dsc and dbc message - Bimmerfest - BMW Forums
Old 10-03-2012, 02:45 PM
papagoob61650 papagoob61650 is offline
Mein Auto: 750 LI
dsc and dbc message
Hopefully someone has had a similar problem and can help. Was driving my 2007 750li today (rainy) and after approximately 10 miles a message came that there was a dsc and dbc failure and that I should drive moderately and contact my BMW dealer ASAP. I drove for another 10 miles or so and stopped for gas and as I shut the car off a message quickly came on that I had an emergency brake problem. I fueled the car up and all messages disappeared and I drove the car home, another 25 miles, with no messages reappearing. Any advice would be appreciated.
Old 10-03-2012, 03:38 PM
***CCCP***'s Avatar
***CCCP*** ***CCCP*** is offline
Major
Mein Auto: 745 li
Seems like ur battery is going dead. Or alternator not giving enough charge. U can check ur battery voltage through the hidden menu in ur cluster with the car on. Should be around 14.
Old 10-03-2012, 04:32 PM
MakaveliFaison's Avatar
MakaveliFaison MakaveliFaison is offline
Mein Auto: Bmw E64/5, Maserati GT
Ive had it happen before due to faulty harness. Located right next to coolant tank
650i sport hud ac schnitzer eibach resognator delete m6 quads akebonos
Old 10-03-2012, 05:47 PM
SFbay SFbay is offline
Account Under Review
Mein Auto: BMW 745i
Yeah be very careful with that dsc module connector,
I washed my engine very little water got in there! So they claim this connector is water proof it's not!! That rubber pad won't seal it like it should.
So if you spilled some coolant while topping it off or your tank was leaking, you might kill 600$ module.
