E30 (1982 - 1993)
Old 10-04-2012, 04:21 AM
casino1 casino1 is offline
Mein Auto: e30 / e46 3 series
e30 318i 1989 idle problems
my poor bm when i start the car the engine idle surges up and down then cuts outs 6/7 times i start it same thing drive the car cuts out when i stop but after 5 min when engine warm its ok but still have erratic idle and still feels like it wants to cut out took icv off cleaned made no diffrence any one got any ideas
Old 10-04-2012, 08:08 AM
Billwill Billwill is offline
Mein Auto: BMW E30 318i 1991
OK you obviously have the M40 motor.....same as me!
Firstly for cold start idle problems you need to check out the Blue Temp sensor...located under the intake manifold next to the Brown sensor which drives the temperature gauge.
With a bit of fiddling you can get to the sensor but it is best to actually measure it first at the ECU connector. What you are looking for is that with an Ohm-meter you need to measure about 3,000 Ohms on the sensor when cold which then should go down to about 300 Ohms when hot. This sensor tells the ECU what temp. the engine is at so that the ECU can vary the fuel mixture.
Next you need to check all the vacuum hose for air leaks...it is best to spray some Carb Cleaner around all the air hose while the engine is at idle to listen for a change in engine note. Also spray around both sets of intake manifold gaskets as you may have a gasket leak.
Then...make sure that no idiot has tried to adjust the idle by turning in the throttle return stop screw....this is a screw with a locking nut on it that is factory set and sealed with paint.
You need to back out this screw while observing the butterfly inside the throttle body...the butterfly needs to slightly close all the way home...no visible gap.
Now with the throttle relaxed...make sure the throttle cable is not too tight...move the throttle linkeage slightly...you should hear at slight "click" as the throttle come to rest...clicks again as the throttle is moved slightly.
This is the Throttle Position Switch or TPS which is a micro-switch located under the throttle body. This tells the ECU that the throttle is at rest and so the ECU sets the idle speed correctly.
Likewise you need to test this switch is working at the connector at the ECU.
Best place to get more information on the M40 and the ECU pinouts is at the UK club:
http://www.e30zone.net
Old 10-05-2012, 09:13 PM
BMWFatherFigure's Avatar
Old School
All of the above plus clean out the idle control valve.
Current:
E38 Parts Car
Previous:
Old 10-06-2012, 05:19 AM
"took ICV off cleaned made no diffrence"......from casino1
Old 10-06-2012, 06:24 PM
Old School
OK - Shot my self in the foot on that one. Did the ICV get blown thro with compressed air to clear blockages? Also is the ICV the type with the moving slide? The 'book' test is to shake the unit and check resistances. If the ohm meter is attached and the unit moved over its operating range with a pencil or similar you might find a 'dead' part of the track - no fix only replace.
Current:
E38 Parts Car
Previous:
