E90/E91/E92/E93 (2006 - 2013)
Old 10-03-2012, 10:24 AM
chris328's Avatar
chris328 chris328 is offline
unbekannt
Mein Auto: lci 335 e92
Weird asterisk in dash
Hey guys this morning I got up and it was real cold out, and after I started my car and went a little bit I got this dingy sound and a large asterisk symbol on teh dash. What is that??
Old 10-03-2012, 10:27 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 09 335Cabrio zsp/11 335d
Ahhh, the first snow flake sighting of the year. It means that it was less than 38 outside, so be warned of possible black ice. N4S
Old 10-03-2012, 10:37 AM
andrew b's Avatar
andrew b andrew b is offline
flâneur en cabriolet
Mein Auto: 2007 E93 N54
It's that time of year again....
Old 10-03-2012, 10:54 AM
dealio's Avatar
dealio dealio is offline
Mein Auto: E90 335xi
asterisks, snowflakes, whatevers
Old 10-03-2012, 12:01 PM
SD Z4MR's Avatar
SD Z4MR SD Z4MR is offline
(formerly SD 335is)
Asterisk?
- Tom
Old 10-03-2012, 01:49 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi Sedan
I think y'all just got punk'd....
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
N47° 35' 30.13" E11° 10' 33.36" - End of break-in period. You can guess the rest. BMW CCA
Old 10-03-2012, 03:01 PM
3.1L Z 3.1L Z is offline
Mein Auto: '06 330i
It's a Moose warning.
'08 335i Sp Pkg, Cobb and wife's '07 X3si
San Antonio, TX
Old 10-03-2012, 04:23 PM
jertronic jertronic is offline
jertronic
Mein Auto: 2008 328 xi sedan
Great... Now brace yourselves for a few more Angel Eyes posts.
2008 328xi E90|N51|monaco blue|premium|sports|cold weather|logic 7|ipod|BMW Assist|xenon|sunshade|HD radio
Old 10-03-2012, 05:09 PM
pointandgo's Avatar
pointandgo pointandgo is online now
bimmerfest Supporting Member
Mein Auto: '11 E90 328i
Wrong...that's the "antler" symbol. Everyone in NH, Maine knows that.
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic.
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 10-03-2012, 05:17 PM
pointandgo's Avatar
Originally Posted by need4speed View Post
Ah the first snow flake sighting of the year. It means that it was less than 38 outside, so be warned of possible black ice. N4S
I'm wondering if the BMW "asterisk" calculates that the temperature is declining when the symbol appears and chime goes off. Last time that I checked, ice doesn't form at 38 deg. F.
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
Member: BMW CCA
Old 10-03-2012, 05:41 PM
Nordic_Kat's Avatar
Nordic_Kat Nordic_Kat is offline
My Reality Check bounced
Mein Auto: 09 328i 6MT Cabrio
My guess is any engineer who works at the FIZ and has been caught on some of the roads in southern Germany and northern Austria has figured out that if he can get the chains on his tires before temps reach 0°C, it's much easier and a lot less wear and tear on the knuckles.
It's a word problem:
It takes Franz 7 minutes per wheel to put the chains on his E92. If the temperature is dropping at 0.12 degrees per minute, at what temperature must Franz begin installing chains to get them on the car before the temperature reaches 0°C?
If your sport doesn't put blood, dirt or grease under your fingernails,
then it's just a game.
Euro Modded|Split Armrest|Rear Foglight Mod|CDV Delete|Shark Fin Antennae Delete|Front Reflector Delete|LUX H8 Angel Eyes|No Bells|Few Whistles|Das Fahren im Freien| BMWCCA#445793
Old 10-03-2012, 06:11 PM
pointandgo's Avatar
NK,
Noted, but my take on Munich's programming of the "asterisk" warning is that it will only appear after a "least squares" calculation of temp...after one hour of numbers crunching (temp calcs)...and only after arriving at an R-squared factor of at least .70. I could be wrong.
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
Member: BMW CCA
Old 10-03-2012, 06:13 PM
gpburdell gpburdell is offline
Mein Auto: 2010 335i Cabrio
If its below 38F at the sensor, it could be sub-32F nearby with little to no warning. The idea of warning beforehand tends to work a little better than after you've slid into the oncoming lane...
Old 10-03-2012, 07:30 PM
laser's Avatar
laser laser is offline
Mein Auto: 2007 S2000
These lights on the dash are so confusing......
Like this one that keeps coming on:
Also a strange clicking that seems to accompany
Laser
___________________________
2011 535i Black Sapphire Metallic, Sport, Euro Del (ret)
Old 10-03-2012, 08:17 PM
SD Z4MR's Avatar
(formerly SD 335is)
Weird, I have an arrow that comes on too, only it points in the opposite direction. Do you think that whatever's causing this arrow to light up got installed backwards in my car?
- Tom
Old 10-03-2012, 08:31 PM
Nordic_Kat's Avatar
I get both arrows. They are intermittent; ie sometimes left pointing, sometimes right. There seems to be a slight correlation with which way my wheels are pointed. Is this something that is covered by warranty? Should I have my dealer check it out?
Old 10-04-2012, 07:05 AM
chris328's Avatar
unbekannt
Old 10-04-2012, 09:40 AM
andrew b's Avatar
Sometimes mine both come on at the same time! When this happens, there is also a bright red light flashing on the dash.
My dealer says it's normal, but he was laughing so I'm not sure he was serious.
Old 10-04-2012, 11:21 AM
dealio's Avatar
anyone else suffering from orange-y glowing mysterious alphanumeric characters (mostly alpha, irrc) that show up in the rear view mirror. they tend to morph into other alphanumeric characters every time the car changes direction. weird.
Old 10-04-2012, 11:24 AM
BiHoTTo115's Avatar
BiHoTTo115 BiHoTTo115 is offline
Mein Auto: 2006 330xi
Odd. I think I need a DIY guide on figuring out how to fix that Rumbling noise when I push the start button. It's definitely strange.
2006 330xi | 6AT | Navi | Premium | Cold Weather
Old 10-04-2012, 12:03 PM
The X Men The X Men is offline
Mein Auto: 2012 535xi 2012 X3 35i
I always thought that the asterisk lights up on the dash when the AC is on.
Old 10-04-2012, 01:26 PM
need4speed's Avatar
Ture, but on a bridge, over pass or in a shady area of the road the air temp may be 38, but the road temp can be below 32. Why did BMW chose 38 as their warning point? Who knows, it ranks up there with run flat tires, not ready for prime time hpfp and the euro beek nose (I actually do know this one) as unknowable BMW quirks. N4S
Old 10-04-2012, 01:51 PM
Dork Knight's Avatar
Dork Knight Dork Knight is offline
Location: 2mi W of Gotham, in the mediocre side of the burbs
Mein Auto: '11 335i M-sport...by day
I have the same problem with my lights and they frustrate me. What's worse, when I get angry about it and hit the middle of the steering wheel, it makes a terrible noise. Very loud.
Old 10-04-2012, 01:59 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Mein Auto: 2009 335i xDrive coupe
Ice doesn't form at a temperature of 38 degrees, but it can certainly form on a road surface that drops below the air temperature.
Posit a situation where it is a 38 degree night, crystal clear, with no wind. The road is radiating IR in all directions. In most directions, there is an object of similar temperature radiating IR back at it. But, we've said it's a clear night. The road is radiating IR towards the clear sky, but is receiving no IR from the (approx) -450 degree section of interstellar space in the opposing direction. The road loses temperature continually, dropping below the freezing point even though the air around it is several degrees above freezing. The effect is especially pronounced on bridges and overpasses. It's also why you first see frost warnings in the fall on clear nights, but not on cloudy ones.
You can do a demonstration with your car's front and rear glass to show the effect. Park the car so that there are branches with leaves above the rear glass, but nothing above the windshield. You will often find that frost or dew will form on the glass exposed to the sky, but not on the glass shaded by the leaves, as they are radiating back at the glass, while the exposed surface has dropped below the dew point / freezing point.
The reverse is the case during the day. The air temperature may be below freezing, but the portion of the road looking at the 10,000 degree ball of fusing hydrogen in the sky is raised significantly above freezing.
FWIW,
George
2009 335i xDrive coupe, Jet Black, Black Leather, Grey Poplar, Steptronic, ZPP, ZSP, ZCW, iPod/USB, HD radio, Parking Assist. Rear Fogs, Hardwire V1, ProFit G3.
ED May 12, 2009, Munich dropoff May 16, Redelivery June 22, 2009
Prior 33 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette (kept until first Bronco) / 1981 Subaru GL wagon AWD / 1983 s10 Blazer 4x4 (big mistake) / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion
Old 10-04-2012, 02:02 PM
rtgirard's Avatar
rtgirard rtgirard is offline
1-5-3-6-2-4
Send a message via Skype™ to rtgirard
Mein Auto: 2013 335xi
Every time that asterisk illuminates I get a nasty kink in my Hofmeister.
F30 335xi - Ordered on 9/5/2012... Delivered 10/29/2012
Alpine|Coral|ZSL|ZPP|Nav|ZDH|SportAuto
BMWCCA# 457109
