Old 10-06-2012, 02:43 PM
baltej baltej is offline
Mein Auto: 2006 750li
Post 2006 E66 DCS/ABS/Servomatic/ faults
When I start my car there is no fault lights, i will begin to drive for about 10miles or so and the abs fault light appears, followed by the servomatic malfunction, and DCS inactivated. I had the car service codes read which read as a abs/speed sensor, so i replaced both front sensors $200 dollars later no change. I had the battery checked from autozone at 700cca,750cca, 850cca load and battery stayed at 80% under load. I had the alternator checked from a shop and they said its working fine. couple of things left to check, the steering wheel angle sensor, and the DCS module. So I would appreciate any input in to finding the problem and how to test them to check if its functioning, the shop i went to just feels like they will just have me replace everything until the problem is fixed regardless if its working or not. Click image for larger version
Old 10-06-2012, 04:01 PM
MINI+BMWtek MINI+BMWtek is offline
BMW master tech
Mein Auto: e30 318
I recommend to hook up with ISTA and have any faults that come up in test shedule review by a BMW technician. Ch
Sent from my Nexus 7 using Bimmer App
BMW master tech
Mein Auto: e30 318
Ch
Old 10-06-2012, 04:02 PM
BMW master tech
Mein Auto: e30 318
Check alternator with a DSO during start up,high load and ch
Old 10-06-2012, 04:03 PM
BMW master tech
Mein Auto: e30 318
Also look for any loose battery connections
abs, alternator, dcs, faults, servomatic
