Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E39 M5 (1998-2003)
E39 M5 (1998-2003)
Old 09-07-2012, 05:43 PM
chirojoe chirojoe is offline
Mein Auto: 5281
fuse keeps blowing
Anybody have a problem with the fuse that goes to the drivers seat and steering wheel adjustment switches? Mine keeps blowing. I think it is the number 13 fuse. I am guessing there is a short because as I am putting in the new fuse I get a faint spark.
Old 09-29-2012, 09:51 PM
///fast5 ///fast5 is offline
Mein Auto: e39 Bmw M5, e46 Bmw 330i
Check your wires under the seat like connectors make sure they in proper position and no open circuit and make sure your seat motors works properly if the motor is goinf bad, it can cause a internal short and cause your fuse blown.
Old 10-06-2012, 10:10 AM
ard ard is offline
Resident Curmudgeon
Does it blow when you turn on the heated seats? Or does it blow with them off?
Setat heat element fails in a way that days more current.... If the fuse only blows when you turn on the heater, that's it.
