Old 09-23-2012, 04:01 PM
'07 AlpineX3 '07 AlpineX3 is offline
Mein Auto: 2007 X3
Cold weather starting problems...
Normally my X3 is garaged every night, but when I travel the car gets left outside. Every time I've traveled in the cold and the car is left outside overnight it won't start the next morning. It cranks over fine but just cranks and cranks and cranks until it finally just starts or I floor the gas pedal. Any ideas on what could be? I don't think it's the battery, the starter turns the engine over just fine. Maybe an air/fuel mixture issue, like a sensor or something?
Sent from my GT-P5113 using Bimmer App
Old 09-23-2012, 06:43 PM
Evlengr's Avatar
Evlengr Evlengr is offline
Ukemi - that's how I roll
Mein Auto: 2013 Audi S4 2010 MT MCS
for grins and giggles, do you know how to use a multi-meter to check the voltage? As an 07 it is likely that could be a contributing factor to it.
2013 S4 Loaded (and NO RFT's) Awesome is an understatement
2008 MT X3 RIP you were a faithful sidekick and will be missed.
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
1997 Twin Turbo RX-7
1984 GTI Wolfsburg Edition Neuspeed and more
Old 09-23-2012, 11:33 PM
ducx3 ducx3 is offline
sapper
Mein Auto: 02 WRX, 06 X3
Could be condensation in the fuel lines. I had the same problem once last year. I normally park in the garage. Went snowboarding over the weekend and stayed at a cabin by the resort. A couple of days later when trying to go home in the early morning the car wouldn't start. It had been well below zero over those nights. I bottle of HEET and it started up right away.
There are two different colored bottles of HEET. One is less damaging to seals and such than the other. I don't remember which, but I'd go with the easier stuff. Just keep a bottle in your car and put it into the tank if/when the car doesn't crank after sitting in the cold.
Old 09-26-2012, 11:48 AM
Mein Auto: 2007 X3
Well, the car died just as I was pulling out of my driveway last night. I had it towed to the BMW dealer and apparently it is the eccentric shaft sensor. Apparently there is an oil leak that is coming through the sensor and shorting it out. They want 1452 + tax to fix it (522 parts, 930 labor), he said they have to take the top of the engine apart to fix it. Has anyone else had this repair? Does that sound like a reasonable cost?
Last edited by '07 AlpineX3; 09-26-2012 at 01:58 PM. Reason: wrong part needs to be replaced
Old 09-29-2012, 12:05 PM
Mein Auto: 2007 X3
Got the car back and it runs great. I had them update the transmission software and the difference is unbelievable, drives great. Highly recommend it if your transmission isn't shifting well. Cost me an extra 150, which is a little steep in my opinion, but well worth it.
Old 09-29-2012, 12:53 PM
usaret's Avatar
usaret usaret is offline
Retired
Mein Auto: '09 X3 (MT)
I'm glad they got it all sorted out. I just did a search and it's not an easy job:
http://www.e90post.com/forums/showthread.php?t=697252
