Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners & Enthusiasts
Old 09-23-2012, 05:32 AM
TDIwyse TDIwyse is offline
Mein Auto: 4 diesels
First 1/4 Mile Results and Questions
Took the vehicle to a dragstrip this weekend for their last test-n-tune day of the season. Never been to a dragstrip before and didn't know what to expect. Must say it was a fascinating experience. As a complete newbie didn't do anything special to prep the vehicle: Fuel tank was 2/3 full, tires were normal air pressures, didn't remove any items (except the jumper cables) to reduce weight. Also, there was an 18mph NNW wind with gusts into the mid 20's and the track has the cars racing straight North . . . right into the wind. And man was the place packed with racers!
The best run was the first one before many people had made passes (and started dragging water into the main lanes). Was able to mostly bypass the water pit, but the pits were nearly as wide as the lanes. I had read about starting in 2nd and brake boosting to ~2k, but for my first 1/4 pass ever and I tried to start conservatively. Didn't really do any brake boosting and left the traction control on. I did start in 2nd gear. It was obvious the vehicle had too much torque for the track surface as the traction control kicked in quite a bit in 2nd gear even without brake boosting. The Michelin Pilot Super Sport's were not up to the task. Also, my reaction time sucked and the 60' was a horrible 2.24sec, but ended up with a 13.1 sec 1/4 mile at 107.2mph. That was fun.
Next pass still had the traction control on but tried to brake boost a little and had bigger traction issues. Much better reaction time on my 2nd pass, but an even worse 60' at 2.6 sec. Still ended up with a 107.1mph at the end into that headwind.
Tried once with traction control completely off and it was a fricken' clown show. Car nearly went sideways before I took my foot off the pedal. And water was becoming a problem as the big boys were heavily using the water pit (that's kinda cool to see) and dragging water everywhere. I didn't see any reason to continue trying without drag slicks.
Calculating the difference in wind drag at 107 mph vs 125 (107 + the ~18 mph headwind) shows an extra ~35hp sucked up by the headwind. Too bad it wasn't a strong tailwind :-)
So, you guys with drag strip experience, what do you think proper tires that could hook up with brake boosting, and a calm day, would do for the 1/4 ml time? And any suggestions on a good drag wheel/tire setup?
2011 335d 11.8 sec 120 mph 1/4 mile NHRA certified track
2004 Ram Cummins with lots-o-mods
Old 09-23-2012, 05:39 AM
cssnms cssnms is offline
Mein Auto: '11 335d
Were you running stacked?
Get yourself a set of BF Goodrich DR's. Forget going to the track with street tires - been there done that. Like you all I did was spin-out no matter how I feathered the accelerator. The drag strip is fun though... OH, and next time go with a max 1/4 tank. All of that weight you were carrying drug you down. I bet you could have broken 13 on your one pass had you had less fuel in your tank.
BTW, that is an outstanding time/trap for not brake boosting, traction control on and on street tires. **** that is an outstanding time period, but esp so considering the aforementioned.
Old 09-23-2012, 06:50 AM
Thnx.
Yes, Evolve with custom progressive controlled JBD with 600cc/min 70/30 H2O/methanol injection.
Maybe next year I can find some DR's and be smarter about the weight and find a test-n-tune event with less wind. Today the weather is calm winds and would have been a much better experience, just took too long for the front to move through.
Question on the 4th/5th gear shift. Watched a couple youtube videos before going from hotrod and others and it seemed like the shift point for 4/5 was right at the 1/4 mile point. On that first run I did I short shifted 4th early (~4000 rpm) thinking it might help. Anyone have experience with how best to manage that shift? Should you just leave it in 4th longer and hit the 1/4 ml while it's shifting in 5th? Almost wonder if larger tire diameter would help so that shift occurred at a higher speed?
Old 09-23-2012, 07:34 AM
Mein Auto: '11 335d
Originally Posted by TDIwyse View Post
Thnx.
Larger diameter tire will be counter-productive to your effort.
Fastest times thus far have come by letting the car shift itself in manual mode, brake boosting.
Old 09-23-2012, 08:14 AM
Snipe656 Snipe656 is offline
Mein Auto: 2009 335d
That is interesting that they were sloshing water onto the track. Usually the more cars with sticky tires going through there the more sticky the track becomes as they are laying rubber down onto it. I have not been to a stip in many, many years, I am pretty confident I'd embarrass myself greatly at this point in time. We used to go all the time though, lots of fun times except when you break something and are a hundred miles from home and trying to figure out how to either a) fix the car there or b) somehow get the car home.
--Admiral Aaron Rouse
Old 09-23-2012, 10:17 AM
Not finding much online to quantify wind impact on results. Some qualitative info here for newbies indicating 0.2-0.3 tenths potential impacts:
http://www.8thcivic.com/forums/autoc...must-read.html
Old 09-24-2012, 01:38 PM
62Lincoln's Avatar
62Lincoln 62Lincoln is offline
Mein Auto: 335d
TDI, do you have the capability to log the 'performance' of the i/c over these multiple runs? I'm curious about how well the i/c performs in cooling the air for the initial run, and then how well it performs in terms of heat soak on multiple runs. Does the BT have the capability to log ambient versus intake air temps?
Old 09-24-2012, 03:38 PM
Yes it can and yes I have, but I didn't for this event as when reading their rules online before the event it appeared they didn't allow any type of recording devices, computers, etc. However it appears that was more for the $ competitions and not the test-n-tunes. Heck, I was so clueless I forgot to put my helmet on the first 2 passes. I did capture the first run on the android torque app's "track recorder" which is pretty neat to watch. But the GPS was still on from routing to the strip and appears to have messed up the times recorded as it argued with itself wether or not to use OBD or GPS speed data (it said 11.9 1/4 mile time and failed to register 0-60, 40-60, etc).
There's some data here that gets really interesting starting pg 3 (http://www.bimmerfest.com/forums/sho...=598240&page=3). Has BT data on IC temps during full fueling runs in hot weather. The water/methanol injection does a tremendous job of holding temps down run after run. Eliminates heat soak conditions on multiple back to back runs in hot/humid weather.
Looks like there's another test-n-tune Friday night. Not sure I can get drag radials and clear my schedule for that event or not but I'm tempted...
Old 09-24-2012, 04:26 PM
62Lincoln's Avatar
Mein Auto: 335d
I love the work you've done with injection, but I fear I'm not technically savvy enough to attempt such a thing on my car. OTOH, I'm interested in the possibility of improving IAT and heat soak issues via an improved i/c. I can't imagine a better i/c can approach the improvements you are generating, but I hope it will provide improvement from where I am today (Evolve tune, but no JBD).
Old 09-24-2012, 06:12 PM
Thanks.
There's more than one way to skin a cat so an improved intercooler would be a good option.
I should mention that after the 3rd pull in 14 mins time the engine coolant was elevated and the car needed to rest.
Old 09-25-2012, 02:57 PM
Well . . . ordered a dedicated drag wheelset. Kosei k1's with Hoosier's. Anyone know the easiest way to drain excess fuel from the tank? Can it be syphoned or is there an anti-syphon device in the filler neck?
Old 09-25-2012, 03:40 PM
How much does a gallon of DEF weigh? I'd imagine between that and the fuel these cars must have a lot of backend weight.
Old 09-25-2012, 05:34 PM
GreekboyD GreekboyD is offline
Mein Auto: 2009 BMW 335d
Think I've read that a full passive and active tank of DEF on our cars will add about 50 pounds of extra weight.
Old 09-25-2012, 10:33 PM
floydarogers's Avatar
Pedant and Curmudgeon
Mein Auto: 335d, 328d, Toyota T100
Let's see: it's basically the same weight as water, 5 gallons is 20 liters (or thereabouts), a liter of water is 1 kg, so it's 20 kg or 2.2*20 = 44 lbs.
Old 09-26-2012, 10:31 AM
Just an FYI . . . If you use the supplied nozzle adapter to open the filler neck, and have a long enough tube, it's possible to syphon the fuel tank.
Old 10-04-2012, 11:25 AM
62Lincoln's Avatar
Mein Auto: 335d
Did the wheels/tires show up yet?
Old 10-05-2012, 08:40 AM
Yes, but there's a problem with one of the tires not holding air. Loses ~1psi/hr. Waiting for replacement but that particular size is on backorder . . .
Last Friday would've been perfect (no winds, 70F) but the track was setup for 1/8th mile only.
Old 10-05-2012, 08:46 AM
Back when I used to be a track junkie I'd routinely use the 1/8th mile tracks for testing new things. Especially suspension and tire changes. Guess I was more concerned with 60' testing when I was going to the 1/8th. You can at least though look at an 1/8th mile slip and get a good idea of what the 1/4 would probably be.
Old 10-05-2012, 09:28 AM
Good point. However, I'm actually more interested in the trap speed at the 1/4 ml point as it seems to correlate a lot closer to horsepower, so don't want to make the trip and take the time if it's not going to be the 1/4 mile.
Old 10-05-2012, 09:39 AM
Hopefully that bad tire can get sorted out quickly. I'd imagine weather conditions are becoming great for a boosted car at the track. I'd be very curious to see how much improvement is seen in the trap speed due to a more real launch from the tires. My experience never was much of a gain but it was in cars with suspension more purposely built for drag racing and never on an RFT but instead real tires(with some give in the sidewalls) v. usually drag slicks but sometimes cheater slicks. Probably a whole other world in these cars.
Old 10-05-2012, 10:07 AM
I don't expect much if any due to improved launch (got within 0.07mph trap speeds with the 2 runs even with a significantly worse 60' on one), but the 18mph headwind had a quantifiable impact (significantly more wind drag sucking up ~30+ hp).
Old 10-06-2012, 12:44 PM
Mein Auto: '11 335d
Call it a hunch, but I project you are going to produce the fastest 335d 1/4 times and traps speeds once you get the issues with your tire sortedf out. Good luck, keep us posted.
Old 10-10-2012, 04:36 PM
Replacement tire showed up yesterday. Mounted and balanced and holding air. Did some testing this afternoon and they provide significantly more launch capability based on GTech measured data than the street tires used previously. A major storm front is supposed to hit Saturday, but the weather for this Friday is looking promising for the last Test-n-Tune opportunity of the season in this area. We shall see . . .
Old 10-11-2012, 05:48 AM
Launch data comparison of the street tires vs drag radials: http://www.bimmerfest.com/forums/sho...7&postcount=83
The dragstrip cancelled this Friday's track event. That sucks. They have a season ending race the following Saturday and are supposedly opening up a test-n-tune in the afternoon for a few hours before the evenings races.
Old 10-12-2012, 05:15 AM
jashearer jashearer is offline
Mein Auto: Holden Wagon & Sedan
What track are you going to? Would love to come out and watch.
Cordova is open for a test n tune tonight if you want to make the 1- 1 1/2 hour drive east. Its a decent track.
Jay
Rover - 2013 Holden Commodore SV6 Sedan
Clark - 2013 Holden Commodore Sport SV6 Wagon
Brumby - 1955 Holden FJ Ute
