E34 (1989 - 1995)
Old 10-05-2012, 10:10 PM
Robert Morris Robert Morris is offline
Mein Auto: 1993 525i
1993 525i won't ccrank
just changed starter. no clicking or dimming of lights now. no anything when turning key. Aaaaaargh.
Old 10-06-2012, 12:10 AM
Banned
Mein Auto: car
What happened before that? Why did you change the starter ? You probably messed something up during installation (happens all the time). Which means that its fixable. Go through exactly what you did in your mind. Its best to stand in front of the car while you do this. Be slow and methodical, and be zen about it. Don't worry....its probably something really minor that you'll laugh about when you discover.
Basically, make sure everything electrical is connected, your gear shift is in park, and all of your fuses are working. Make sure your fusible link is properly connected. Check your battery connections - you probably unhooked them for the installation. Then check if all your relays are working. Then download the bentley manual and check the starter troubleshooting list.
Its best to get a good nights sleep before you start looking at this again.
Old 10-06-2012, 10:17 AM
My525iT My525iT is offline
Mein Auto: 92 525iT Wagon M50
Sometimes might still be loose.
Old 10-06-2012, 07:23 PM
BMWFatherFigure's Avatar
Old School
or not as clean as you thought. Did you accidently connect the small wire to the 'cold start' terminal of the solonoid? Been there - done that.
Current:
E38 Parts Car
Previous:
Old 10-13-2012, 11:06 PM
Mein Auto: 1989 525i M20B25
Yup, check connections.
Old 10-14-2012, 09:37 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
I would check fuses and starter connections.
Old 10-14-2012, 09:44 PM
Banned
Mein Auto: car
I would update this thread !
Old 10-14-2012, 10:34 PM
i would update this thread !
+1
