E34 (1989 - 1995)
Old 06-01-2012, 01:00 AM
xxjamesxx xxjamesxx is offline
Mein Auto: 1994 bmw 530i
changed waterpump/engine wont start
Okkay. I have a 1994 bmw 530i and about 2 months ago the waterpump went out, so the car just sat there tell about yesterday, when I got a new waterpump, I replaced it with a brand new one, and it would not start, it sounds like it wants to start but Doesn't turn over, the starter and fuel pump are working. I. Was told that I might have to reset the engine. But idk.. anybody have any ideal. O and when the waterpump went out it still started....
Old 06-01-2012, 06:50 AM
Monsignor's Avatar
BMW CCA Memeber #445389
Mein Auto: Sig
Reset the engine?! i'd love to know what that means but to me it sounds like its cranking but not firing. This is exactly what happens when the crankshaft position sensor is failed, improperly installed, or not installed at all. double check the CPS to make sure it is installed, if so, check the resistance on it.
And are you sure about the Fuel pump? when you turn the key to accessories, you should hear a light humming coming from the right side of your trunk. if not, check the FP relay as that is where my No-start issue was... Good luck
EDIT: also i see this is your first post. Welcome to the B'fest E34 crew! the happiest forum on the planet
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 06-01-2012, 08:33 AM
1995i540's Avatar
1995i540 1995i540 is offline
Founder @ Maintenr
Mein Auto: 1995 540I/6
Depleted battery or no gas.
///////////////////////////////////////////// E34 Addicts
Founder @ Maintenr. Take control of your vehicle maintenance.
Old 06-01-2012, 11:55 AM
I have gas and the I had the battery hooked up to the battery charger.. umm and how do I check the resistant on the crankshaft sensor? And thanx 95 e34
Old 06-01-2012, 01:52 PM
Monsignor's Avatar
Mein Auto: Sig
with a multimeter. download a bentley manual for the car. it will tell you how to check the CPS. Although, the voltage in the bentley is a typo, it should be 540 OHM not the 1140+ in the manual...
Find the CPS, its on the front of the car, under the radiator hose on the passenger side pointing down at the harmonic balancer. The wire to it runs from under the intake manifold, along the front near the VANOS and down to the sensor. Unplug at the connection under the intake manifold and thats where you'll check it.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 06-01-2012, 03:03 PM
Allright thanks..
Old 06-01-2012, 10:35 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
I think that enough /dirt grease can lodge under the cps to disrupt the pulse of the sensor. Also check that the wire is not damaged. Another idea is possiable that car is flooded.
Old 06-01-2012, 10:53 PM
The car was flooded after a few trys, I took the plugs out and cleaned them off. Then let it sat for a couple hrs. And then tryed.. but im jus goin to see. If theres somethng under the cps
Old 06-01-2012, 11:29 PM
1995i540's Avatar
Founder @ Maintenr
Doubt it, there is 0.02mm clearance that would not affect magnetic reader. Just test Ohm and move on.
Try starting the car without MAF, and do fuel DELIVERY and pressure holding test.
Old 06-02-2012, 10:54 AM
luckydog's Avatar
Oh well mine after removing it was caked at the face of the sensor.
Old 06-02-2012, 10:59 AM
luckydog's Avatar
Oh excellent nothing serious .You may be in line for a fuel filter soon.
Old 06-02-2012, 03:45 PM
1995i540's Avatar
Founder @ Maintenr
Mine too they get really dirty
Old 07-04-2012, 05:49 PM
Does the crank shaft need to lined up correctly with the crank shaft sensor? If so I believe thats my problem, and what would I need to do?
Old 07-04-2012, 08:36 PM
Mein Auto: 1989 525i M20B25
Don't worry about that. As long as its tightly fastened to its bracket.
How is the resistance?
From the bentley, but the information is WRONG.
M50/M60 engines should also have a 540 +- 10% ohm reading.
Old 09-02-2012, 04:41 AM
I changed my crankshaft sensor and still wont start.. iz there any way to figure out why it wont start?
Old 09-02-2012, 09:32 AM
Gotta run through these:
THE DEFINITIVE "NO START" trouble-shoot instructions - Bimmerforums - The Ultimate BMW Forum
Old 09-02-2012, 11:15 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
thats bold haha
E30 above Sold
Last updated 2nd January 2014
Old 09-04-2012, 07:40 PM
TemporarySanity's Avatar
TemporarySanity TemporarySanity is offline
Mein Auto: 02 530, 02 540, 07 525
It's not getting ignition if it floods with fuel so the timing could be off. The CPS controls timing but you say you changed it so pull a plug and see if there is spark.
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot.
Old 09-06-2012, 12:22 AM
BMWFatherFigure's Avatar
Old School
If you are getting a spark and fuel either the CPS is in the wrong place (same casting used on various models so two mounting points), or plug leads are on wrong plugs or wires on wromg injectors. We've all made these mistakes....once.....
Old 09-06-2012, 11:26 AM
ThoreauHD ThoreauHD is offline
Mein Auto: 02/1994 530i 8cylinder
Why have none of you laid off rocket scientists told him to check the fking error codes? Do a stomp test first. Stop flinging feces at a wall like howler monkeys. He's going to go broke before he fixes the problem.
Old 09-06-2012, 06:34 PM
Josh429er Josh429er is offline
Mein Auto: 1989 BMW 535i
That's hilarious, but it probably doesn't have a code. The car hasn't ran at all to know theres an issue. Your advise is as pointless as the ideas you complained about.
2003 GMC Sierra SLT 2500HD CC/SB
Old 09-06-2012, 09:39 PM
I didn't think it would be a fuel pump. Not saying I know the issue, because i don't. Now when it runs does it miss, does it run crappy, or like a champ? When it dies is like it run worse and worse until it dies, you know gradually die quickly if that makes sense, or does it just die, like BAM It's dead, like you turned the key off. You have to be very specific and detail oriented if you wanna figure it out.
Have you checked plugs after it dies? Are they wet?
Can you prime the fuel system?(hear the pump running on key on accesory)
What's the batteries voltage?
Old 09-30-2012, 12:50 PM
frankies525 frankies525 is offline
Mein Auto: 1995 525i
battery
disconnect battery
Old 09-30-2012, 01:52 PM
Big-t34 Big-t34 is offline
Mein Auto: E34 525i 95'
How bout u change the crank sensor?
Old 09-30-2012, 02:36 PM
Banned
Mein Auto: car
Fuel pump, fuel pump relay, fuel pump fuse, crank sensor...these are the likely suspects.
There's also the dme relay, starter, dme, battery.
Methinks the OP is not motivated to get his car on the road...taking too long to get things fixed, such as 2 months for a water pump, and 3 months for a no start issue....
