Old 10-04-2012, 08:41 AM
kcornwell kcornwell is offline
Mein Auto: 2006 330i
Need advice: One of my spark plugs is "gummy" (see picture)
My mechanic said these were the original spark plugs with 63,000 miles on the car. Should I be worried about the gummy spark plug?
Old 10-04-2012, 10:35 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Yes.
Old 10-04-2012, 10:40 AM
The X Men The X Men is offline
Mein Auto: 2013 X3 35i
Looks like something is not right inside that cylinder.
Old 10-04-2012, 05:18 PM
DSXMachina's Avatar
Bimmerdex 7.4!
No.
Put the new plugs in. If it runs good leave them in for 5K miles and check again. My informed opinion: the plug will be clean.
(Anyone else notice all that blow-by on the porcelain of all the plugs?)
Old 10-04-2012, 07:46 PM
Originally Posted by DSXMachina View Post
No.
Okee Dokee....why should it clean up?
Saw - looks like blow-by. How's that happen on 'em all?
Old 10-04-2012, 07:47 PM
Which cyl?
Old 10-04-2012, 09:37 PM
aleks001 aleks001 is online now
Aleks
Mein Auto: 2006 BMW 325i
I could be wrong, but after that many km's I've never seen different looking spark plugs in any of the cars I've ever had. Looks pretty normal too me.
Old 10-05-2012, 09:58 AM
Originally Posted by CALWATERBOY View Post
Which cyl?
Sorry, not sure which cylinder.
Old 10-05-2012, 10:57 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Because the plug is what was causing the poor burn and by replacing the plug he eliminates the cause of the fouling. In a situation where I have no evidence to the contrary I always go for the simplest explanation. It has saved me hundreds of diagnostic hours on very complex systems. I would install new plugs and have him drive it a few thousand miles, then pull the plug for another check. It's very cheap diagnostics because it means he doesn't have to pay a tech hours of labor to find a problem which may not exist.
The blow-by is due to a poor seal between the porcelain and the steel. We see a lot more of it nowadays and I think it's due to a change in the manufacturing process. It can get so bad it burns the inside of the boot, causes carbon tracking, and then a misfire. The deposits on these plugs don't indicate a critical situation yet, it can get much worse.
Old 10-05-2012, 12:02 PM
Because the plug is what was causing the poor burn and by replacing the plug he eliminates the cause of the fouling. In a situation where I have no evidence to the contrary I always go for the simplest explanation. It has saved me hundreds of diagnostic hours on very complex systems. I would install new plugs and have him drive it a few thousand miles, then pull the plug for another check. It's very cheap diagnostics because it means he doesn't have to pay a tech hours of labor to find a problem which may not exist..
Y'see? I glossed right over the NEW plugs...assumed same plugs reinstalled. My bad.
And, a good reminder to pull 'em now & then for inspection.
Old 10-05-2012, 04:08 PM
DSXMachina's Avatar
Bimmerdex 7.4!
...and another thing...notice the threads on the "fouled" plug compared to the rest. Also look very closely in the area between the seal ring and the base of the plug. What do you see? What is your theory as to why all the threads are dirty, and why there are deposits at the seal?
That's the reason this plug looks like it does.
The bill is in the mail. Now let me enjoy my weekend.
Old 10-05-2012, 05:02 PM
galahad05's Avatar
galahad05 galahad05 is offline
Better with Butter
Mein Auto: 335i sedan 6MT
Running rich? That kind of doesn't make sense, what with O2 sensors and tight ECU control and all....
Don't resent growing old. Many are denied the privilege.
-- Irish Proverb
Old 10-05-2012, 06:01 PM
DSXMachina's Avatar
Bimmerdex 7.4!
The ECM can tell which bank of three cylinders is too rich or too lean, and can kind of infer which cylinder it might be. The problem this plug experienced resulted in a condition for which the ECM could not make a sufficient short or long term adjustment in that cylinder.
So we need another possibility which is the likely culprit.
Hint: It was neither spark nor fuel, nor that the plug was excessively worn.
Old 10-05-2012, 09:05 PM
galahad05's Avatar
Better with Butter
Improper gapping, maybe.
-- Irish Proverb
Old 10-05-2012, 09:53 PM
DSXMachina's Avatar
Bimmerdex 7.4!
The gap looks OK to me. No need to gap these, they come set to spec and are usually good out of the box.
Here's why the plug is a little more carbon covered than the others: the compression pressure in that cylinder was enough to result in combustion and enough expansion to prevent a detectable skip, but not high enough to result in a clean burn. Why? Because some of the compressed mixture was leaking out past the sparkplug which was not properly torqued down!
That's why you see the carbon all the way up the threads and packed under the seal.
Old 10-05-2012, 11:01 PM
galahad05's Avatar
Better with Butter
Ahhhhh.
-- Irish Proverb
Old 10-09-2012, 08:18 AM
Thanks guys for the prompt advice. Awesome Forum!
