Old 09-26-2012, 05:13 PM
Gahngoo Gahngoo is offline
Mein Auto: 07 530i Silver/Blk Sport
windshield washer fluid pump question...
I recently discovered that my windshield washer fluid pump was leaking. I pulled back to the fender lining and got to the pump to remove it. I took a look at the pump and saw that it was leaking from the bottom. if you look at the picture, you'll see a rectangular opening. That is where the fluid was leaking from.
Here's my question: Is this some sort of vent, or can I fill it with silicone to stop the leak? (2007 530i)
I'm ready to glue it, so quick responses are appreciated!!!
ID:	343394   Click image for larger version
ID:	343395   Click image for larger version
Old 09-27-2012, 06:37 AM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
Thats not going to stop the leak. Do a search for a new pump, there cheap enough . I got a OEM pump through amazon $10.95 shipping included
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Mats-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Mats
Old 09-27-2012, 07:30 AM
brocyourworld brocyourworld is offline
Mein Auto: 2008 535
Nothing better than logging on to ask a question and seeing that someone else has the same issue and a solution has already been posted. Love this forum!!!
Anyone got a pics or a DIY on how to get to the pump?
Old 09-27-2012, 08:51 AM
john@eac john@eac is offline
Past Sponsor
Mein Auto: Many
Here is a link to the washer pumps that we carry if you would like to check them out. http://www.eaceuroparts.com/parts/pa...ge/31/2007/378
Old 09-27-2012, 09:18 AM
Thanks for the info. I'm glad a new one is cheap. This is probably the cheapest repair I've seen with this car!
Old 09-27-2012, 09:34 AM
It's pretty simple. Take off the front driver-side wheel. Then unscrew the wheel-well lining. You don't have to take the liner off, just pull it to the side. You'll see the white washer fluid reservoir. The pump is at the bottom. Pull it up and out. It just sits in a grommet. You're done.
Old 10-03-2012, 01:05 PM
Update: I glued the pump with marine tec epoxy. No leaks. No problems. The plastic housing on the pump cracked along the seam causing it to leak, but the glue took care of that. :-)
Old 03-20-2013, 07:08 AM
dartery dartery is offline
Mein Auto: 2004 525i
Thank you.
This info proved to be invaluable.
Old 03-20-2013, 10:02 AM
Tomahawk674 Tomahawk674 is offline
Mein Auto: WTB 528i
I just did the same on my car last saturday. I was very concerned when I found a puddle of red liquid under my car - until I realized it was washer fluid. I the did research and found many different models have the exact same pump, and tons of the original pumps leak.
Old 03-22-2013, 06:38 AM
Westlakeoh1 Westlakeoh1 is offline
Mein Auto: 2000 528i; 2005 545i
I have the same issue. I actually purchased new pumps twice. The first new one, after I installed, would not pump washer fluid so I returned it. I purchase another and installed it, and again, no fluid delivered to the windshield. I re-installed the old leaking pump.
Does anyone know if the new pump needs to be primed first? I have a 05 545 and I don't understand why either new pump works. I went to two different providers for the pumps and both website provide the same pump part number.
anyone else experience this issue?
Old 03-22-2013, 07:18 AM
pcy pcy is offline
We don't need to prime the washer fluid pump.
Other than the leak, the old pump is working fine? Water is coming out of the jets with the old pump?
There is a strainer/filter and the grommet fits over the inlet of the pump and that grommet assembly sits in the opening of the tank. Are you sure you are installing correctly?
Old 03-22-2013, 05:28 PM
Yes, the old pump pushes water out of the jets just fine. The problem is when I installed both new pumps - exactly the way the old pump was, grommet included
- and nothing comes out of the jets. Both new and old motors are identical in appearance. I just lived through this winter with the old motor that leaks a gallon of wiper fluid in a couple days.
When i warms, I'll put the last new motor I purchased and see if there are still leaks, maybe the tank is leaking. the weather has just been too bad to do this yet.
