Old 10-05-2012, 08:30 AM
8355adam 8355adam is offline
Mein Auto: 2006 330I ZSP
what make/model tires do you guys use for winter?
This is my first winter with a Bimmer. I've been checking out the differences between performace winter tires and studless snow/winter tires.
i know Bridgestone blizzaks LM-60 or WS60 are popular but Ive also wondered if the new Michelin pilot PA4 are worth the extra $$$ ($250 for 4)
I am expecting cold temps for 4 months and snow/ice for one week/year average.
What do you guys use for the winter...???
Old 10-05-2012, 08:35 AM
Orient330iNYC's Avatar
Flying monkey herder
Mein Auto: Daihatsu Terrios
dunlop wintersport 3ds.
the blizzak WS series will be squishy on dry roads compared to the LM.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 10-05-2012, 08:37 AM
galahad05's Avatar
galahad05 galahad05 is offline
Better with Butter
Mein Auto: 335i sedan 6MT
The last 4 winters: Dunlop Wintersport M3 DSSTs and Wintersport 3D (goflat).
This winter: Pirelli Sottozero Series II 240.
Don't resent growing old. Many are denied the privilege.
-- Irish Proverb
Old 10-05-2012, 09:46 AM
from what you describe (1 week or so of snow and ice, and the rest cold) i would go with a performance snow.
two of the top contenders are the bridgestone lm60 and the dunlop wintersport 3D.
the lm60 will be biased to snow performance (its the same tread pattern as the ws60, just without the tube multicell)
the 3d would be biased toward dry and wet road performance.
Sent from my Galaxy Nexus using Bimmer App
Old 10-05-2012, 10:03 AM
Zooks527's Avatar
Zooks527 Zooks527 is online now
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
I use Blizzak WS series. I deal with the squish on the dry to get the go in the snow. YMMV.
I do agree with Orient that VA would seem to indicate a performance snow rather than a snow/ice tire.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 10-05-2012, 10:14 AM
I have a staggered set up on my Summer's at the moment but there are very few winter tires including the BS LM60s and the 3Ds that have both 225/40 for the front and 255/35 for the back. Since the rear rim is only 0.5 Inch wider and will accept a 225/40 should i change to a sqaure set of 225/40 all round?
Old 10-05-2012, 10:34 AM
galahad05's Avatar
Better with Butter
Oh, you're swapping tires on the OEM rims then?
-- Irish Proverb
Old 10-05-2012, 10:45 AM
recommend going with a tire and wheel set-- the cost of mounts and balances will cover the cost of the rims within 2.5 years. going with 17s will cut the cost even more
runflat mount and balances run about 120-140, twice a year.
plus you wont subject your factory rims/tires to mount dismount damage, potholes, and sand/salt
Old 10-05-2012, 10:50 AM
BiHoTTo115's Avatar
BiHoTTo115 BiHoTTo115 is offline
Mein Auto: 2006 330xi
I'm getting new tires as well this month, but I was planning on going with just Continental DWS's, and swapping my current Conti SSR RF's with them. OEM wheels as well. I figure I'll probably sell the car before I swap to new tires...
2006 330xi | 6AT | Navi | Premium | Cold Weather
Old 10-05-2012, 10:57 AM
I'm pretty sure Im going to use the OEM rims and swap the tires. My reasoning is that i am moving to non-run flats for the winter and also next summer season. So i am spending money on a donut. I just dont have all the money in the world to buy new tires, rims just or winter and a $350 donut. Maybe when i have saved some extra i can take the next step and get some dedicated winter rims. So is it fine to go with thinner tires on the back for winter, i heard this may even be beneficial in slick conditions?
Old 10-05-2012, 11:05 AM
BiHoTTo115's Avatar
We have the same car, pretty much, and I'm doing exactly what you're doing, swapping out the RFT's on my OEM rims, and putting in (probably) new Conti DWS Non-Run Flats. I read they do excellent in rain and sleet, as well as snow in general. Pretty good for dry also. But I'm not buying until the end of the month, looking at all options.
Old 10-05-2012, 11:07 AM
Zooks527's Avatar
If you expect to be driving in snow (and it seems you don't) you want thinner tires, as they don't tend to ride up on the snow as much. OTOH, most of the world drives with same-width setups, and it shouldn't hurt you, assuming the tires you select are capable of being properly mounted on your (assumed) wider rear rims.
Old 10-05-2012, 11:12 AM
The cost of mounting and balancing will surely not be higher than a whole new set of rims over 5 years? Ive seen places that do it for $15 per wheel. which is $120 per year. Which is about even against a set of cheap rims over period of 5ish years. Since my rims are 7 years old they are not quite in the same condition as brand new ones even though i take good care of them. So Im not too concerened about possible damage to them with moutning and remounting. In an ideal world yes i would but new rims but i just dont have the money for that right now. I need to keep some back for the inevitable cooling system failure now im at 83K miles :-)
Old 10-05-2012, 11:20 AM
Zooks527's Avatar
Guaranteed it will be higher over 5 years. You're ignoring the higher cost of 18" snow tires versus 17". In addition, if you've found a place that is mounting and balancing a tire for $15 a pop, I'd bet one of my kids (OK, the one I don't like) they're using old-style equipment that's going to leave your BMW rims looking like you've been polishing curbs with them, regardless of how they look now.
A fast run on TireRack:
4 LM-60 tires in 225/40-R18 = $808 + $60 mount/balance at cheap place = $868
4 LM-60 tires in 225/45-R17 mounted and balanced on inexpensive rims (no TPMS) = $1132.
Difference = $264.
You would be ahead of the game after the second year. And a $264 savings this year doesn't seem big enough to fix the cooling system.
check with the cost by the size. 18" 35 and 40 series tire mount and balances will cost more.
you also run the risk of bead damage with the repeated mounts and dismounts. and also tire sensor damage.
i dont know that i would trust a $15 dollar mount and balance vs a hunter touchless mount/dismount and a roadforce balance. but if you're on a budget... i can almost guarentee you you'll come away with rim damage-- the proper equipment is expensive, a hunter gsp 9700 and a proper touchless tire changing machine.
if you're comfortable with that, then go for it, but in the long run, its a wash financially.
Old 10-05-2012, 11:24 AM
...and there i was thinking "oh yeah, i'll just throw a couple winters on to see me through"! so much to think about!
Old 10-05-2012, 11:53 AM
when i got my 01 i was like, oh, cool, high performance tires! how bad could it be in the snow
then reality sunk in
Old 10-05-2012, 12:18 PM
Chris90's Avatar
Chris90 Chris90 is offline
Mein Auto: '04 330i
If you're on all seasons already don't bother with performance snows.
"When you were born, you cried and the world rejoiced. Live your life so that when you die, the world cries and you rejoice." - Cherokee Expression
Old 10-05-2012, 12:36 PM
Im on Micheline Pilots that are very worn and need to be changed regardless.... Thought about all seasons but i figured that a set of winters will last me through until i sell the car X years down the road and will probabaly just about break even of 2x all season replacements vs 1xset of summer tires adn 1x set of winters. leaving me with the performance benefits of both.
Old 10-05-2012, 12:43 PM
if you see only very light snow, take a look at the conti DWS. 50K mile treadlife warranty. very good snow performance for an all season
Old 10-05-2012, 12:55 PM
galahad05's Avatar
Better with Butter
I have a buddy with an '09 M3. He got tired of the summer/winter wheel swap (when he had an e46 330ci), so opted to go with the Michelin PS2 all-seasons.
He's very happy with them. He just tries to minimize on-road-time when it's snowing.
-- Irish Proverb
Old 10-05-2012, 06:17 PM
ProRail ProRail is offline
"Clunker" *****
Mein Auto: 1999 BMW 528A-220K-traded
Continental all-season. Rarely have a problem but I do avoid deep snow. I'm retired so if it's really bad I stay home (but my agency has had work-at-home for at least a decade so it would not have been a problem even if I was still employed).
Old 10-11-2012, 07:02 AM
peripherique peripherique is offline
Mein Auto: 2009 328i XDrive Sedan
Conti DWS. Few snow events in MD/VA.
Old 10-12-2012, 05:14 PM
machtnichts machtnichts is offline
Mein Auto: 2011 328i xdrive
Snows are awful to drive except in the snow, they feel squishy and squirmy on dry roads and have weak grip on wet roads. Unless you are really likely to get snow, there is NO performance benefit from them other than on the one or two days all winter when you may be forced to drive in the snow.
Where I drive.
Old 10-12-2012, 05:24 PM
55's Avatar
55 55 is offline
Mein Auto: 2016 BMW touring 328d
Dunlops winter runfflats (3D?)
Sent from my GT-N7000 using Bimmer App
