Old 09-18-2012, 10:35 PM
Shredology Shredology is offline
Mein Auto: 1998 BMW 740i
Problem with radio and taillights
So today I just installed my new led bar lights I received from ddm tuning, next thing I know my radio does not work. So I have power leading to the unit and the radio always worked perfectly before I installed the lights but I can't figure out the problem. I might have touched the cd changer a little bit meaning I unscrewed two screws and wiggled it around a little and i accidentally dropped a screw from the light beside the battery but still can not figure out what the problem is because the radio shows power but when I press the power button for the fm, it does not show anything or whenever I click the audio button. Let me know what you guys think.
Old 09-23-2012, 04:07 PM
BMWFatherFigure's Avatar
Old School
Recheck you have all the plugs in OK. Spray them with contact cleaner. I think you touched it harder than you recall.
Current:
E38 Parts Car
Previous:
Old 10-03-2012, 12:48 AM
marynel marynel is offline
Mein Auto: bme e38
If the botton for on & off not show tha orange light under when u push,but cassette player sound like working that means is the radio fuse.where is it located? open the trunk,the left side opposite to the battery side,there are cd case,telephone component others staff ,u have to take those out & behind the cover u will see a part belong to the radio ease take it out & test the fuse.Easy to change.Good luck.
