E36 (1991 - 1999)
Old 10-02-2012, 10:44 AM
godschariot godschariot is offline
Mein Auto: 325is
no idlery pulley?
I have a 95 325is with m50tu. It makes a "chirping" sound when idling or accelerating at low rpms, especially when cold. Replaced both belt tensioner pulleys and belts this weekend with no change. I noticed when doing it that I have no idler pulley on my car. I'm pretty sure I have a mechanical tensioner like this:
not my car, found this on an e30 forum i'm on (this m50 is in an e30). he has an idler pulley mounted up.
according to realoem this style of tensioner (which is different than the hydraulic shock type also found on 95 m50s) does not use an idler/deflection pulley?
http://www.realoem.com/bmw/showparts...47&hg=11&fg=18
http://www.realoem.com/bmw/showparts...99&hg=11&fg=18
Is this normal?
Old 10-02-2012, 11:40 AM
Mein Auto: 325is
ok looks like the mechanical tensioner on pre-1995 cars DID use an idler pulley. So it looks like my set up is as it should be.
http://www.realoem.com/bmw/showparts...11&fg=18&hl=42
Old 10-03-2012, 02:42 PM
superwashcycle superwashcycle is offline
DIY lifestyle.
Mein Auto: 2003 530i Sport Premium
Does it sound like crickets? You may want to try regreasing or replacing your pulleys. If you have the engine out like that, it's really easy to do. I have the same thing happening in my E39 and it really only chirps at the lower RPMs in drive or reverse.
Old 10-03-2012, 03:15 PM
Mein Auto: 325is
yes same symptoms as you. did yiu read my post? thats not my engine and i replaced both tensioner pulleys already. i think my mechanical tensioner itself is suspect. i think i may buy a mechanics stethoscope and try to further diagnose it even though the tensioner is only $40.
Old 10-03-2012, 04:36 PM
DIY lifestyle.
My apologies - I have quality control issues regarding my replies when a professor is trying to teach me algorithm design and I'm here trying to find resources on greasing pulleys.
If you search "re-grease 3 belt pulley bmw," you should land at a link that has descriptive pictures of all the parts connected to the belts. I bought some wheel bearing grease from O'Reilly's and I'm going to attempt to perform the "regrease" tonight.
Have you considered just greasing all of the pulleys? Once you remove the fan shroud, everything's there and really quite easy to remove and inspect. There's a good DIY on removing the shroud from Beisan Systems. Once you find a pulley that has bearings with play in it, you've isolated one of the culprits. From what I've read over the last several days, this symptom seems to be caused by the idler pulley. Other symptoms I've read about are constant and include noise in any gear - my car doesn't make a noise when it's in park or neutral, so hopefully that's the case.
Last edited by superwashcycle; 10-03-2012 at 04:37 PM. Reason: oops, I have more to say!
Old 10-03-2012, 04:44 PM
Mein Auto: 325is
once again... i've replaced both pulleys. my car doesn't use the third idler pulley found on most other versions of these engines therefore i don't have one...
Old 10-03-2012, 04:48 PM
DIY lifestyle.
Well, I think the alternator bearing can also cause this noise?
Old 10-03-2012, 05:12 PM
Mein Auto: 325is
i'll report back if i make any findings!
Old 10-03-2012, 10:15 PM
Mein Auto: 325is
So i bought a mechanic's stethoscope and placed the rod on the tensioner with the engine running. there is a pretty loud noise coming from the assembly, like something banging around inside (no its not my vanos lol). anybody know what one of these things look inside and what could be broken?
Old 10-04-2012, 10:24 AM
bmw-mania bmw-mania is offline
Mein Auto: BMW
Maybe...
YOU SHOULD CHECK, INSPECT, REPLACE THE TENSIONER.
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 10-04-2012, 10:33 AM
Mein Auto: 325is
Originally Posted by bmw-mania View Post
Maybe...
lol... im just trying to proceed carefully, in the past ive thrown parts at problems before and it just ended up being misdiagnosis. doing research it seems like this is not a very common problem.
