5 speed whining - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 10-04-2012, 01:33 AM
BmwMan92's Avatar
BmwMan92 BmwMan92 is offline
I <3 my E34
Mein Auto: 1985 318i// 1988 325e
5 speed whining
Hey guys got the 5 speed swap completed. But there is a wine that sounds like its coming from the transmission, every gear could it be low on fluid? No grinds or anything out of place what could this be?
Brandon
http://www.facebook.com/brandon.m.fore
Originally Posted by v8bimmer View Post
I just dont see any other logical way around this problem.
Old 10-04-2012, 05:07 AM
E30-325's Avatar
E30-325 E30-325 is offline
Mein Auto: BMW 325is
did you check/change the fluid before you put it in?
im guessing the whining wasnt there before the swap?
Old 10-04-2012, 07:11 PM
downhiller's Avatar
livin large
i had a whining noise in my tranny. grant it my 1st gear synco was shot, but even with new fluid still made the noise.
Old 10-05-2012, 01:55 AM
BmwMan92's Avatar
I <3 my E34
No I didn't =( stupidly lol. Its not first its every gear I'm kicking myself in the a$$ for putting a used throw out bearing in. It makes a howling noise without my foot on the clutch, I'm thinking that is my problem.
I also re used my csb from the auto
Buut I spent every dollar I had on all necessary parts for the swap and went in with little knowledge so I guess that was my mistake being to impatient but income taxes are soon so my e30s christmas will be coming early. Taking her to the body shop and getting every knick and dent fixed then getting her resprayed factory swartz then iridium plugs, new wires, cap, rotor, timing belt, valve adjustment, etc. So I'll just add a full trans service in that equation
Brandon
Old 10-05-2012, 08:10 PM
downhiller's Avatar
livin large
pop the fill plug out and see what the color of the fluid is. if its the typical colors, internals are fine and most likely throw out bearing, if its silvery, youll be looking at a tranny rebuild or a better tranny
Old 10-05-2012, 09:12 PM
BmwMan92's Avatar
I <3 my E34
Its clear green or yellow
Brandon
Old 10-05-2012, 10:01 PM
BMWFatherFigure's Avatar
Old School
Make the throw-out clear the clutch for a test and see if the noise goes away. Then press the pedal and see if the noise comes back. Bearing change here we come...................
Current:
E38 Parts Car
Previous:
Old 10-06-2012, 05:19 AM
BmwMan92's Avatar
I <3 my E34
Yes throw out bearing is bad lol so is that my problem?
Brandon
Old 10-06-2012, 05:44 AM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
Oh my that's quite a job to throw old used parts back in. My $$ is on the bad TO and a lame input shaft bearing or pilot ,or all 3 bad is the most likely scenario.
Old 10-06-2012, 02:54 PM
BmwMan92's Avatar
I <3 my E34
Pilot its new
Brandon
Old 10-06-2012, 06:59 PM
Old School
TO or input shaft brgs. All out and start again. Another chance to get the engine bay clean and tidy.............
Current:
E38 Parts Car
Previous:
Old 10-06-2012, 09:47 PM
BmwMan92's Avatar
I <3 my E34
Didn't pull the engine
Brandon
Old 10-07-2012, 08:43 AM
On Top
Oh you opted for the easy way eh?
So much easier to pull/drop IMO.
Old 10-07-2012, 12:54 PM
BmwMan92's Avatar
I <3 my E34
Yeah I didn't want to pull the engine. But I'm regretting it now (tore engine mounts).
Brandon
Old 10-09-2012, 05:47 AM
BruceJM BruceJM is offline
BruceJ
Mein Auto: E30 vert, Z4 Si, 330i
Sorry that happended to you but still not to bad - engine mounts are cheap. I think that even the OEM's are under $30 each
Good Luck
Life's Good!
2011 335is vert
03 330i - Mods: MTechII front Bumper, 162K and rollin!
88 & 89 E30 Verts
05 Mini S Hatch (DD)
07 Z4Si - (Gone, but not forgotten)Mods: M front Bumper, Mstache, Alarm, Hardtop Retrofit & Hardtop, mudflaps, windscreen, DaveZ GDO, Intravee II, Gaptech Remote +, Diet hamburgers and a Fat steering wheel.
