The X5 SAV Forum
Old 10-02-2012, 07:51 PM
LGF LGF is offline
Mein Auto: 2002 BMW X5 3.0
Disa Valve
I currently have a faulty Disa Valve with inoperable flapper. I have also noticed that my gas consumption has increased considerably. Could this high gas consumption problem be a result of the faulty Disa Valve?
Old 10-03-2012, 10:39 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
Could be. The DISA valve controls the intake manifold. There is a lot of engineering that goes into this part of the engine operation, and if it is failing, it could make the engine work harder. That would decrease your fuel efficiency.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by SCJon View Post
Jared is king of ambiguous comments.
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
Old 10-17-2012, 12:15 PM
ECSTuning's Avatar
Mein Auto: e30
A failed DISA valve will often cause idle problems and low RPM hesitation. Poor fuel economy can also be one of the side effects. Below is a video showing how to remove the unit from an E46, the process is almost identical on the X5, also I have new DISA units available HERE.
800.924.5172
OEM BMW Part Number Search
Old 10-18-2012, 11:52 AM
Mudnyrey Mudnyrey is offline
Mein Auto: X5 3.0i
I have had the same issue on my X5, The removal and install is about 30 minutes. Two bolts hold the DISA valve in place. One top and One bottom just adjacent from the other.
After replacing mine, I have noticed a considerable change and improvement in acceleration and gas milage!!
Mud~
