Old 10-01-2012, 07:09 PM
dodell66 dodell66 is offline
Mein Auto: 2014 BMW 435xi M-Sport
Discrepancy In Oil Level Readings
The other day I checked my engine's oil level. First I checked it using the OBC that is accessed via the turn signal stalk. Much to my surprise the reading said 3/4 full. Then I checked it using the iDrive. The iDrive says the oil level is full. I tend to believe my iDrive because my car has never burned oil and there is no oil on the floor in my garage or on the garage floor at work.
Has anybody ever had this happen to them?
Currently Drive: 2014 BMW 435xi M-Sport | Previously Owned: 2013 BMW 528i / 2008 BMW 335i Sedan
Old 10-01-2012, 07:28 PM
DSXMachina's Avatar
Bimmerdex 7.4!
By any chance did you then go back and check using the stalk immediately after using the iDrive? They both get their signal from the same source...
Old 10-01-2012, 07:32 PM
I did. There was no change. I have subsequently checked both of them again and I still get 3/4 full via the stalk and full via the iDrive.
Old 10-01-2012, 07:37 PM
Leekay07 Leekay07 is offline
Mein Auto: MY12 550I,MY09 X5.
the stalk always has space at the end of the gauge. full is not right at the end of the bar.
Old 10-01-2012, 07:41 PM
I've seen the stalk read full before. The gauge now clearly reads 3/4 full.
Old 10-01-2012, 07:58 PM
wait till the car tells you to add a quart
Old 10-01-2012, 08:05 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Either way, no worries. You are well into the normal range, and still have at least 3/4 of a quart MORE than the minimum mark. There is absolutely no mechanical/hydraulic benefit to having the oil nailed on the full line.
Old 10-02-2012, 07:50 PM
Thank you!
Old 10-02-2012, 07:54 PM
joeveto joeveto is offline
Mein Auto: 328
I just recently had this happen. I didn't add oil, because I was approaching my oil change. I find that my car takes 6.5 quarts to read full (capacity is 7). At no point did any warning come on, so I'm not worried about it.
