Old 09-20-2006, 03:15 PM
ChileBeem's Avatar
ChileBeem ChileBeem is offline
Mein Auto: 2002 540ia MSport Tsilver
Fill up my tank => puddle of gas on floor!!!
Hey guys: ideas please before I rip the whole tank out.
I have noticed a light gas smell after long drives, but no wet patches on floor or tank bottom. I fill up (feeling rich!) on Friday, and the guy really fills the tank several clicks past the first pump click (I know, but was too late). There is a splash and gas, about 1/8 gal. I guess, falls very fast to floor. Looks like from front upper of tank.
Any ideas?
Thanks...
2002 540ia MSport Euro
Factory fitted goodies:
Titanium Silver, Blk interior/headliner
MSport option 337, body, seats, s.wheel, shadowline, trim
MSport op. 705, st II suspension
MSport op. 204, 3.15 dif/ high stall tq converter
Premium Sound with DSP + Sub
Type 66 wheels 245f 265b
Old 09-20-2006, 03:40 PM
BillP BillP is offline
Mein Auto: Cars
Any ideas?
Thanks...
Define "floor" - if you mean "ground", that is normal, though your gas station attendant is an idiot. Where else do you want excess fuel to go? There is a spill pipe that runs along the back of the rear right tire.
If by "floor" you mean the interior of the car, that is bizarre and probably dangerous.
Bill
'00 540iA/Sport, Anthracite/Black - Euro Delivery in Spring 2000
'06 Honda S2000, Black/Black (my go-kart) - GONE
'03 Z4 3.0 6-speed/Sport, Sterling Gray/Black - GONE
'71 2002 Green/Black - GONE
Old 09-20-2006, 03:56 PM
ChileBeem's Avatar
ok, sorry Bill.
On the concrete gas station floor. The spill ran down the tank to ground. If there was a overfill from filling process, would it not end up at gas station attedants feet? ie right side, rather than left?
Thanks for advice!
Old 09-20-2006, 06:30 PM
Mein Auto: Cars
It is possible that the overflow pipe/tube isn't extending through the wheel liner and is then causing the fuel to run along the bottom of the car before it finally hits the ground. Get under the car and look.
Bill
Old 09-20-2006, 08:24 PM
BMWtech75 BMWtech75 is offline
Mein Auto: IS300
Any ideas?
Thanks...
Remove your rear seat bottom and insulation then take a look to see if the area of the sending unit is wet. If so, possibly a bad gasket.
Old 09-20-2006, 08:43 PM
Redshift's Avatar
Redshift Redshift is offline
Bimmerholic
Mein Auto: a BMW of course!
Had this problem with my track car. The side-to-side vent tube was not properly seated and had to be fixed. It's not a pressurized line, so not immediate harm/danger, but should be inspected anyway. The way to check it is to remove your rear seat bottom, pull back the carpet and sound deadening material, and remove the round gas tank access panel.
Brian
Coming soon: 2003 M5iT Sapphire Black (E39) - 2001 M5 LeMans Blue (E39) - 2002 330Cic Orient Blue (E46) - 2010 BMW K1300GT - 2002 Suzuki DR650
For Sale:
*** Parting out entire 2003 E39 M5 *** - TONS OF PARTS AVAILABLE
Old 09-21-2006, 08:01 AM
KTrostel KTrostel is offline
Mein Auto: 1998 540i and 2002 M5
I had the same problem. Car had a faint smell of gas and would drip fuel onto the ground after a full fill up. Realigned the sending unit gasket and the problem went away. As BMWtech said, it is quite easy to check.
Old 04-20-2012, 12:01 PM
SamReyes91 SamReyes91 is offline
Mein Auto: BMW 325i with iS Con
bump any ne info on this??
Old 04-20-2012, 01:53 PM
JimLev JimLev is offline
Mein Auto: 540/6, Tribeca
It's possible the top of the connecting hose to the tank behind the wheel well liner has a split in it, or one of the clamps is loose.
Maybe the fuel ran down the liner toward the rear of the car.
If your really want to know you will need to pull the wheel and liner, put the wheel back on, go to the gas station and fill'er up.
Old 04-21-2012, 07:00 PM
gtxragtop's Avatar
gtxragtop gtxragtop is offline
Mein Auto: 2003 530IA
+1 Mine seems to be seeping from this hose. I get a faint smell only, nothing on the ground. Pulled wheel liner (which is a pain) and could see that there was brownish stains around the area where the rubber hose clamps to the tubes from filler and down to tank. I tightened the clamps figuring... All set now. Well, better but not fixed. This started late last year.
Ever wonder why 5 series electrical issues are common and complicated.. Spend time here and you will understand why. http://www.bmw-planet.com/diagrams/r...9new/index.htm
Old 09-30-2012, 06:05 PM
gtxragtop's Avatar
Found the problem. Removed rear seat and fuel pump access cover. First thing I see is a mouse nest loaded with grass other debris and acorns. The area was wet with gas. It turns out the lovely mice chewed on the small black line which I assume is the vent line. The chewing left a pinhole that peed fuel when I filled the tank. I cut out the bad section and used 1/4" fuel line with fuel line hose clamps and problem is solved. I hate mice
Old 10-03-2012, 08:06 AM
The cute mice have given us a nice update for this thread:
- Does spilled gasoline go into the charcoal canister (1)
Old 10-03-2012, 09:56 AM
Fudman's Avatar
Fudman Fudman is online now
I hate mice
I hate those meeses to pieces!
Similar Threads
Can't fill the gas tank all the way up kcoetzee E90/E91/E92/E93 (2006 - 2013) 20 09-13-2013 05:37 AM
AndyM please read post below on gas tank and advise 01silber E36/7 Z3 (1996-2002) 0 11-10-2002 11:23 PM
Found little pin in my Gas tank...WHAT? 330Guy 3 Series & 4 Series 5 05-24-2002 09:20 PM
my gas tank door doesn't close!!! punkman79 3 Series & 4 Series 4 05-05-2002 06:21 AM
Got 480 miles on a tank of gas! alee General BMW Questions 18 12-27-2001 02:51 PM
