Unable to open doors due to disconnected battery - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 10-03-2012, 02:10 PM
Bugsie Bugsie is offline
Mein Auto: BMW E34 M50 2.5
Hi all.
I just finished read the thread, while sitting near my car, and was unable to open the doors.
The car was parked for 2 weeks so I disconnected the battery, just in case.
Today I arrived and couldn't open the doors. Connected myself to the forum and tried all the tips on a thread posted a while ago.
Then I remembered that I left the negative cable way down and try to reach it from under. I was able to link a cable between that cable and a (-) from a donor car. NOTHING.
What now???
Tips, advices. Appreciate all the help.
Best regards
Old 10-03-2012, 04:19 PM
Hi all. One more thing.
I connected ground to another car and positive remains on mine.
I only disconnected groumd and my battery was ok.
I'm I missing something obvious???
Thanks and best regardd
Old 10-03-2012, 08:40 PM
My525iT My525iT is offline
Mein Auto: 92 525iT Wagon M50
I do not understand.
Are you able to gain entry to the vehicle but the doors remain locked?
Way down?
Typically, if the battery is completed disconnected (negative and positive), you have to manually lock each door.
I do this all of the time with my 92 M50.
Old 10-03-2012, 09:00 PM
Banned
Mein Auto: car
Yes, you do not have a closed circuit. It has to be a circle. The positive in your car can now get OUT of your car to the next car THROUGH the negative, but cannot return to the positive on your car.
Charge does not travel both ways on one wire. Connect the positives.
Before that, just try the emergency door unlock procedure, but with the following difference. Try lifting the door handle WHILE you are turning the key and not before. See if that works. You may have to do that several times to get the right simultaneous combination working.
Old 10-04-2012, 01:38 AM
Hi all.
My car has the battery on the motor compartment and I simply disconnect the ground. I can reached it from under the car because the cable is hanging.
I tried that emergency procedure after reading a thread here but not working. I'll keep trying.
Again , I'll also try to find a hot connection from the battery, maybe the starter, and connect positive there and ground on the hanging cable.
Thanks Roberto. I also thought of that. Something was missing there and I couldn't get it right after a 8 hours flight.
I'll keep trying, thanks for the help.
Best regards
Old 10-04-2012, 01:26 PM
Hi all.
Done. After reading some threads, I just plugged a booster to the starter and ground it on the vehicle. Popped right away.
Thanks to all.
Best regards
Old 10-04-2012, 03:56 PM
MeanM50 MeanM50 is offline
Mein Auto: E34/5
Hi all.
Thanks to all.
Best regards
You can do the same by plugging a 'booster' into the rear side markers...way easier.
Old 10-04-2012, 04:02 PM
Mein Auto: 1989 525i M20B25
or the trunk light...
Old 10-04-2012, 04:04 PM
Mein Auto: E34/5
Some people can't get to the trunk light...the marker light is ALWAYS available.
Old 10-04-2012, 07:34 PM
My sidemarkers are sooooo brittle its not even funny. The trunk doesn't need any electronics to open with the key.
Old 10-05-2012, 04:38 AM
Hi all.
The trunk didn't open with the key.
Sorry to ask, but what do you mean by marker??
For the two procedures, trunk and marker, the ground cable can be disconnected???
Thanks for those tips. I have to keep those in mind for the next time.
Best regards
Old 10-05-2012, 09:08 AM
Mein Auto: E34/5
Hi all.
Best regards
Sorry Bugs...euro cars don't have 'side markers'...they are little rectangular lights that the US cars have on their bumper trim...it's the white rectangle on the rear bumper in this pic:
YOUR bumper should have 'euro trim'...AKA-flat trim...no light...like this pic:
Now, I would wager that the harness for the rear side marker is present on your car...pop the trim off the bumper and look around for an unhooked light harness. The trick should work with no batt hooked up...all it does is feed the voltage through the system backwards so you can use the locks...it's the same thing as hooking a lead to the starter...but it's WAY easier to get to...
Good luck!
Old 10-05-2012, 10:37 AM
Trunk doesn't open manually with the key?
That's a first...
Something is wrong with it then.
Old 10-05-2012, 11:23 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
That's a first...
Hmmm..... I was thinking that the actuator for the trunk is electrically powered ??? Is this not correct?
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 10-05-2012, 02:26 PM
Hi all. Thank you so much for all the inputs.
And I believe so. The trunk lock is electrically powered.
Also, my car comes with LSD, lowered suspension and a few more features. As far as I researched, there was some special editions here in Portugal with those..
I'll look for that harness
Best regards
Old 10-06-2012, 08:22 AM
Mein Auto: E34/5
It IS electrically powered...but the mechanics are directly driven by the key...so it SHOULD work with the key EVERY time...but I have ran into a trunk that didn't open with they key...you will likely need a new trunk latch to fix the problem.
Best regards
In the US, we didn't have the 525i 'sport'...because it featured all the options that came standard in the US (other than the LSD). We all got moonroofs, power windows and power leather seats standard...while EU markets had to 'option' leather seats and power windows etc...
Old 10-06-2012, 10:15 AM
Just noticed that Bentley has an emergency unlock procedure on pg. 515-2.
Has anyone tried this?
Due to a discharged battery, use the passenger side front door (additionally drivers side on pre 1990). Place key in lock and lift door handle while turning key fully in CW direction. Same to lock.
Old 10-06-2012, 07:53 PM
Mein Auto: E34/5
It's not 100%...the mechanism that operates the 'emergency unlock procedure' can break very easily. I've had terrible luck in this department. Almost every E34 I've owned hasn't worked.
Old 10-06-2012, 07:58 PM
BMWFatherFigure's Avatar
Old School
+1 with the trunk (boot) lock. It should have a rod attached to the lock at all times - mechanicial unlock. Check the owners hand book as to which way to turn the key. If the car did not come with one try e-bay. Worked for me.
Current:
E38 Parts Car
Previous:
Old 10-07-2012, 02:00 PM
Hi all.
Tried that "emergency opening" with no luck.
The key doesn't move on the lock neither way. I'll put that on the correction list. Stay tuned for a new thread after the compression test.
Here we have to "build" he car. For instance, mine as ZF box, LSD, lowered suspension, electric all around, two temperatures AC, pre-heating device, fabric seats...
