Old 10-04-2012, 11:58 AM
helpmyfive helpmyfive is offline
Mein Auto: 528i
Light Control Module replaced but problem persists
SORRY to post a new thread, but I'm in a rush at work and DESPERATE for knowledge. Recently I replaced a transistor on the LCM to fix the headlight stuck on issue. It sort of worked. I bought 4 more transistors to fix the flickering problem but never got that far.
Lesson to other dummies out there: disconnect the battery before removing/installing the LCM!!!
I was reinstalling the LCM and bumped the heat sink on the bracket behind the glove box. SPARK!!! Now I have half the lights I used to. No fuses are blown, and it doesn't appear the bulbs are bad, but I have:
1 dim headlight on the driver side
1 bright headlight on the passenger side
1 blinker on the right rear ONLY
2 tail lights
0 driving lights
Dash indicates passenger and both rear bulbs out.
REPLACED the LCM with a salvage yard part (looked identical). No difference with the lights or dash at all.
What am I missing? Does the LCM need to be coded to work at all? I'm ok with an indicator that I tinkered with the electronics. Is there another fuse somewhere I'm missing? Is there a relay for the LCM? Nothing seems to be wrong, but I have lights out and a dash lit up.
I tried removing the battery cables and crossing for 15 mins. No difference.
I guess my question is: What tells the dash the light is out? Where is the power stopping and not getting to the bulb? The switch? The plugs? Anything?
Old 10-04-2012, 01:41 PM
acoste's Avatar
acoste acoste is offline
Mein Auto: 2010 550i MT
LCM has 4 fuses (no relays): F112, F113 under the carpet on the passenger side, F16, F41 in the glove box. Maybe one of the big F11x fuses is out.
Old 10-04-2012, 03:52 PM
champaign777's Avatar
had similar battery issue with GM module
Lesson to other dummies out there: disconnect the battery before removing/installing ANY BMW module
try this
disconnect battery
reconnect LCM module
clean errors in DIS/INPA and check LCM status
http://www.bimmerfest.com/forums/sho...416&highlight=
Old 10-04-2012, 06:04 PM
Mein Auto: 528i
Acoste: YOU ROCK!!! I tested F111 and F112 and found F112 was dead. Made a makeshift fuseable link till tomorrow and we're good to go! THANK YOU THANK YOU!!!!!!!
Old 10-05-2012, 06:34 AM
Mein Auto: 528i
Update: I should have my car taken away from me. I did something stupid. When I made a fuseable link to temporarily mend the problem I used too weak of a fuse and too small of gauge of wire.
Got in the car this morning and the fuse popped. NO problem, I'll just cross the wires since I know all the systems are fine. That way I can get to work and buy the proper fuse from NAPA.
Crossed the wires and they lit up like a light bulb. The car started smoking and I did all I could to pull the battery terminal. Meanwhile my 7 year old daughter is trying to show me her magnetic ducky. NOT NOW!
I got all the power off and waited a sec for the red hot wire to cool. I got the trim piece off and yanked the carpet up. The burned carpet. Then I removed the melted foam blocks a piece at a time. Underneath was a cloud of smoke and melted wires.
I removed all the schrapnel and got the car back to just "broken". I stopped by NAPA and got the correct fuse. Conclusion to this debacle later.
Old 10-05-2012, 06:54 AM
Mein Auto: 528i
just an FYI. I did a little research. The fuse for the LCM is an 80amp, NOT a 50amp like the first one on the block. CHECK THE BMW PART NUMBER BEFORE YOU REPLACE ANY!
Back to the store for a replacement. Good thing I thought to check before I put it in and blew it.
