E36 (1991 - 1999)
Old 03-15-2012, 09:45 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
You don't say? I've never noticed that
-CJ
Old 03-15-2012, 09:47 PM
crisscross's Avatar
crisscross crisscross is offline
Just living MY dream
Mein Auto: 1995 M3 Boston Green
Sarcasm?
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3(sold) 2000 TiAg 4.4l X5(sold)
-2000 F250 V10
-2004 GMC Yukon Denali
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 03-15-2012, 09:49 PM
cj.surr's Avatar
some kid
Nope, no sarcasm. I never knew that pinhole was there. I thought the only way to lock the flywheel was to bolt one of those backets from the flywheel bolt to the bellhousing bolt.
-CJ
Old 03-15-2012, 09:51 PM
crisscross's Avatar
Oh, yeah its pretty cool. I didn't know it either until I rebuilt my vanos and changed my HG.
-Alan
-2000 F250 V10
Old 03-15-2012, 09:54 PM
cj.surr's Avatar
some kid
Hmmm I guess that means to use that feature, there's a certain orientation the flywheel has to be bolted on by? I've never paid attention to that. :/
Well, I'll be changing the flywheel this weekend, so I'll get a second chance
-CJ
Old 03-15-2012, 09:59 PM
crisscross's Avatar
Yep, look for the hole in the bellhousing and bolt it lined up with the hole with the motor at TDC. You don't have to take off the valve cover to see, just use a mirror and look at the timing marks on the crank
-Alan
-2000 F250 V10
Old 03-15-2012, 10:05 PM
cj.surr's Avatar
some kid
Cool. Easy enough.
-CJ
Old 03-17-2012, 04:17 PM
MrToSlo MrToSlo is offline
Mein Auto: 1996 BMW 328i
Originally Posted by drivinfaster View Post
ok, this is twice...where are you guys getting the idea that the hub needs to be replaced?? i am not aware that this is a wear part, and subject to needing replacement on occasion. it is also not like a bearing that could be damaged upon removal, so i don't think that would be it.
please essplainz, as i are confuzzeded...
there is no explanation as to why the hub was replaced in the thread...i checked...
df
i don't think it's required, but like u said it's on occasion. my mechanic suggested it's a good idea to replace the hub while we have access to it (preventive maintenance).
good thing he has 450 ft lb air gun for the crankshaft bolt.
Old 10-04-2012, 09:36 AM
Kiefer09 Kiefer09 is offline
Mein Auto: 1998 318is
So I take the belts off then take off the pulley , do I need a harmonizer too?
Old 10-04-2012, 08:13 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
only if you sing 'o canada'....ed will be the bass...
but no, you should not need to replace 'hard parts' like that unless physically damaged.
df
Old 10-05-2012, 09:41 AM
Haha ok , I will post a picture of the oil leak later today. I just want to make sure it is that front crank seals before i rip it apart.
Old 10-08-2012, 01:13 AM
Double checking
http://www.realoem.com/bmw/showparts...85&hg=11&fg=10
So im wanting to replace the crankshaft seal so i need #3
http://www.pelicanparts.com/cgi-bin/...0%281991-99%29
and the crank bolt
also getting the bolt off and on can someone make a list of the tools required please
Old 04-04-2015, 11:49 AM
jair24611 jair24611 is offline
Mein Auto: 1997 318i
Anybody have a picture of where this flywheel locking pin hole is, in the bell housing? I'm doing my front crank seal and crankcase seal to try and solve a long-time minimal oil leak.
There are a few different homemade techniques for holding the crank/balancer in placer, but I kind of want to have that Pin in there as support to the other homemade methods.
Old 04-05-2015, 12:35 AM
hornhospital's Avatar
D'oh, You Kids!
The pin hole is next to the starter Here:
Quotes to live by:
Old 04-05-2015, 02:29 PM
Thanks. Anybody know for certain if the flywheel locking dowel pin is guaranteed to be safe and sufficient enough, by itself, to hold up when breaking loose the 300+ lb torqued crank bolt?
