Old 09-17-2012, 11:30 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
Mein Auto: 2011 535i M-Sport
Originally Posted by digital View Post
Mine is F10 2013 with the new Nav. I'll keep you posted.
Good deal. Thanks.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 09-17-2012, 05:24 PM
digital digital is offline
Mein Auto: 2013 535i xDrive M-Sport
Here it is:
1- Code KOMBI / HUD_PIA_BLINKER = aktiv
2- Code KOMBI / BLINKER_HUD_ENABLE = aktiv
3- Code HU_NBT / HUD_TURNSIGNAL = aktiv
The iDrive check box will not show up, but it works. (I couldn't figure out the check box issue)
2013 535i xDrive M-Sport Graphite
2011 X3 35i White
2004 325i Silver Grey
1978 518
Old 09-17-2012, 05:26 PM
Here it is:
Sweet! Maybe you can kind the missing Pia_Default_Tippblinken or equivalent too?
- BMWCCA #446923
- flick
Old 09-17-2012, 06:12 PM
I'll work on it
2011 X3 35i White
1978 518
Old 09-18-2012, 06:10 AM
Paging @marcosg:
Can you check and tell me if your HUD Turnsignals work with just:
HU_CIC / HUD_TURNSIGNAL = aktiv
Or, if you also have to enable:
Also, tell me if you have the "Turn indicator" Checkbox in Settings=>Heads-Up Display.
- BMWCCA #446923
- flick
Old 09-18-2012, 06:17 AM
marcosg marcosg is offline
Mein Auto: 2011 BMW F10 528i M Sport
Paging @marcosg:
Yes, HUD Turnsignals work with just
I did not code KOMBI / HUD_PIA_BLINKER. It is currently set to inaktiv
Yes, I do have "Turn indicator" Checkbox in Settings=>Heads-Up Display.
Old 09-18-2012, 06:30 AM
Ok. Interesting. So, a car with HU_CIC updated with 47.x acts the same as it always has, yet cars with HU_NBT apparently need KOMBI / HUD_PIA_BLINKER also enabled to get HUD turn signals, and for some reason, the "Turn indicator" Checkbox does not show up with HU_CIC / HUD_TURNSIGNAL = aktiv.
- BMWCCA #446923
- flick
Old 09-20-2012, 06:01 PM
preeble preeble is offline
Mein Auto: Cars
I couldn't get my 2013 F10 to work either, but will try it with these new settings and will report back.
Old 09-21-2012, 07:19 PM
falcongeek falcongeek is offline
Here it is:
I was able to get the HUD Turnsignals working on my 2013 F10 also using the KOMBI / HUD_PIA_BLINKER = aktiv setting. I also found that they continue to work even with HU_NBT / HUD_TURNSIGNAL = inaktiv. It looks like the checkbox function maybe similar to the Entertainment/Telephone List where the checkbox just won't work but the HUD still displays them properly?
Adam
Old 09-21-2012, 07:39 PM
Adam
Your check box shows up though, its just nonfunctional?
- BMWCCA #446923
- flick
Old 09-24-2012, 09:34 PM
FrogmanF30's Avatar
FrogmanF30 FrogmanF30 is offline
Mein Auto: 2012 328i
I have never coded HUD Turn signals on an F30, so I can't say for sure whether it should work.
Has anyone coded an F30 and got it to work?
I just tried this on my 2012 F30 328i (April build); no joy.
I set:
HU_CIC / 3000 / HUD_TURNSIGNAL to aktiv (Wete=01)
KOMBI / 3003 / HUD_BLINKER_ENABLE to aktiv (Werte=01) F30 function is named this, there is no BLINKER_HUD_ENABLE in KOMBI)
KOMBI / 3008 / HUD_PIA_BLINKER to aktiv (Werte=01)
I get the iDrive turn signal option in the HUD section and I can select it and it's checked, but no HUD signals show up.
I also wanted to code the one-touch from 3 blinks to 5, so I also changed:
FEM / 3064 / PIA_DEFAULT_TIPPBLINKEN to Mehrfachblinken (Werte=01)
FEM / 3060 / BLINKZYKLEN_ANZAHL_TIPP to Werte=04 (value name changes to UNKNOWN)
I now get 5 blinks for one-touch, but still no HUD signals. Any ideas?
It may be one of those settings that takes a while to "take", so I'll see if it works tomorrow...
I-Step is F020-12-07-532
CAFD versions:
HU_CIC is 0F9_007_003_007
KOMBI is 9C8_005_000_030
FEM is 794_004_122_077
Old 10-03-2012, 01:31 PM
legaleye3000 legaleye3000 is offline
Mein Auto: F30 328i Sedan
If anyone figures out HUD turn signals for F30 2012, please post. Thanks.
Old 10-03-2012, 02:30 PM
332701 332701 is offline
Mein Auto: 535xd
don't you have the same menu structure as the F10/11?
535xd with 20'' Wheel style 434 M in Sophistogrey II Brillant Metallic
Old 10-03-2012, 02:36 PM
FrogmanF30's Avatar
It's almost the same.
I've set all three and get the option in the iDrive HUD list and I can and do select it, but no turn signals show up in the HUD.
I'm not sure, but a couple posts above, he said he was unable to do it.
Old 10-03-2012, 03:49 PM
wdimagineer's Avatar
wdimagineer wdimagineer is offline
Mein Auto: 2013 M5
Adam
Interesting. Do you get a checkbox? I don't. But they DO work.
2013 ///M5
Alpine White · Sakhir Orange Full Merino
Executive · Driver Assistance · B&O · 20" HRE P40SC · Akrapovic Evolution · H&R Springs · Many Euro Mods
Old 10-03-2012, 04:16 PM
FrogmanF30's Avatar
On my F30 (with CIC not NBT) I get the checkbox and it's enabled (I can check and uncheck it), but no turn signals show up in the HUD when checked.
Did you only change the KOMBI / HUD_PIA_BLINKER = aktiv and nothing else to get yours to work? I have not tried that yet. I've also always set HUD_BLINKER_ENABLE to aktiv too.
When I just reset HU_CIC / 3000 / HUD_TURNSIGNAL back to inaktiv (leaving the other 2 changes intact), the check box goes away and no signals in the HUD.
I think the HU_CIC change just enables the checkbox on the screen and the KOMBI change(s) actually enable the function.
Old 10-03-2012, 08:03 PM
Mein Auto: 2013 M5
I checked everything, including in HU_NBT. I get no checkbox, but I do get turn signals in my HUD.
2013 ///M5
Old 10-08-2012, 03:18 AM
soupratt soupratt is offline
Mein Auto: 520d
This works perfectly well in a 2011 Australian M-spec 520d.... Nice to use as the turn signal sound is quite soft and can be muffled by music.
Old 10-27-2012, 05:24 AM
f01driver f01driver is offline
Mein Auto: 750i, S5
Has anyone tried this on the f01?
2011 750i
Old 11-07-2012, 01:53 AM
Mein Auto: 750i, S5
Coded the signals on my f01;
2011 750i
Old 11-10-2012, 12:04 PM
AutobahnCowboy AutobahnCowboy is offline
Mein Auto: BMW
shows the hud only both sides together or right/right and left/left ?
in my tested F30 i cant get it work
got the Checkbox too but take no effect in hud
Old 11-21-2012, 03:46 PM
csnyder335i csnyder335i is offline
Mein Auto: 335i
Any luck on this. Have an 2013 F30 checkbox shows up but no blinkers in HUD. Have all 3 settings enabled.
Old 11-21-2012, 04:33 PM
Mein Auto: 750i, S5
Signals are shown to together.
2011 750i
Old 11-21-2012, 08:00 PM
FrogmanF30's Avatar
No joy on getting this to work on an F30 yet.
I also have all 3 settings activated on my 2012 328i and the check box is operational, just no blinkers in the HUD.
