Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 09-28-2012, 01:30 AM
FOXDESERTRATS FOXDESERTRATS is offline
Mein Auto: 96 740il&98 740i
Dash lights p-r-n-d-4-3-2
Dash lights p-r-n-d-4-3-2 light up for about 3 seconds at start up and thats it no more lights radio dont work and temp gauge is pegged in the red also im getting a po600 code a po116 temp code and a 1747 can- bus code please help thank you also why cant i put a 5hp30 in place of a 5hp24 whats the deal with the wiring drive shaft lenth no problem but what the wiring issue thank you
Old 09-29-2012, 04:12 PM
gotrice415 gotrice415 is offline
Mein Auto: M3, 335Ci, X5d, 750i
Check the fuses within the Ebox. Once you open the Ebox you'll find a cluster of fuses. I'm sure you'll find one of them blown. If you find a blown fuse, remove the thermostat connector and make sure it's not melted. If it is, repair it.
Good luck!
Old 09-30-2012, 06:49 AM
joyism5's Avatar
joyism5 joyism5 is offline
Mein Auto: '99 740IL, K75RT
Punctuation is very important, if you want to be understood.
The 5hp30 might have a different transmission control module VS the 5hp24. It's not about the wiring only. That module needs to be aligned with engine control module, EWS, ABS, etc. If you have lite the gear indicator only a couple seconds, you have a power source issue or a transmission control module/can bus issue.
JOY = BMW
HTML code is Off
