Old 10-04-2012, 02:16 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Obligatory picking of nit: The outside-temperature warning sounds at +3 C / +37 F (actually +37.4 F), not 38 F. Everyone citing 38 F, go to the back of the bus, now. (We need you back there for traction in the event of black ice. )
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47° 35' 30.13" E11° 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 10-04-2012, 03:12 PM
BobBNY BobBNY is offline
Mein Auto: 2015 535d
Originally Posted by rtgirard View Post
Every time that asterisk illuminates I get a nasty kink in my Hofmeister.
I hate when that happens. Need to put a sweater on it!
BB
Old 10-04-2012, 05:03 PM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK/335d
Check original cite, Less than 38 degrees. N4S
Old 10-04-2012, 05:15 PM
craignet craignet is offline
Mein Auto: 08 328i Alpinweiss Coupe
And here I thought it meant that the hyper-space drive was online and the worm hole was about to open!
Old 10-04-2012, 06:10 PM
Zeichen311's Avatar
Old 10-04-2012, 07:22 PM
pointandgo's Avatar
Originally Posted by Zooks527 View Post
Ice doesn't form at a temperature of 38 degrees, but it can certainly form on a road surface that drops below the air temperature.
Posit a situation where it is a 38 degree night, crystal clear, with no wind. The road is radiating IR in all directions. In most directions, there is an object of similar temperature radiating IR back at it. But, we've said it's a clear night. The road is radiating IR towards the clear sky, but is receiving no IR from the (approx) -450 degree section of interstellar space in the opposing direction. The road loses temperature continually, dropping below the freezing point even though the air around it is several degrees above freezing. The effect is especially pronounced on bridges and overpasses. It's also why you first see frost warnings in the fall on clear nights, but not on cloudy ones.
You can do a demonstration with your car's front and rear glass to show the effect. Park the car so that there are branches with leaves above the rear glass, but nothing above the windshield. You will often find that frost or dew will form on the glass exposed to the sky, but not on the glass shaded by the leaves, as they are radiating back at the glass, while the exposed surface has dropped below the dew point / freezing point.
The reverse is the case during the day. The air temperature may be below freezing, but the portion of the road looking a the 10,000 degree ball of fusing hydrogen in the sky is raised significantly above freezing.
FWIW,
George
George,
Interesting post...but I've heard that NITROGEN in your tires will protect you from interstellar freezing on bridges. I have at least three good sources.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 10-05-2012, 02:24 AM
Zooks527's Avatar
Zooks527 Zooks527 is online now
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
Hah! If I didn't know you better, that quarter would have gone in the slot!
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 10-05-2012, 06:04 AM
55's Avatar
55 55 is offline
Mein Auto: 2016 BMW touring 328d
It is a symbol of Octoberfest. You will see it every October as a reminder not to miss it.
Old 10-05-2012, 06:30 AM
BiHoTTo115's Avatar
BiHoTTo115 BiHoTTo115 is offline
Mein Auto: 2006 330xi
Must be something wrong then, because I started drinking Oktoberfest-based beers long before I'll see my icon.
2006 330xi | 6AT | Navi | Premium | Cold Weather
Old 10-05-2012, 06:50 AM
andrew b's Avatar
andrew b andrew b is offline
flâneur en cabriolet
Mein Auto: 2007 E93 N54
+1 I don't normally see the asterisk until mid-late November, or early December. I thought it meant it was time to buy Christmas presents.
Old 10-05-2012, 06:56 AM
BiHoTTo115's Avatar
In that case, should be a $ symbol, and the gong should be changed to a faint voice telling you to "spend it!".
Old 10-05-2012, 07:46 AM
jmsent jmsent is offline
Mein Auto: 07 335i Coupe
I've been getting this indicator that looks like a light bulb. I think that means my car has come up with a good idea. I just wish it could tell me what the good idea is.
Sold-07 335i COUPE-SPACE GRAY-STEP-SPORT-PREMIUM-COLD-SIRIUS-RFT DELETE
Old 10-05-2012, 08:01 AM
55's Avatar
55 55 is offline
So, you don't need the reminder, otherwise I would recommed to call to you dealer to fix this malfunction.
Old 10-05-2012, 05:00 PM
chrisk03 chrisk03 is offline
Mein Auto: 2011 335i M-Sport
Originally Posted by chris328 View Post
Hey guys this morning I got up and it was real cold out, and after I started my car and went a little bit I got this dingy sound and a large asterisk symbol on teh dash. What is that??
Was your car wet, as well? Shrinkage...
2011 335i M-Sport, BMW Performance Powerkit Version 1, 35% F1 Pinnacle Tint
