Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E60 (2004 - 2010)
E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki
Old 10-02-2012, 10:01 AM
Oceans10's Avatar
Oceans10 Oceans10 is offline
Mein Auto: BMW 535i + 535XI wagon
Headlight, Xenon bulb replacement
Just replaced a burned out headlight xenon bulb.
BMW wanted almost $400 to replace it ($240 for part, plus $130 for an hour of labor, plus tax).
Instead I went for Option B and bought the bulb for $40 on ebay. The oem bulb is an Osram D1S with 4150k brightness.
I bought a DOT stamped Philips XenStart D1S Xenon from
oemxenonparts, 4300k, and it matches perfectly with the Osram. No need to replace both.
Installation required removing 2 top screws and 2 at the bottom, you need an extension to reach down. The headlight unit then slides forward and you wriggle it loose and tilt out of the cavity. A plastic cover on the back drops down to expose the bulb. turn it 1/4 turn and remove. Unplug the wire, take off the neckless type bracket, like a collar, and clip onto new bulb. Install.
Whole procedure took 20-30 minutes but this was a first time experience and I was figuring it out on the fly.
The 2 lower screws are tricky to refasten. You need an 8mm socket with magnet at bottom to hold the screw, or a nut driver with long shaft, 6 inches or so. I stuffed a little duct tape inside to make it sticky. Did the job.
Styling: M5 body kit, M5 trunk spoiler, LED Angel Eyes, HID fogs, LED side markers, Jehnert Flatline speakers, Mobridge M1000 DA2 prepro, Zapco Z8 DSP, Zapco Z-150.6 amp, iDock on dash
Performance: JB4/G5 ISO flashed on Cobb, Meth Injection, AR Downpipes, ER FMIC and Charge Pipe, DCI, Walbro LPFP, RB turbos. H&R Sport springs/Koni FSD shocks.
Old 10-02-2012, 10:37 AM
F1.tifosi's Avatar
F1.tifosi F1.tifosi is online now
Bimmer Craze
Send a message via Yahoo to F1.tifosi
Mein Auto: BMW 535i Sport, 08 Accord
Oceans, just wanted to know why you did not go with 6000K which is safe and many people have been using it already..
Jet Black | LCSW | DP WT | ZCW | ZPP | ZSP | 261 | 2TB | 322 | 415 | 416 | 609 | 610 | 620 | 677 | 6FL | 6UH |Front/Rear Cameras | Escort 9500ix |
Performance-Cobb Stg2+FMIC ST Agg | Injen Intake | BMS OCC | ER anodized FMIC |AR DP Catted |TIAL Q BOV | ER Charge pipe | Spacers (F 12mm/ R 18mm)
Cosmetic-32w Cree LED AE | Xenon HID Fog Bulbs | M5 trunk & Roof spoiler rear | XENON white Emblem LED BG Light | LED Side Marker | M5 bumper | Hamann LP | License & Interior LED lights| Tinted glass |
Old 10-02-2012, 10:40 AM
Oceans10's Avatar
I wanted to color match it to the stock bulb. Only replaced one, not the pair.
Old 10-02-2012, 10:45 AM
F1.tifosi's Avatar
Bimmer Craze
Got it.. Cool..
How long did your first bulb stay?
Old 10-02-2012, 08:12 PM
booyaazaa's Avatar
booyaazaa booyaazaa is online now
Mein Auto: '09 AW 535i
Hey I just PM'd you back, sorry for the lag. Glad to see you go it figured out. Those damn bottom screws can be a pain if they drop into the bumper which I've done before.
2009 AW 535i
-Sport, Premium Package, and Comfort Access
-20" Forgestar F14 Black Gloss, Cobb PTF E30 map, KW V2 CO's, Remus Sport Exhaust, BMS DCI, RPI Scoop, Full Front 3M PPF, 35% tint all-around, Orion V4's, Bruce v6.1L cables, LED interior lights, WeissLicht License Plate LED, Trinity Smoked LED side markers, Bimmian Smoked Reflectors, OEM black gloss grills, and Invisibulb turn bulbs.
Old 10-04-2012, 02:03 AM
davethewheel davethewheel is offline
Mein Auto: "06 BMW 525i
+1 on that!
Sent from my MB855 using Bimmer App
Old 10-04-2012, 05:14 PM
SBC530I SBC530I is offline
Mein Auto: '07 530i, '04 Silverrado
For future reference, just loosen the bottom bolts as the brackets on my 2007 530i are slotted, hence bottom bolts did not need to be removed. Also, top bolts use a #30 torx while bottom bolts use a #20 torx.
