BMW Coding and Programming
Discuss coding options and features on your BMW here. |
F10 - Remove TPMS Warning
I have successfully removed all warnings about TPMS from my NAV - HU_CIC / RDC = nicht_aktiv (Thanks shawnsheridan!)
Now Im trying to remove the yellow warning light in the instrument cluster. Anyone attempted this? |
Did you search KOMBI for RDC setting, and if that did not work, remove 2VB from VO and VO Code KOMBI, HU_CIC, and RDC?
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 10-06-2012 at 05:10 AM. |
Kommentar=RDC Ueberwachung (Comment=RDC monitoring) KOMBI / ST_TYR_TIMEOUT = nicht_aktiv KOMBI /ST_TYR_ALIVE = nicht_aktiv
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 10-06-2012 at 05:11 AM. |
I tried those 2 above and it didn't fix. I will try to remove 2VB from vo
Ok. Try this one too: KL_PREDRIVE_F10_RPA = nicht_aktiv If unsuccessful, kill 2VB in your VO, and VO Code HU_CIC and KOMBI. RDC has no coding data, so there is nothing to VO Code there I don't think.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
Removed the 2VB and VO coded HU_CIC and KOMBI.
No luck. TPMS warning still present in NAV screen and instrument panel |
That is almost impossible to believe. Are you sure after you removed 2VB from FA, that before you VO Coded HU_CIC and KOMBI, you loaded that FA (the modified one without 2VB) and activated it, and not the FA read from the car?
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 10-08-2012 at 04:45 PM. |
So load the xml file with the 2VB option removed and VO code those 2 again?
Yes! That is why removed it. Now when you VO Code the ECU's, it won't enable 2VB like your regular FA that is stored in your car will (assuming you did not go so far as to write the modified FA to the car, and the FA in the car is original).
Just to keep the thread alive I have confirmed with Sean what I did was correct. New FA and VO coded Kombi and HUCIC. Still not luck. Will keep researching
when you remove the 2VB out of the VO, you still need to pulll the plug out of the RDC or remover the fuse, otherwise the car is still going to recognize the module and light is going to stay on.
Success! Did everything mentioned above but this time I removed fuse. No more tpms warnings, alerts in nav or instrument panel.
However, while coding the kombi it came up with a CEL out of the blue. It has been 3 days and its still there. I don't drive the car that much so I'm hoping it goes away on its own. |
Assuming the fault condition no longer exists, to clear the fault code. 1) Launch C:\EDIABAS\Bin\TOOL32.EXE 2) Hit F3 3) Load C:\EDIABAS\Ecu\F01.PRG 4) In the "Select Job: F01" window, select FS_LOESCHEN_FUNKTIONAL 5) Hit F5 6) "Results" window should show "JOB_STATUS = OKAY" Hopefully, Problem Solved. Note: fs_lesen_funktional only read fault codes, FS_LOESCHEN_FUNKTIONAL will delete it.
Shawn you the man! CEL is gone. To recap for people wanting to disable TPMS
Pull the fuse in the trunk for TPMS. Remove 2VB option in VO HU_CIC / RDC = nicht_aktiv (this removes TPMS options from NAV) KOMBI / ST_TYR_TIMEOUT = nicht_aktiv KOMBI /ST_TYR_ALIVE = nicht_aktiv Last edited by lifo_1; 11-25-2012 at 03:48 PM. |
It went away the first time i drove it after clearing it but it came back after that. Comes back after i clear it everytime. Might have to take it in
Maybe undo all your coding, clear it with Tool32, and see if it stays off. At least you will know if it is coding related.
hi guys, sorry to dig up this thread again but I could not manage to remove the RDC error message yet.
is it really necessary to remove the fuse to kill the error message? i dont even care about the yellow warning light much, i just want to remove the warning message from the idrive that pops up on every start. I coded the 3 values as stated above, but I do not want to remove the fuse if not 100% necessary. what does this mean: "Remove 2VB option in VO"? I have e-sys running and have coded a couple values before, but im not a coding expret. what is the VO? |
update: well it wasnt too hard. I just had to remove the RDC fuse in the trunk. warning is gone forever
thanks to everyone in this thread
