engine coolant - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 10-05-2012, 04:54 PM
joshmauch joshmauch is offline
Mein Auto: 323i
engine coolant
i work at a domestic auto repair shop and i have some regular old 50/50 mix coolant. can i use that or do i need a special type?
Old 10-05-2012, 06:48 PM
ventsyv ventsyv is offline
Mein Auto: 03 BMW 330ci
If you are doing it for a client, I would say add BMW coolant. If you are topping it off to get the car home, I say normal coolant (or distilled water) is fine. Just tell them and make sure they are OK with it.
Old 10-05-2012, 10:29 PM
Mein Auto: '04 330Ci 6-speed
Don't put any coolant in unless it is spec'd for all engines.
Prestone straight is what I use, mixed with distilled.
Old 10-06-2012, 10:56 AM
Mein Auto: 323i
ok this is an extended life all vehivle all color coolant is what is says its my personal car the coolant light came on and i checked it and its low so ill just use the universal
Old 10-08-2012, 07:18 PM
charmcitybmw charmcitybmw is offline
Mein Auto: 2005 X3
My coolant indicator is going on and off on my 2006 X3. Should I only use BWM coolant? anything else with it? Thanks!
