Old 09-14-2012, 10:37 AM
MalibuMafiaV's Avatar
L4P
I would NEVER put an 8-pound `wheel in a street car....that`s a "Track Only" piece....
Agreed. That's just WAY to aggresive for s daily driven car. It's already to much w/ my 16 pound flywheel. But since I don't drive my bimmer daily I don't mind it as much.
http://www.luxury4play.com
2004 Maserati M128 GT
Old 09-14-2012, 11:43 AM
Fast Bob's Avatar
Keeping it surreal
Originally Posted by MalibuMafiaV View Post
But since I don't drink my bimmer daily I don't mind it as much.
You sure about the "drinking" part there, Skippy ?
The road goes ever onward....
(R.I.P. Jever)
*Please support the Wounded Warrior Project*
Old 09-14-2012, 11:46 AM
L4P
drive* shows what I wana go do right now. To bad I have 4 hours left of work.
Old 09-14-2012, 02:39 PM
numindast numindast is offline
Properly chastised re: Xi
Mein Auto: 2005 325xi
I'm a member of the uninitiated crowd, what makes an 8-lb flywheel "off road use only" as you said earlier? What does having an 8 lb 'wheel do to the driving experience?
As a slushbox owner I'm obviously not planning to do any such thing but I am still curious.
...the last thing you need is unpredictable rubber
Old 09-14-2012, 02:43 PM
L4P
You'd have to keep throttling the car for it not to stall, it'll make a loud chattering sound when in N or holding in the clutch, it would make the clutch insanely stiff. Not for daily driving lol.
Old 09-14-2012, 03:10 PM
SPDSKTR SPDSKTR is online now
I'm a DlCK! So what?
Mein Auto: Hates smolck.
Find my thread on the entertaining read about Harry and Larry and the lightweight flywheel. Good stuff.
Sent from the Bamavarian Nexus.
Old 09-15-2012, 10:24 PM
Fast Bob's Avatar
Keeping it surreal
A flywheel serves a couple of purposes....it acts as a big vibration damper, smoothing out engine pulses (not a BFD on BMW`s I6s, which have excellent primary balance). It also stores kinetic (rotational) energy, which make it easier to get the car under way from a standing start (a slightly heavier `wheel is beneficial here). When a manual trans is idling in neutral, all the shafts & gears are sort of banging around inside the trans case, because nothing is engaged or under load, so the (heavier) flywheel also dampens any potential rattling from the trans. An 8-lb. `wheel doesn`t offer much in the way of damping or centrifugal energy, so you will have more driveline noise, and the car will be harder to launch smoothly. Performance always involves a trade-off of some sort....a heavier flywheel (24 lbs. for the stock unit) gives acceptable levels of performance for non-enthusiasts, but is sluggish to react to change (remember Newton`s Third Law ?). A 16-lb. solid billet wheel is probably the best compromise....it allows much faster rev capability, while providing enough inertial energy that the car isn`t a royal pain in the ass in everyday driving. And, the solid billet `wheel/sprung clutch combo offers a substantial improvement in engagement feel and predictability compared to the stock DMF/SAC setup.
Hope that was clear enough for ya....
(R.I.P. Jever)
Old 09-26-2012, 10:58 PM
anton2718 anton2718 is offline
Mein Auto: 01 325i
so i got the F1 racing stage 1 clutch today, gonna try to put it in saturday, whats your guys opinion on breaking it in? should i limit my revs to a certain rpm for the first fews hundred miles? and how long till i can drop clutch and floor it, my current clutch is pretty much as bad as it gets, if i floor it, no matter what gear the rpms redline but the car barely accelerates, i miss my bimmer!! i want to feel that super fast 0-60 in 7 seconds again haha
Old 09-29-2012, 11:58 PM
Mein Auto: 01 325i
my tranny wont go back into place, why??
Old 09-30-2012, 08:23 AM
Fast Bob's Avatar
Keeping it surreal
Did you use the splined alignment tool (that comes with the kit) during assembly to ensure that everything was lined up correctly ? Did you replace the pilot bushing ?
(R.I.P. Jever)
Old 09-30-2012, 08:35 AM
Mein Auto: 01 325i
yep, did all the above, i pushed it in all but an inch which is where it stopped, but i barely got it there
Old 09-30-2012, 09:25 AM
Fast Bob's Avatar
Keeping it surreal
When you try to put the trans in, does the input shaft stop at the same place the alignment spline did ? Are you sure the throwout bearing is not getting hung up somehow ?
(R.I.P. Jever)
Old 09-30-2012, 09:28 AM
Mein Auto: 01 325i
im not sure, it might be, also there was a cover thing on the pressure plate with a hex insert, i took that out, was i supposed to? the old one didnt have it and it doesnt seem like it would fit if i didnt, what was that for?
Old 10-03-2012, 02:12 PM
Mein Auto: 01 325i
great success!!
Old 10-03-2012, 05:10 PM
Fast Bob's Avatar
Keeping it surreal
great success!!
Glad to hear this. What was the problem ?
(R.I.P. Jever)
Old 10-03-2012, 05:21 PM
Mein Auto: 01 325i
honestly, im not even sure, i took the transmission back out and put it in again and everything came together
