E90/E91/E92/E93 (2006 - 2013)
Discrepancy In Oil Level Readings
The other day I checked my engine's oil level. First I checked it using the OBC that is accessed via the turn signal stalk. Much to my surprise the reading said 3/4 full. Then I checked it using the iDrive. The iDrive says the oil level is full. I tend to believe my iDrive because my car has never burned oil and there is no oil on the floor in my garage or on the garage floor at work.
Has anybody ever had this happen to them?
European Delivery: 3/10/2008 / Redelivery: 5/14/2008 - 2008 BMW 335i Sedan, Sparkling Graphite Metallic, Terra Leather, Dark Burl Walnut Wood, Sport, Premium, Cold Weather, Steptronic w/Paddle Shifters, Satellite, HD Radio, Comfort Access, PDC. Member: BMW CCA |
I did. There was no change. I have subsequently checked both of them again and I still get 3/4 full via the stalk and full via the iDrive.
the stalk always has space at the end of the gauge. full is not right at the end of the bar.
I've seen the stalk read full before. The gauge now clearly reads 3/4 full.
wait till the car tells you to add a quart
Either way, no worries. You are well into the normal range, and still have at least 3/4 of a quart MORE than the minimum mark. There is absolutely no mechanical/hydraulic benefit to having the oil nailed on the full line.
Thank you!
I just recently had this happen. I didn't add oil, because I was approaching my oil change. I find that my car takes 6.5 quarts to read full (capacity is 7). At no point did any warning come on, so I'm not worried about it.
