For cross reference, this was posted today in the E38 forums:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 12-15-2012 at 10:47 PM. |
