Old 08-12-2011, 06:40 AM
Baldman Baldman is offline
Mein Auto: 2003 530I
E39 Alarm Problems
My alarm seems to always go off on my 2003 530 after I've parked and locked the car. Is their a sensitivity level or something else that's wrong? Thanks for the help!
Old 08-12-2011, 06:46 AM
bmw_n00b13's Avatar
Freude am Fahren
Send a message via MSN to bmw_n00b13
Mein Auto: 99 528iA
Is there a dog in the car when you lock it? There's a motion sensor in the car.
Check here: http://www.bimmerfest.com/wiki/index...9#Alarm_System
- How to understand the BMW E39 EWS alarm drive-away protection system (1) (2) & troubleshoot the alarm & hood switch (1) (2) (3) (4) or replace the siren (1) or disable the unlock chirp (1) (2) & how to maintain (1) and repair your hood release bowden cable (1) (2) (3)
'99 528i ('98/12 build). 174,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals
'99 540i (grandfather's)
Old 08-12-2011, 06:55 AM
Thanks, n0013. No dog in the car! Appears it goes off even in calm areas, such as my garage at home which is sheltered from wind and vibration.
Old 08-12-2011, 07:13 AM
thecushion thecushion is offline
Mein Auto: 02 s55 AMG,02 540i
Hood Pin switch.
Old 08-12-2011, 09:09 AM
Thanks, thecushion. I'll give it a try!
Old 08-12-2011, 09:25 AM
adjmcloon's Avatar
adjmcloon adjmcloon is offline
Mein Auto: '99 528iT sport
This issue can also be indicative of a battery on its way out. Check your voltage
2001 530i tiAg sport (sold)
2002 540iA sport (sold)
2006 330i sport (sold)
2008 535i-6 sport (sold)
1999 528iT sport (sold)
2002 525iT alpine sport
1990 325i sedan
1990 325is coupe
Old 08-12-2011, 09:42 AM
CoreyMNK's Avatar
CoreyMNK CoreyMNK is offline
Corey
Mein Auto: 2000 528i Step 215K Miles
I would check the hood switch first, this happened to me too... low and behold, my hood switch was falling out of its holder thing. I have it zip-tied in now.
2000 BMW 528iA Step- 223K Miles- Aspen Silver
  • Dinan Engine Software
  • Smoked Sidemarkers
  • Smoked Turnsignals
  • Shadowline Trim (Plasti-Dip)
  • Fittipaldi Wheels
  • Muffler Delete
  • Beisan Vanos Seals
  • Umnitza MTech Rear Bumper
2004 Volvo V70R
2005 Nissan Armada SE OFF ROAD
Old 08-12-2011, 10:57 AM
Syprist Syprist is offline
Mein Auto: BMW e39
My speed sensor went on me and the exact same problem happened. Replaced the sensor and no issues so far. My dads VW Jetta had the same problem as well. His alarm was going off at 2,3, sometimes even 4am until he replaced his sensor. Is this common in German Cars?
Cheers
Old 09-01-2011, 10:44 AM
Hood Pin Switch was the problem. Replaced for $25 and no problems since. Thanks for all the help.
Old 09-01-2011, 04:53 PM
chiefwej's Avatar
chiefwej chiefwej is offline
Freude am Fahren
Mein Auto: 2003 540i/6 //m-tech
Just unplug the hood switch (on the front corner of the drivers side cabin filter) and I'll bet the problem goes away. If so you can replace the switch or just leave it unplugged. That's the source of most false alarm issues.
chiefwej 2003 540i ///m-tech 6-speed
Black Sapphire Metallic w/gray
Old 09-01-2011, 04:58 PM
dalekressin's Avatar
dalekressin dalekressin is offline
Mein Auto: 2010 M3
Yeah, I learned about the dog & alarms too
94 530i sold (That was difficult for me)
01 530i >144,500+ miles SOLD
06 330XI winter's especially fun drive (SOLD)
10 M3 Sedan (sweet)
13 Nissan GT-R Black Edition
13 Porsche Cayenne Diesel
BMWCCA 4215
Old 05-03-2012, 02:18 PM
txtigr txtigr is offline
Mein Auto: E39 530i Sport
E39 Alarm Problems
I have seen several threads for the alarm going off at random. My E39 530i started the same issue. I replaced the hood switch and it still went off at random. I unplugged the interior sensor, and it still went off at random. I removed fuse 48 from the trunk fuse panel, and even though siren would not sound, lights would still flash while alarm was going off at random. Come to find out that there is an updated hood switch, that originally came off the X5, with a longer plunger. When I had the alarm code read, it said the hood was opened 31 times. I picked it up from my local dealer for about $18 and no problems at all now. Hope this helps some of you.
Old 10-04-2012, 02:36 PM
EconoBox EconoBox is offline
Mein Auto: 2001 530i (E39) 120k
I am having this nightmare issue today.
The alarm only goes off when I access the car (unlock via the key)
I disconnected the hood latch socket. Alarm still goes off.
I pulled out Fuse 48 in the trunk. This actually set off the alarm again!
I will now test the battery voltage, but I've had low voltage before and never had the alarm fritz! (12.6v off and 14v on)
I can lock it twice to disable interior sensor, but that's not my issue (the key unlock sets off the alarm)
Just in case, is it easy to unplug the interior sensor??
PS: I HATE car alarms. Is there a wire I can just cut?
This is only one step below your car being on fire.
I'd rather have my tranny die, honestly. Less drama and attention.
Old 10-05-2012, 03:26 PM
A new battery seems to have solved my car alarm issue!
I was locking and unlocking the car with glee (and silence)
As a postmortem, I did notice my door locks were occasionally acting "weak" over the last few weeks.
Sometimes, they'd hesitate when unlocking (weak battery?).
I also noticed I had to sometimes unlock again when they first try seemed to abort/stall.
Otherwise, there was no indication of a low battery.
The locking/unlocking now seems more "crisp", but I'm not sure if that's the placebo effect.
A new 49-DL was $118 out the door at AutoZone. Here is the DIY
Even if this isn't the real culprit, I don't mind dropping $100 on a service item. My Excide was about 2 years old, FWIW.
It's been 5 months since anything has gone wrong with my E39.
