Old 09-18-2012, 10:48 AM
rdeleon11 rdeleon11 is offline
Mein Auto: 2001 540I
E39 Power steering hose leak
Greetings,
I need to replace the high pressure power steering hose that goes from the pump to the Box. In the diagram below its number 5 part # 32411093926. Its a for 2001 540I Manual. If any one can provide DIY info it would be highly appreciated. Thx
How difficult is it to replace?...My main concern is how hard is it to get to the back connection?
I found two great post on the replacement steps:
http://forums.bimmerforums.com/forum....php?t=1160904
Old 09-18-2012, 08:28 PM
Type in /power steering hose F3 into the bestlinks and you'll find that DIY you found, and lots more, in about two seconds!
- Power steering fluid (1) (2) & power steering fluid flush DIYs (1) (2) (3) (4) & volumes (1) & how to clean the power steering fluid reservoir internal filter (1) (2) & how to replace the cap o-ring (1) (2) & why you want to fix the power steering hose drip onto the alternator (1) (2) (3) & how to debug PSP power steering pump noises (1) (2) (3) or steering rack noises (1) & a nice power steering pump autopsy photo (1) & how to flush cloudy ATF fluid (1) (2) (3) (4) (5) & what PS fluid to use (1) (2-pdf) (3-volume) & what volume is needed to buy (1) & DIYs to replace the power steering hoses (1) (2) (3) (4) (5) & how to debug common BMW power steering issues (1) and noises (1) (2) (3) or steering rack noises (1)
Old 09-18-2012, 09:45 PM
Thanks Bluebee. Very helpful postings, Appreciate you help!
Old 09-19-2012, 11:04 AM
Bwood1 Bwood1 is offline
Mein Auto: 1999 528i, 2002 540i
I did mine when the valve cover was off (to fix the cam chains) and it was much easier to get to that back banjo bolt.
Old 09-30-2012, 08:53 PM
Completed this repair today...the rear connection was hard to get too, after you remove the front screw and pull the hose upwards you easily see the back connection, the only way I was able to get it out was by placing a jack and lifting the engine a little less then an inch, this gave me enough room to take it out. While its not a complicated job, it sure was a pain to remove and replace the rear screw.
Old 09-30-2012, 08:58 PM
Jason5driver's Avatar
Jason5driver Jason5driver is online now
It is MUCH easier if you were to remove the alternator, and get it out of the way...
Using a smaller box-end wrench was key to removing the large jet-valve-bolt (22mm I think...).
The job is VERY messy, and ATF can get everywhere.
Not really fun...
Thanks!
Jason
