E34 (1989 - 1995)
Unable to open doors due to disconnected battery
Hi all.
I just finished read the thread, while sitting near my car, and was unable to open the doors. The car was parked for 2 weeks so I disconnected the battery, just in case. Today I arrived and couldn't open the doors. Connected myself to the forum and tried all the tips on a thread posted a while ago. Then I remembered that I left the negative cable way down and try to reach it from under. I was able to link a cable between that cable and a (-) from a donor car. NOTHING. What now??? Tips, advices. Appreciate all the help. Best regards |
Hi all. One more thing.
I connected ground to another car and positive remains on mine. I only disconnected groumd and my battery was ok. I'm I missing something obvious??? Thanks and best regardd |
I do not understand.
Are you able to gain entry to the vehicle but the doors remain locked? Way down? Typically, if the battery is completed disconnected (negative and positive), you have to manually lock each door. I do this all of the time with my 92 M50. Last edited by My525iT; 10-03-2012 at 08:43 PM. |
Charge does not travel both ways on one wire. Connect the positives. Before that, just try the emergency door unlock procedure, but with the following difference. Try lifting the door handle WHILE you are turning the key and not before. See if that works. You may have to do that several times to get the right simultaneous combination working. Last edited by robertobaggio20; 10-03-2012 at 09:09 PM. |
Hi all.
My car has the battery on the motor compartment and I simply disconnect the ground. I can reached it from under the car because the cable is hanging. I tried that emergency procedure after reading a thread here but not working. I'll keep trying. Again , I'll also try to find a hot connection from the battery, maybe the starter, and connect positive there and ground on the hanging cable. Thanks Roberto. I also thought of that. Something was missing there and I couldn't get it right after a 8 hours flight. I'll keep trying, thanks for the help. Best regards |
Hi all.
Done. After reading some threads, I just plugged a booster to the starter and ground it on the vehicle. Popped right away. Thanks to all. Best regards |
You can do the same by plugging a 'booster' into the rear side markers...way easier.
or the trunk light...
Some people can't get to the trunk light...the marker light is ALWAYS available.
My sidemarkers are sooooo brittle its not even funny. The trunk doesn't need any electronics to open with the key.
Hi all.
The trunk didn't open with the key. Sorry to ask, but what do you mean by marker?? For the two procedures, trunk and marker, the ground cable can be disconnected??? Thanks for those tips. I have to keep those in mind for the next time. Best regards |
![]() YOUR bumper should have 'euro trim'...AKA-flat trim...no light...like this pic: ![]() Now, I would wager that the harness for the rear side marker is present on your car...pop the trim off the bumper and look around for an unhooked light harness. The trick should work with no batt hooked up...all it does is feed the voltage through the system backwards so you can use the locks...it's the same thing as hooking a lead to the starter...but it's WAY easier to get to... Good luck!
Trunk doesn't open manually with the key?
That's a first... Something is wrong with it then. |
Hmmm..... I was thinking that the actuator for the trunk is electrically powered ??? Is this not correct?
Steve Calypso Red 1992 525i with 170K miles 1991 735i - Sold 1992 525i - Sold 1995 325is - Sold 2000 528i - Sold
Hi all. Thank you so much for all the inputs.
And I believe so. The trunk lock is electrically powered. Also, my car comes with LSD, lowered suspension and a few more features. As far as I researched, there was some special editions here in Portugal with those.. I'll look for that harness Best regards |
In the US, we didn't have the 525i 'sport'...because it featured all the options that came standard in the US (other than the LSD). We all got moonroofs, power windows and power leather seats standard...while EU markets had to 'option' leather seats and power windows etc...
Just noticed that Bentley has an emergency unlock procedure on pg. 515-2.
Has anyone tried this? Due to a discharged battery, use the passenger side front door (additionally drivers side on pre 1990). Place key in lock and lift door handle while turning key fully in CW direction. Same to lock. |
+1 with the trunk (boot) lock. It should have a rod attached to the lock at all times - mechanicial unlock. Check the owners hand book as to which way to turn the key. If the car did not come with one try e-bay. Worked for me.
Good - Fast - Cheap: Pick any two. Current: E23 735i; E30 318i; E32 735iL; E38 735iL; R50 Cooper; R55 Cooper Clubman. Previous: E21 318i; E32 735iL; E34 535i; E38 730iL; E53 4.4i
Hi all.
Tried that "emergency opening" with no luck. The key doesn't move on the lock neither way. I'll put that on the correction list. Stay tuned for a new thread after the compression test. Here we have to "build" he car. For instance, mine as ZF box, LSD, lowered suspension, electric all around, two temperatures AC, pre-heating device, fabric seats... |
