Old 10-02-2012, 01:19 PM
moonbeamer moonbeamer is offline
Mein Auto: bmw z3 1998
Question Z3 car wont start
moonbeamer here...New to Bimmerfest .
I drive a Z3 1998 and last night it wouldnt start... put the battery onto charge.
This morning it at least clicked ...and lights came on...but nothing else.
tried jumper cables and nothing....only lights.
Now what ??
please help!!!!
Old 10-02-2012, 07:25 PM
Can somebody pleeeeease help ... Just replaced battery... Still no start up!!
Dashlights come on but it doesn't even click when I turn ignition key
Old 10-02-2012, 09:19 PM
AndrewZ's Avatar
AndrewZ AndrewZ is offline
Super Moderator
Mein Auto: 91 E30
Welcome to bimmerfest, I've moved your thread over to the Z3 forum.
Old 10-03-2012, 05:13 AM
wifesauto wifesauto is offline
Mein Auto: sloporsche
if its stick check the clutch safety switch on the pedal. do you have a DVOM and how much car repair can you do ?
Old 10-03-2012, 07:04 AM
Its a manual, yes we have a DVOM . we tried to push/clutch start it last night and she did start...but wont if we use jumper cables. I myself am a woman and dont know that much but have my husband help me and a friend too.
Old 10-03-2012, 08:16 AM
push start it again and drive to your mechanic.
Old 10-03-2012, 08:36 AM
hahaha... was that reply because I am a woman ?? ......
yesterday I checked all the fuses.. I tried to locate the starter solenoid and there were no signs of any burnt wires or loose wires that could be seen.
If I am correct in saying , it could be something to do with the starter possibly....or maybe the immobilizer system???
I tried using my spare key in case it was that as well...
today I will start over from beginning and although its a new battery , test that and test it under load as well....
will check the battery connectors too and work my way through the checklist.
Didnt think about the clutch safety switch...so that will go onto checklist too.
by the way...when I try to start her although there is no click or anything...the headlights dont dim....which makes me think...Starter...am I correct in thinking this???
Old 10-03-2012, 08:55 AM
if you can access the starter solenoid it may have a large post for the battery cable and a small post . check for voltage at small post while some one turns the key to the start position. if it has voltage and does not start it maybe the starter. with the clutch pedal down you should see voltage on both sides of the clutch pedal switch when the key is turned to start position. what is the batt voltage now ?
Old 10-03-2012, 09:10 AM
The Other Tom The Other Tom is online now
Mein Auto: 2008 335i
replacing the battery can be tricky in that it's sometimes hard to get the battery clamps back on securely. I had to use a socket that fit over the posts to push the clamps down. If you have good voltage at the battery (which I assume you do for a new battery), then check the clamps and make sure they are on, all the way to the top of the battery and clamped securely.
2008 335i
2001 325i retired
2000 M Roadster Imola Red retired
1998 Z3 2.8L retired
Old 10-03-2012, 10:04 AM
I will get my husband..who has a wide knowledge on working on cars and my friend who is a mechanic...although neither are BMW specialists...hence I am on here looking for help..... to look at both of the suggestions you made ... Thank you
Old 10-03-2012, 10:06 AM
Thanks ....will double check that again...
Old 10-04-2012, 08:49 PM
lovemyz3 lovemyz3 is offline
Mein Auto: Z3
There was mention of the starter. I would honestly check the starter and like Tom said, the battery clamps. Let us know if that works.
Old 10-05-2012, 07:38 PM
tohbi tohbi is offline
Mein Auto: z3 '97 atlanta blue 2.8
+1. car won't start, it's logical to suspect the starter. if you can hear the solenoid click, it means it is engaging the starter. if the starter won't turn after being engaged, one can expect low amperage or bad starter.
since you have new battery and wires are good [?], i would guess starter.
Old 10-07-2012, 07:07 AM
It turned out that it was the starter... I had to replace the whole thing as I wasn't even getting a click !
Now she runs beautifully again.
Old 10-07-2012, 07:17 AM
amancuso's Avatar
amancuso amancuso is offline
Send a message via AIM to amancuso
Mein Auto: Z3 2.3iA/5MT 528iA VW GTI
Glad it's sorted!
Old 10-07-2012, 08:39 AM
thank you for reporting back . did you change the starter yourselves ?
Old 10-09-2012, 05:31 AM
Randy Forbes's Avatar
Randy Forbes Randy Forbes is offline
Investigative Tinkerer
Mein Auto: ///Motorized Vehicles
Oops, wrong thread...
Randy Forbes
1957 Austin-Healey 100/6 Wine Red
1961 McCulloch R1 go-kart Screaming Yellow
1999///M Rdstr Cosmos Black Eurosport Twinscrew S/C
1999///M Coupe Estoril Blue Eurosport Twinscrew S/C
2001///M Rdstr Steel Gray
2011 X5 35i Sport Deep Sea Blue/Cinnamon
