BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#51
So, all you are doing is coding KOMFORTSCHLIESSUNG FB and FA, changing it them from nicht_aktiv to aktiv, and after you FDL Code and read the ECU, it reverts back to nicht_aktiv? You aren't changing any Werte Values?
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® |
#52
I dont know anything about coding but i lijke what Iam reading. Where can I get this equipment and...do you know if there is anyone in the Atlanta area that will code it. 2011 528i |
#53
The Cheat Sheet says to change the parameter form nicht_aktiv/00 to aktiv/01, aparently after selecting aktiv the werte reverts to 00, I was changing it to 01, the parameter would remain aktiv, but at the time of saving the werte 01 would revert the parameter to nicht_aktiv (not visible until I reopen the module), I just changed the parameter, left the value alone and it worked. The cheat sheet confused me. thanks for your guidance. |
#54
#55
Coding on older models & questions
Question -- I'm brand new to these forums and coding. Just bought a 2012 E93... And was interested in Coding (i.e. Automatic Hardtop convertible movements via keyless comfort keyfob, etc)
I noticed the majority of this forum was dedicated to FXX models. A) Could anyone point me in the direction of some E9X coding manuals, background info, etc. B) Also, I know that BMW is coming out with a revamped iDrive/ConnectedDrive in the next year or two... What are my options to make this part of my current car (i.e. Software Update from BMW, BMW retrofit, Coding, etc) Many apologies-- Really new to this BMW iDrive world-- had an old 2004 325xi that really required no modding... but looking forward to playing catch-up! Thanks! |
#56
Your best bet though is to go here, and read this thread, maybe not all 193 pages, but at least the 1st post. This should get you going in the right direction. http://www.e90post.com/forums/showthread.php?t=451145 The new iDrive is here now, as in 2013 F10's. Your 2012 E93 surely will be able to be retrofitted with the new new CIC Head Unit (HU_NBT), but it will be more complicated and more expensive than what it was to retrofit the previous CIC Head Unit (HU_CIC) into a factory CCC Head Unit vehicle. The new HU_NBT has Combox (TCU & MULF) built into it, so the Unit Cost will be much more, plus the hardware installation will be much more than just swapping the Head Unit as all the Combox wiring in the trunk will need to be relocated to connections on the CIC. On top of that, the FSC Codes in your current CIC will not work with the new CIC. So, you will still need to either buy and import and activate all your FSC Codes into the new Head Unit for Navigation, Voice Recognition, Maps, Sat Radio, BMW Apps, etc., or buy a Hardware Activation Module (CAN Filter) for Navigation and Voice Recognition, and FSC Codes for the others. This by itself will be very expensive. So, is it doable? Sure, if you have a lot of money to throw at it.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® Last edited by shawnsheridan; 09-20-2012 at 09:04 AM. |
#57
So essentially, in addition to actually buying the mod and having it done -- I would have to pay BMW for *new* access to the same services I currently have just with a newest Combox/CIC? Or I could buy this CAN Filter (which may fake them for me, etc?) I need a glossary of terms ha.
Learning slowly.... May just start with modding my ComfortAccess KeyFOB to open/close roof and mirrors automatically .... |
#58
#59
Hi,
My English is poor, so I write with a translator. Could I ask for links to psz 47.4 for PM? In Poland, unfortunately, very hard to get and I need this for my F25. Thank you very much! |
#60
PM Sent.
#61
Hello
Can anyone send me the Links for psz 47.4. Thanks Steve |
#62
PM Sent.
#63
Thank you shawnsheridan
Steve |
#64
Can I get the link as well?
Thanks |
#65
#66
Can someone attach a cheat sheet for coding values Please?
#67
You mean like the one at the bottom of Post #1 here:
http://www.bimmerfest.com/forums/sho...d.php?t=624369
#68
Dont know if this has been brought up but what all could you really do with the cable and software like can you recode a abs module or see codes that are in the car but doesnt trigger the check engine light
#69
You can recode and flash update the firmware on any ECU with E-Sys and the PSdZdata. For reading codes though, you need ISTA/D.
#70
So yes then because im having the hardest time getting my abs flashed due to they are only open m-f close early and all the shops are far away from my location it almost imposible asking a friend who works also and they want to keepn the car the whole day. If I can do this with the suppied information posted I might go this route
#71
Your 528i is an F10 correct? First though, I would just try and VO Code ABS, but I am not sure which ECU specifically as there is no ABS Module by itself. Probably ACSM I guess, or CAS.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® Last edited by shawnsheridan; 09-29-2012 at 11:56 AM. |
#72
Um..wait. 2000, as in 12 years old? E-Sys only works on Fxx Chassis, so for 5 Series that would only be F10's, from Model Year's 2011 forward in the U.S.
If you do not have an F10, you need NCS Expert for Coding and WinKFP for flashing, but unfortunately, I can not help you with that. I don't deal with the older Exx Chassis.
#74
Also, you will need the proper Interface (cable) for an E39. I'm not sure what that is though.
