E36 (1991 - 1999)
Old 09-22-2012, 10:30 AM
chillwill13555 chillwill13555 is offline
chillwill
Mein Auto: 318i
Unhappy noise from the rear
help pleaseeeeeeeee i just got an 95 325i convert and everytime i go to take off i hear a banging sound from the rear like if its going to fall off so i cant take off fast it feels like no power in the engine but when i do about 60 mph it sounds ok the guy that sold it for me said it was the differential and i dont know what it is my self .but like i said when i take off its like a loud banging sound then it catches i know the trans is shot cause it goes in to reverse slow like if its standerd lol but its auto. can any body help me pleaseeeeeeee much thanks my fellow bimmer heads.
Old 09-22-2012, 10:38 AM
jonesin's Avatar
jonesin jonesin is online now
The Canadian Prick.
Mein Auto: '96 328is Cosmos
So. To confirm: your rear end sounds like it's going to fall out of your car, so you can no longer accelerate quickly, yet increasing your speed (in an obviously moderate fashion) to 60 mph is considered to be a good idea?
Since you've been a member here awhile, it is safe to assume that you ruled out each of the sounds described in detail in the "Sounds from the rear: Explained" sticky right?
The Evolution of a Lady
“This is the fast lane, folks...and some of us like it here.”
--Hunter S. Thompson
Member of the Non-M Bumper By Choice Club
Old 09-22-2012, 12:51 PM
Poorboysracing's Avatar
Poorboysracing Poorboysracing is offline
I <3 Underpowered BMW's
Send a message via AIM to Poorboysracing
Mein Auto: '00 BMW 528i '68 BMW 1600
ed, you so silly.
those stickies arent there to read
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
Old 09-22-2012, 12:52 PM
Now have you jacked the car up and taken a look as to if anything even remotely looks wrong?
and if your answer is "I dont know what i would be looking at"
then you may as well bring it to a mechanic since this is what will end up happening anyways.
Old 09-23-2012, 03:07 PM
bimmergary328i bimmergary328i is offline
Mein Auto: 323is/328i
Universal joints
Old 09-23-2012, 03:11 PM
Universal joints
Fixing e36 Driveshaft
I'm not a english major...Please forgive me . You absolutely "Can" replace Universal joints. e36 joints From the U joint store or Ebay .. E36. 430-11 is the size for my 98- 323is and 97- 328ic. The trick is tools . Burn the ujoints out with a torch .. alittle at a time (dont go crazy with the heat.) Press them out(normally. )That will leave you with the staked burrs. circle file them down .(Burrs) Emery cloth smooth. (Lightly) press them in. they will need to be centered in . This is where it sounds crazy but works perfect ,get $2.00 in quarters (Not silver) Press those into the yoke ends .(It will center them perfectly). Put a tack weld on outer ear of the yoke , leting the weld puddle down to the quarter.(On the thickest part of the circle)inner ear. Bmw shaft is balanced put marks everywhere so the shaft goes back exactly as it wwas . the front shaft also is splined exactly so put it back exactly on the same slpine . It Works !
Last edited by BimmerGary328i; Today at 04:57 PM.. Reason: PICTURES>>>type bimmergary328i on photobucket
urself.
Old 09-23-2012, 03:35 PM
FenderBender's Avatar
FenderBender FenderBender is online now
Needs Boost
Mein Auto: Red Sled
Diff bolt or bushings
Sent from my ADR6400L using Bimmer App
Turbo Build Here
Parting Out Complete 96 328is
Old 09-25-2012, 01:10 PM
chillwill
Mein Auto: 318i
hey fender bender you say its the diff bolt or bushings cause like i said when i take off in sounds like the rear end bounces one guy said its the diff bushings but i dont know but htanks for the info cuz.
Old 09-25-2012, 04:00 PM
Needs Boost
Mein Auto: Red Sled
Most of the time that's the issue. Put it up in the air and see if you can move the diff by hand. If not, leave it in the air and have a buddy "drive" it while you look to see what's moving.
Turbo Build Here
Old 09-25-2012, 07:08 PM
chillwill
Mein Auto: 318i
thanks fenderbender ill try that thanks cuz and bimmer club around pa that you know of cause de aint got any lol
Old 09-25-2012, 07:36 PM
Needs Boost
Mein Auto: Red Sled
Nah no clubs around me, I wish there were!
Turbo Build Here
Old 09-27-2012, 10:56 PM
chillwill
Mein Auto: 318i
thanks fenderbender we got to start a club then lol
Old 09-28-2012, 08:06 PM
Hectorml07's Avatar
Hectorml07 Hectorml07 is offline
WYKDBMR
Mein Auto: BMW E36
[QUOTE=FenderBender;7091956]Diff bolt or bushings
This ^^ I've already dealt with this a few weeks back and a couple of months ago as well. It can be your diff bolts, mine was the front one (snapped in half and was a pain to remove) it can also be your center support bearing (when this goes bad it makes the driveshaft bang underneath the car) and if you don't fix it will do major damage like mine did (completely destroyed my trans output flange and driveshaft bearing)...lift up your car and inspect underneath ASAP!
WYKDBMR
Old 09-28-2012, 08:20 PM
chrisbmw318i chrisbmw318i is offline
Mein Auto: bmw318i
Unhappy noise in rear over 30mph
Hello I. Have this bmw318i its 1998 manual trans just changed center support bearing was shot but noise still present its like "wow wow wow" whence over 30 mph. Turns do not affect noise there is no clunking sound when taking off everything whitout play help what is it?
Old 09-29-2012, 01:48 PM
Hectorml07's Avatar
WYKDBMR
Mein Auto: BMW E36
Did you align the driveshaft the way it was prior to removing? If you changed the csb and didn't align it the way it was it is not balanced correctly. Also check your flex disk, it sits on the trans output flange. It gets worn out and cracked after years of driving. If there are cracks on it it will start tearing apart.
WYKDBMR
