9.5 width on the front XI? - Bimmerfest - BMW Forums
Old 10-03-2012, 03:59 PM
bighead2267 bighead2267 is offline
Mein Auto: E60 with a turbo
i'm currently looking for a set of 19 wheels for my XI.
it's a square setting 19 9.5 with ET 35. i ain't plan to lower but i'm worry the front will rub(inner)
any expert see a setting like this before or let me know if it works?
thank you
Old 10-03-2012, 06:04 PM
TLO03's Avatar
TLO03 TLO03 is offline
Mein Auto: 08 535 xit
I think it's doable I'm running 9" 35 et and I thought about spacers at adult ride height I'd say its a go.
Old 10-03-2012, 10:23 PM
Thx TL, u don't think it will run the inner? I doubt the outer will have problem since I see ppl running 30 or even 28.
Old 10-04-2012, 06:50 AM
TLO03's Avatar
6mm pushed in I do belive there room but I'll look in a bit. Edit my cars to low .. Can't fit my hand it.
http://www.willtheyfit.com/index.php...&Submit=Submit
Old 10-04-2012, 09:06 AM
thx for the info. does dish style wheels make a different for offset calculation.
TL, that's a nice wagon you got there.
Old 10-04-2012, 06:52 PM
TLO03's Avatar
For the manufacturing it dose i.e. typically the higher the offset the less concavity you can have. The style 128's in my sig pic are x3 fitment flushed out with spacers style 128's in a Rwd offset i think 20et or so have a much deeper dish. But for the end user these number are what they are.
I re worked the calculator with my stock setup your proposed wheels and my tires, it travel in 17mm that's a number you can measure tire to strut to see if you have that kinda clearence. Assuming you have typical oem xi setup..if not play with the website to configure your needs..
