E82 / E88 1 Series (2008 - 2013)
BMWs throw back to the iconic 2002, with a renewed form and function. The smallest car in BMW's line up but still packs a punch. Available in coupe or convertible, powered by either an inline 6 in the 128 or the twin turbo rocket sled 135. |
135i - Switching to different tire type/brand in rear only - Bad Idea?
An unscrupulous nail jumped into the left rear tire of my 135i. Obviously, it needs a new tire.
I'm still on the OEM run-flat Bridgestone Potenza tires. I've been thinking of switching to the Michelin PSS. However, the front tires still have plenty of tread life left. If I just switched out the two rear tires to the non run-flat PSS, would that be advisable? Obviously, I'd like to replace all four tires, but that seems like a waste of money with so much life left on the front tires. What's the going opinion/best practice? Thanks!! Last edited by chronoton7; 10-01-2012 at 08:13 AM. Reason: Changing thread title |
So, it would be run-flats in the front and non-run flats in the rear? I wouldn't; if for no other reason than because tires are so crucial to suspension and good handling...I think you would adversely affect your car's balance by having stiffer sidewalls up front and more flexible sidewalls at the rear. Either replace the one OEM rear with another run-flat, or replace all 4 tires with whatever you want...if you're looking to save a few bucks, TOYO makes a quite decent performance tire.
2012 Mini CooperS convertible 2008 135i Convertible - Sparkling Graphite Metallic Prior BMWs: `05 645CiC; `07 650i; `08 M6 convertible; `11 750ix MSport 2004 GX470 |
I definitely want to eventually switch to all PSS tires, I just hate replacing the front tires with so much life left on them. I am admittedly frugal. :-) It sounds like I'd do better with getting another OEM tire, waiting for the rest of the tires to wear out, then replacing all at once with the PSS. Is that the safer/better performing way to go?
:I used about 57% of the life of the fronts (or maybe 66% in BMW's eyes?), or I could say I'm "throwing away" 43%. Then, I then figured out what 43% of my most desired tire would be (and not the OEMs, because that's not what I'm buying; twisted logic? yeah maybe sure whatever), would be $181 today. THEN, I tried to put $181 (or whatever it really was at the time) in perspective. Yes, it's nothing to sneeze at. But- it is arguably paltry compared to the figures that many people easily drop; $1,000 on an exhaust, $1,000 on a bumper, $1,000 on a tune, or what have you. THEN*, I thought about how if there was *one* single place where your dollar went the very, very, very furthest for performance vs value, yep, it would be the tires. If there was JUST ONE place where you could feel alright about splurging, yep, it would be the tires. So for discussion's sake, let's say your old fronts are identical to my old fronts. $181 is the difference between questionable(?), compromised(?) driving, and having the best possible summer tires available in the world for your wheels, on all 4 corners, fresh, brand new, full 10/32" ready to go for the winter. IMO, the biggest, hugest difference to me was in the wet. I realize the tread depth plays an enormous role, but I still stand by that. THEN**, there was a promo going on at the time, some free cash card, was it $70? If you replace rears, mismatched, I imagine you will increase your oversteer, not just with fresh rubber, but because they just grip way more than the OEMs. FWIW, I am not 100% convinced that mismatching front vs rear is necessarily a bad thing, maybe like 75% convinced. I had a friend who had done so, put on some Hankooks on the rear of his leased Z4 35is, I haven't heard any complaints. |
