E46 (1999 - 2006)
Old 10-03-2012, 06:05 PM
LPenna LPenna is offline
325i Guy
Mein Auto: 2001 BMW 325i E46
Angry What my problem???
Can someone please help me find my issue with this check engine light.
I have a 2001 325i e46. I fail smog and had these part changed and I still get the check engine light after 80 miles of resetting the light. i change the MAF with the air tube and clean the ICV which did not look very bad after having 112k on the car. I also change all 4 O2 sensors. Change of spark plugs also.
I have peake code reader and only two code come up saying E3 and E4 O2 sensor adaptation limit cyl # 1-3 and 4-6.............
What is my issue......please help me....
Old 10-03-2012, 11:32 PM
harryhchen harryhchen is offline
Mein Auto: 2001 325i / 2002 530i
so what are codes?
Old 10-04-2012, 12:09 AM
scarede46er scarede46er is offline
Mein Auto: 2001 BMW 325i ZSP
I have peake code reader and only two code come up saying E3 and E4 O2 sensor adaptation limit cyl # 1-3 and 4-6............."
Old 10-04-2012, 06:46 AM
CPBIII CPBIII is offline
Mein Auto: 2002 325i
take your car to a local parts store that will read the OBDII codes. Better if they can provide the BMW codes which alot of readers will do.
Old 10-04-2012, 09:39 AM
325i Guy
Problem in California is that store ain't allow to do that any more. I was surprise also. Should I just buy a new code reader??
Old 10-04-2012, 09:44 AM
You can get a ODBII reader for around $20 from Amazon. Here is what I have:
http://www.amazon.com/Autel-MaxiScan...s=ODBII+reader
Old 10-04-2012, 12:26 PM
325i Guy
What the difference between this one and the ones that are bigger and little more expensive. Does those one give more info, Or does it do the same job?
Old 10-04-2012, 01:56 PM
Check the specifications and find one that will provide manufacturer specific codes. Probably won't be the $20.00 plan.
Old 10-04-2012, 09:36 PM
chansta chansta is offline
Learning Daily
Mein Auto: 89 CIVIC
those are adaptation codes. most likely your car is running lean due to a vacuum leak. probably cvv needs to be changed.
iATN
