Fuel smell in boot
Hi all,
Can anyone help, or suggest. I have 1999 2.8 z3 which runs great. Lately when opening the boot, you get a waft of fuel vapours.Nothing in the car whilst driving. I've check for leaks and there's none visible. Has anyone any suggestions Cheers |
The fuel tank is located behind the pass seat under the carpet.... might be leaking
The key phrase is that there are no leaks visible.
There is an extensive network of vapor recovery tubes that run on top of the fuel tank and those have been known to be a problem. Also, if there has been any aftermarket audio work done it isn't uncommon to see an installer actually drill into the fuel tank while drilling holes for screws. Unfortunately, to make a complete evaluation of fuel vapors coming from that area the best way is to break down and pull the fuel tank for inspection of the tank and associated lines. |
Cheers guys for the suggestions
The smell is more like a vapor, than a leak.. I will look into it and let you know how I get on. Thanks for the time |
Hi,
Just letting you know the update on my car. Had it looked at, turned out to be the drivers side fuel tank strap was loose. Cheap replace £13 from dealer. Thanks again for the input. Great forum Lee |
A very cool tool, and kudos to whoever thought it up__though I suspect it's an age-old practice, as I can remember guys in the 60s exhaling their cigarette smoke into the vacuum line to see if the distributor advance diaphragm was cracking. Quote:
If you didn't get a check engine light, resulting from a system breach, then there shouldn't have been any smell. I think you're just psychic and that's what led you to getting the loose fuel tank strap taken care of...
![]() Randy Forbes 1957 Austin-Healey 100/6 Wine Red 1961 McCulloch R1 go-kart Screaming Yellow 1999///M Rdstr Cosmos Black 2001///M Rdstr Steel Gray 2011 X5 35i Sport Deep Sea Blue/Cinnamon |
I didn't get no check engine light.
I asked my partner to check smell in boot, she seemed to think it was a damp musky smell. Maybe her sense of smell is differ to mine..ha. So if I was to leave the filler cap off and start engine |
The check engine light would come on ?
