E30 (1982 - 1993)
Old 10-03-2012, 04:21 PM
jlebreton jlebreton is offline
Mein Auto: 1987 325i
87 325 Rumbling noise from rear
I have a rumbling noise at the rear that only lasts for about 2-3 seconds when I accelerate from a stop . Wheel bearings? I dont think so, It seems to be in the middle( diff area )
Old 10-03-2012, 06:13 PM
hornhospital's Avatar
D'oh, You Kids!
Center support bearing on the driveshaft.
Quotes to live by:
Old 10-04-2012, 09:10 AM
john@eac john@eac is offline
Past Sponsor
Mein Auto: Many
I would agree with checking the center support bearing. Also check for worn bushings to make sure that the differential isn't moveing causing the noise.
Old 10-04-2012, 04:14 PM
E30949/909 E30949/909 is offline
Mein Auto: 1990 325IC
Deff csb I have the same prob. Just rebuild your driveshaft an get new bearings. Should cost around 500 if a shop does it with labor.
Old 10-06-2012, 05:44 AM
thanks , I'll have a look , at he driveshaft. I was afraid it was the diif or cv joints
