#26
I had the problem of the alarm going off when I was parked on a slight downward slope, and passing traffic would generate enough road vibration to set off the motion detector. Once that was disarmed, it was fine.
Also had the problem last week in the middle of the night as my battery was apparently going dead from an unknown/undetected drain. Finally had to leave it unlocked in my driveway for a few hours until I got up and recharged the battery.
2000 528iT sport (Sienna Red w/ Tan) 2000 540i/6spd (Sienna Red / Tan) |
#27
+1 on the cell phone bit!!! I have a blackberry and left it in my 540, it didn't just set the alarm off when it rang, but even when it was searching. I'm wondering if maybe the infared is setting it off. by the way, just to make sure, i placed my daughters regular phone in it and it did nothing.
#28
+ 1 Million on the Hood Sensor. Even my X5 is yappin in the middle of the night. Probably the damn sensor!
2007 E60 530i - Current 2002 E39 530i - RIP ![]() BMWCCA MEMBER #397411 |
#29
so i have been having the same problem mentioned a few times in this post.. i took out the fuse by the battery.. and now the alarm obviously doesnt go off but when i lock the car.. after a few minutes.. the lights start flashing as the alarm going off except the sound.. any suggestions?
#30
Disconnecting the hood sensor worked for my 2002 525iT. For the first time in months I don't have to open the back door in order to lock the front door.
#31
me too... hood sensor... unplugged... issue solved.
#32
I had my truck open on its own once and set the alarm off. It just went off again last night in the garage (only the second time ever), and while I played with the trunk before leaving for work I don't know for sure if that was it this time. Hood sensor, hmm...
2012 Honda Accord coupe V6 6-speed 7-1-08 to 1-16-12: 2003 BMW 540i Sport 6-speed |
#33
http://www.bimmerfest.com/forums/sho...5&postcount=61
What do we look at next when it is not the hood sensor |
#34
Just went to unlock my dad's '04 X5 in Walmart's parking lot, and... BEE-EEE-EEE-EEE-EEE-EEE! Yeesh. :/
#35
Alarm goes off after about 5-10 mintues. Any ideas? Alarm module? |
#36
Need Alarm Help...Driving Me Nuts!
I am reviving this thread because I see it died right where it got interesting for me. I noticed no one answered the last question in this post. I have a 2000 528IT, 86,000M, and have had an alarm problem for 6 months or so. I have taken the battery out and had it bench tested, I have disconnected both the hood and interior roof sensor and the stupid thing stills goes off even if I try the double lock thing.
I can count on every second weekend going out to the car to find the battery completely dead and having to charge it overnight...why? Because the siren goes off, then shuts off, but the lights sit there and flash causing a drain on the battery; the lower the battery gets the more this stupid car thinks its being tampered with and sets off the alarm again, thus draining the battery some more, which in turn sets off the alarm again (see the pattern?) ![]() Is there any help out there to solve this problem? I have read about rechargeable batteries being inside the alarm somewhere that wear down after time. Is there something I'm missing or do I have the one off problem to which there is no fix... |
#37
Chck out a treand in the E38 side. Theres a newer post about draining battery. It has'nt really gone anywhere yet, but keep an eye on it. Sorry I cant be of more help.
#38
Belicek,
I can't comprehend that you have not taken this to a mechanic to get fixed. You really let this insanity go on for SIX months????? For others, here is a review of possible things to try:
#39
Beli tried the hood sensor, would have been good to test a brand new battery. Try opening the 'secret menu' and checking alternator voltage just to be sure it is getting good charge while you drive.
#40
Lots of people say it's the hood sensor, but what is it about the hood sensor?
Can it be repaired? Is it shorting out (i.e. going open position when closed)?
Cheers Stuart NZ |
#41
If you have some type of powder, chalk paint or fingernail polish...you can slather the top of the senor's pin, then close the hood...this will mark where the tip of the pin contacts the hood. If this contact point is the insulation versus the metal part of the hood...worn insulation may be the cause of the sensor not making proper contact. ![]() ![]()
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) Last edited by QSilver7; 10-06-2012 at 09:38 AM. |
#42
This is my second BMW, the first I had while assigned in England; it was a 535, got 38 MPG, and parts could be attained anywhere, relatively inexpensively. Fast forward to my return to the states where I buy another...talk about a different story. This one gets 19 MPG, weighs a lot more and parts are outrageously expensive...and that's for used parts. I contacted Barvarian for a used stereo part in the boot...$350 for a 12-year old stereo part. ![]() But I digress... As to your list... Battery is less than one year old, passes all tests and is quite secure Hood and interior sensor are disconnected (is there a tilt sensor somewhere? are there any other sensors to disconnect?) No need to push button twice if sensor is disconnected, this takes it out of the picture. (Is this correct?) Fuse 48 being unplugged does NOT disarm the security system; just the siren, lights will still flash if the alarm is activated. Just this morning after I arrived at work I double locked the door with the key and 2 hours later the alarm went off again, the siren stopped but the lights flashed for an additional 5 minutes (yes, I timed them). I just charged the battery overnight (It was totally dead again after this last weekend of sitting in the driveway not being driven) I am a mechanic and have my own private shop w/lift, I say this not to brag but to inform that I am not a total newbie when it comes to turning wrenches. I even built my own tool ($480.00 from BMW cost me $38 to build) and changed out the rear suspension bushings myself. This problem has me quite perplexed. What I am finding strange is the lack of anyone else having experienced the same thing before. Usually forums, if searched long enough, will reveal someone who found a fix. I think the next step is to put this POS up on the lift and gut the alarm in the wheel well; my concern is that it will disable the car but what good is a car that won't start because the alarm keeps draining the battery? I have read that there are rechargeable batteries that are in the siren portion of the alarm system that die over time (great design!) causing the system to repeatedly activate...I will focus on that area for now and report back what I find. If anyone has additional information that I missed or have wrong, please let me know. The depreciation on these cars is so bad that I am basically stuck with this thing so I have to figure it out. I should have bought a Toyota! Last edited by Belicek; 10-09-2012 at 10:37 AM. |
#43
I'm not sure if you've fixed it yet but I will +1 that its the hood sensor. I had the same issue on my car. I thought it just wasn't mounted well so I ziptied it better and it still went off. Got a new hood sensor and the alarm hasn't went off since.
#44
One of the first things I tried was the hood sensor; it has been unplugged for months so it can't be the culprit of setting off the alarm. |
#45
See also:
- How to understand the BMW E39 EWS alarm drive-away protection system (1) (2) (pdf) & troubleshoot the alarm & hood switch (1) (2) (3) (4) or replace the siren (1) or disabling or enabling the unlock chirp (1) (2) (3) & how to maintain (1) and repair your hood release bowden cable (1) (2) (3)
#46
As the old saying goes, necessity is the mother of all invention... One final question regarding the sensors: Are there any other sensors which can be disconnected on a 528it besides the hood and interior roof sensor? Thank You |
#47
Siren is out and apart
I placed the POS on the lift and removed the siren last night; took about ten minutes and it was in my hands. After I removed the three screws holding it together I found it was sealed at the seam as well, probably to insure a moisture barrier due to hostile environment where it's mounted. I took a razor knife and repeatedly scored the seam until I was able to get a portion to separate, be patient and gentle, like most things on this car, it is made of recycled brittle plastic and it will snap in a heartbeat.
After I separated the case, I found three batteries wired together in a triangle pattern to form a total of 6/250H 7.2v which plugs into the siren via a small two-wire harness. Of course I couldn't find the battery setup anywhere except European websites but I did find the individual batteries 2/250H 2.4v, with wiring tabs, on E-Bay for $7.99 (free shipping too); I ordered three of them and will solder them together myself. My belief is that I can remount these back into the siren, seal the case back up, hold it together with the original three screws and place it all back together in the wheel well. I see nothing prohibiting this from happening. A savings of $140, a minor investment of time and the joy of doing something I have not found anyone else attempting yet. On a side note, the car runs fine without the siren, the jury is still out on whether the lights will continue to flash because something else was the cause of the alarm going off. I will update when I have it back together. Last edited by Belicek; 10-12-2012 at 06:41 AM. |
#48
Mine was rusty contacts on door switch, used contact cleaner & clicked it many times, solved it.
#49
Did the same thing on mine. Quick 30 second fix and it still allows the keyless entry to work. I don't care about the alarm- I live in Iowa!
#50
If my school police drives by my car it sets off my alarm! Something to do with the frequency they are on.
528i Stock except for the Audio system |
