E36 (1991 - 1999)
Old 07-10-2012, 11:33 PM
Dakota_leWarne Dakota_leWarne is offline
Mein Auto: 1994 318is
sounds good, i plan to remove the cat and just weld in a straight pipe, are there any issues with that?
"if you look close enough... youll see my bumper is being held together with zip ties
Old 07-11-2012, 07:03 AM
veteran011's Avatar
veteran011 veteran011 is offline
WARNING: Has Dumb Ideas
Mein Auto: 97 328is
if you wanna go straight pipe there are no issues as long as you:
A) dont live in california (and you dont so props)
B) dont have OBDII (which you don't so consider yourself a lucky bastard).
dab of oppo anyone?
Project List:
Replace coolant temp sensor
Replace starter
Brake and Power Steering Fluid Flush
Front Control Arms, Bushings, and Tie Rods
Replace Passenger Lock Actuator
Reglue Peeling Hedliner
Swirl removal
Old 07-11-2012, 08:25 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Yea, what he said. I'm a little worried about my S/C M3 passing smog next year.
GGC BMW CCA #443004
Join the BMW CCA!
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
Old 07-11-2012, 09:44 AM
bmw-mania bmw-mania is offline
Mein Auto: BMW
^ FCK smog.
If you need some smog tippery.. I've got a some goodies.
I run a hi-flow CAT on almost all my cars.. Just cuz.
No need to gross pollute for no reason.
Straight pipes are for track.
You will actually appreciate the driveability of the car WITH a CAT
rather than the car WITHOUT a CAT.
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 07-11-2012, 11:06 AM
ok thanks for the opinions, my cat seems to be worn down and rattling, so i think untill i can afford to buy a newer cat ill just delete it.
Old 07-11-2012, 11:15 AM
veteran011's Avatar
Mein Auto: 97 328is
if it already passed smog then just leave it. no reason to spend more money.
dab of oppo anyone?
Project List:
Replace starter
Swirl removal
Old 07-11-2012, 12:00 PM
Mein Auto: BMW
Originally Posted by Dakota_leWarne View Post
ok thanks for the opinions, my cat seems to be worn down and rattling, so i think untill i can afford to buy a newer car ill just delete it.
I say blow the fck-er out..
Run it until you have to replace.. Its just exhaust.
Since you dont have emissions, and visual inspection, just let it ride.
Old 07-11-2012, 03:25 PM
new o2 sensor in, cut off the cat and welded it up, has ALOT more power now and the check engine light does not come on.
For the record i know that the power gain is more then likely from having a working o2 sensor and not the cat, just though i would put it out there.
Old 07-11-2012, 04:01 PM
Mein Auto: BMW
THANK GOD!
Chopped it out anyway huh?
Meh..
might be time to do a full exhaust with removable cat/center pipe.
edit:
Doesnt feel good knowing that you've done this work?
That everything is FUNctional?
Your car rips now!
Im excited for you.
Old 07-11-2012, 05:18 PM
AGREED HOMIE!
Yeah i did the whole exhaust was pretty choppy already and whomever installed the last cat ****ed it up ( pictured)
my to do list includes cosmetics, exhaust, and brakes so im not too worried
AND Yes, it really does, its been alota work but its a great feeling knowing everything that wares out is new or newer.
Old 07-12-2012, 10:10 AM
Mein Auto: BMW
AGREED HOMIE!
Real hyped for you.
Glad you overcame adversity.
That exhaust is 2D.. no wonder it wont work on your car. j/k
When you do your exhaust.. PROPERLY..
Minimize bends..
I hate flanges.. so i went for v-bands.. a world of difference..
Make your cat/centerpipe removable.. for those "occasions"
And lastly... AVOID RICE.
You've come a long way.. Congrats. :
Old 07-17-2012, 02:08 PM
Mein Auto: BMW
Umm... strange question..
How far are you from Lake Oswego?
Old 07-19-2012, 01:41 PM
no too far at all, maybe 30 minutes. Why do ya ask
sad news of the day.. i was just rearended. luckily i saw it coming and was able to start moving away from the oncoming car but shes still smashed up
Old 07-19-2012, 01:56 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
Gah, what a bummer! What's the damage? Any way to turn this situation around to your advantage?
1998 BMW 328is
1966 Pontiac GTO
Old 07-19-2012, 02:15 PM
the bumper is trashed, the section in between the trunk and bumper is mangled, the exhaust tip is bent, one tail light has a small crack, the spare tire well is bent so i cant get it out, the rear bumper support is smashed in, im assuming that the trunk lid is bent too as it wont close properly,
just looking at it it seems very minor, sadly i think its a bit worse then it looks.
im on the fence of weather or not to try and get them to total it or not. Any idea what they would try and give me? if not im gonna fix it myself and get a nice check.
Old 07-19-2012, 02:46 PM
Mein Auto: BMW
What? NO WAY!
That is absolute horsesheet!
Widebody kit time.
Old 07-19-2012, 03:05 PM
ZeGerman's Avatar
Warm Leatherette
Oh, there's no question they're going to total it. It's only a matter of whether or not you want to keep the car and fix it yourself. Repairing the section underneath the truck between the tails requires cutting out the entire section which includes the taillight sections and welding in a replacement. In other words, not a super quick repair... You're a resourceful fellow, though, so I'm sure you could figure out a way to get it done. On the other hand, it seems that insurance adjusters tend to provide good payouts for E36s, so you might be able to scrap it and get a nicer one.
1998 BMW 328is
1966 Pontiac GTO
Old 07-19-2012, 04:36 PM
oh there is no doubt ill buy it back if its totaled, just weather or not it i would keep it or just part it out. we will see as time goes on what the outcome will be.
Old 07-19-2012, 04:39 PM
petriej's Avatar
Wow, and you just finished working on it! Unbelievable.
GGC BMW CCA #443004
Join the BMW CCA!
Old 07-19-2012, 05:57 PM
yup mechanically it was done, some cosmetic work and it would have been done, sadly.. **** happens, and life goes on.
Old 09-07-2012, 02:11 PM
UPDATE
The insurance finally decided they would work with me and payed out $3300 and threw in the car for free.
current condition
ID:	340804   Click image for larger version
Old 09-07-2012, 02:17 PM
petriej's Avatar
Congrats!
GGC BMW CCA #443004
Join the BMW CCA!
Old 09-07-2012, 03:11 PM
ZeGerman's Avatar
Warm Leatherette
Sounds like a deal to me!
1998 BMW 328is
1966 Pontiac GTO
Old 10-04-2012, 10:05 AM
Mein Auto: BMW
Amazing.
Congrats Dakota!
Im glad your were able to prevail.
VICTORY!
