Old 10-02-2012, 09:59 AM
THE HAITIANMAN THE HAITIANMAN is offline
Mein Auto: 328I
Help with usb flash drive music
I nedd help to configure why my music are cutting off while playing from the USB DRIVE.
if anyone can please help with some ideas will be preciate.
I have a 2.0 8G PNY FLASH DRIVE. I load a few songs WMA files the song play but cut off every minute. I;m not sure why and how to fix it, or is it possible to fix?
the drive was already Formated to default FAT32 I didn't change it.
please help
Old 10-02-2012, 10:07 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
does it do it with mp3s? or with a different drive?
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Old 10-02-2012, 10:55 AM
Mein Auto: 328I
well I didn't try MP3 FILE yet but I will try I never though of trying a different drive. I will go try both a diferent drive & Mp3 file and I will def let you know. thanks for replying...
Old 10-02-2012, 11:20 PM
NeutronNED NeutronNED is offline
Mein Auto: 328xi
I'm using a 32Gb PNY stick with WMA. I had some strange problems the first time I loaded it, where the car would stop recognizing songs. I reformatted and reloaded all my songs, and it's been perfect from then on. You do need to leave the stick in for a while with the larger drives so the car can index the files. You might just try reformatting the stick and reloading the music files.
Old 10-03-2012, 09:14 AM
Mein Auto: 328I
Thanks..
I'll do that. should I reformat it to FAT32? or to something different. I did left the stick in the USB port since 3days ago I never remove it...
thank you so much for the help...I will try it today.
Old 10-03-2012, 09:59 AM
EaglesWin EaglesWin is offline
Mein Auto: 2007 335i
Hi, just got my '07 335i. Where is the USB port? Is it near the Aux IN jack? If so, I might not have this option.
Old 10-03-2012, 11:06 AM
gpburdell gpburdell is offline
Mein Auto: 2010 335i Cabrio
Left side of panel behind glove box door is the one for loading music. Inside the center console is the one for playing direct from USB if your vehicle is so equipped. If just an AUX jack, you probably don't have the 6FL option.
Old 10-03-2012, 11:08 AM
Mein Auto: 328I
I use to have one also I don't think they come with that option, the 2007 is the first generation body style, and yes its suppose to be next to the AUX IN JaCK....
Old 10-03-2012, 11:52 AM
Ok, no USB there. I don't have it I guess. There's no mention of USB in my manual. It's an early build '07 - November 2006.
apparently not available until 3/07 - http://www.bimmerfest.com/forums/sho...d.php?t=258477
Old 10-03-2012, 11:53 AM
chris328's Avatar
chris328 chris328 is offline
unbekannt
Mein Auto: 750Li Hi-Sec, '13 Actros
i dont even have the usb and mine is an '11. got the cheapo stuff.
Old 10-03-2012, 07:08 PM
Mein Auto: 328xi
Thanks..
I just formatted mine to FAT32. I don't know why it was flakey the first time I tried, but it's working great now.
