E36 (1991 - 1999)
Old 10-04-2012, 10:24 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
Originally Posted by Time2Fly View Post
True but when you introduce spacers your wheels are no longer hubcentric...
:massive facepalm: WRONG. What do you think a hubcentric spacers is, anyway? IT IS STILL HUBCENTRIC! If it's made correctly, it will still result in a wheel perfectly centered on the hub
Originally Posted by Eight Thirty View Post
this is so incorrect........
i dont understand how people dont get this.
Neither do I. It's about as simple a concept as there can be.
If your putting your wheel on your hub... which makes your wheel hub centric right? no disagreeing that?
now.... you take your brake rotor and you make it farther out 1 inch. (lengths differing on spacer sizes... and you put the correct bolts on.
Assuming it is a CORRECT wheel spacer (meaning hub centric) it will STILL be hub centric with very little/no weight on the bolts.
Exactly.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 & New Member Intro Forum Mod/Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426 Which is worse, ignorance or apathy? I don't know, and I don't care!
1995 318is "Bebe"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 10-05-2012, 12:11 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
It's easy to see where Tim2Fly got a little confused, though. If you were to use a non-hub-centric spacer, then yes, it would no longer be hub-centric. But if you use the correct spacer (i.e. one that has a hub lip), it will remain hub-centric. This is why selecting the correct spacer for our cars is important. Now we can simmer down.
1998 BMW 328is
1966 Pontiac GTO
Old 10-08-2012, 07:01 AM
Time2Fly's Avatar
Time2Fly Time2Fly is offline
Sometimes Out To Lunch!!!
Mein Auto: 1993 318i 1994 325i 1998
Ok depending on the width of the spacers I guess this could be true also. When I look at the hubs on my 325 there isn't much between the wheel and the rotor to lose before your not on the hub. Your comment eight thirty make some sense until you get to the rotor part, you make it sound like you put the spacer behind the rotor I'm sure your not serious about that just want to clear that up.
Old 10-08-2012, 07:49 AM
Eight Thirty Eight Thirty is offline
Hellawut??
Mein Auto: who knows?
what i meant by that was you put the spacer sitting flush against the rotor moving the "face" of the rotor out farther.
just trying to help people understand what i was meaning. haha.
-Franklyn
Old 10-08-2012, 09:49 AM
ZeGerman's Avatar
Warm Leatherette
I find the idea of moving the "face" of the rotor confusing, also. The rotor obviously does not move at all when spacers are added, but I guess what you're getting at is that the distance between the rotor and inside of the wheel is increased, since this is usually the intended purpose of spacers.
1998 BMW 328is
1966 Pontiac GTO
